Re: trailer tire
[Re: max_maniac]
#2015669
02/19/16 09:13 PM
02/19/16 09:13 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
My experience is that it is not your weather, it is your tires. Standard 15 inch trailer tires are JUNK. I converted my last trailer to 16 inch, 10 ply light truck tires and never looked back, two years parked outside and no problems. Tire shop got me a size that was only 1/2 inch taller than my regular 15 tires, so all I had to do was buy rims. With 15 inch trailer tires I used to blow out on average at least two a summer. Had damage to trailer, and changing trailer tires on the interstate is much more dangerous than drag racing. Bought a new trailer this year and 16 inch tires were an option, so I got them on it as well. [u][/u] The light truck tires are NOT LEGAL in most states. There are many states that it is the law that the tire has to be marked "Trailer Tire". I'm sure if I had 15" light truck tires they may last longer too but they are not legal for me. Do you know or know of any other person being stopped by the local law enforcement and looked at thier trailer tires for the "trailer tire only" designation labels I know I always look at the GVW rating on all of my tires, truck, car and trailers, to make sure there rated a bunch (minimum of 10%+) higher than the known load I'm towing or carrying I have fought that war on enclosed car trailer tires blowing up for no reason I've had some that weren't two years old and where ran at 5 lbs more pressure cold than what was on the sidewall and the load on each wheel and tire was 1200 lbs less than the max GVR of those tires I haven't lost one in the last three years, knock on wood, so I will probally have three of them blow out on the next long trip to a race I carry three spares now ready to go now I have had two tires come apart 80 miles apart from each other on the same trip, I also lost two by running over a rock in the dark on early morning before sunrise I missed it with the truck and hit it with both of the right side trailer tires, bent the rims and ruined the sidewalls
Re: trailer tire
[Re: ahy]
#2015809
02/20/16 01:08 AM
02/20/16 01:08 AM
Posts: 133 Winter Park, Florida
classracer
I fought the tire blow out woes for years. 26' Haulmark trailer st225x75r15 tires rated at 2550 lbs each. I kept them covered, tried an extra 10 psi while towing. Bottom line you better replace them every two years, and hope for the best during the two years. I just changer over to 16" wheels and Goodyear Lt245x75r16ht tires that are rated at 3100 or so pounds each. Normal inflation is 80psi. I wanted to use LT235x85r16 tires, but I did not have room. So far things seem to be much better. The trailer sits 2" higher, the ride is better, the tires don't bow out when in contact with the road, and when towing they run much cooler. Eventually I will have the trailer in a barn and on concrete, but for now tire covers and a piece of plywood on the sun side.
70 Challenger A/SA 2441
Re: trailer tire
[Re: J_BODY]
#2015894
02/20/16 03:32 AM
02/20/16 03:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Haulmark bought the cheapest crap tire you can buy(Carlisle) they could blow with just the weight of the empty trailer... I run a 43' trailer with 2 axles.. very heavy duty ones.. I buy the best tires for the 16" rims.. I have had 1 blow out.. that was after 7 years on them.. and that was part my fault.. the wheel cover fell off on the sunny side of the trailer and it sat for a few months like that.. I run the MAX air pressure the wheel can take..95psi and I check the pressure EVERY time that trailer goes out the drive way(the tire can take 100psi but the wheels are only 90psi so I run a couple psi high for the wheel EDIT The 43' is not Haulmark.. thats my home made trailer.. my old 26' was a Haulmark
Re: trailer tire
[Re: J_BODY]
#2015896
02/20/16 03:36 AM
02/20/16 03:36 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
From 97 to 2014 my Haulmark trailer had about every 15" combo you could think of on it.... and it came down to the same as many. Throw them out after two years.
My dad got out of racing so we sold the 24ft and kept his Cargo Mate 28ft trailer. It has 235/85/16 tires and now it looks like I'm back in the two year deal because this trailer is eating the tires off it!!! The right rear seems to be taking the brunt of it as it will be 6-8 degrees warmer when I stop for a rest and check them. I'm hoping to find somewhere to try and get it aligned. What type of axles do you have on your trailer ? I have the torsion type and when I loaded up the trailer to max the axles would deflect and wear out the tires fast from over heating.
Re: trailer tire
[Re: MR_P_BODY]
#2015967
02/20/16 11:39 AM
02/20/16 11:39 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Haulmark bought the cheapest crap tire you can buy(Carlisle) they could blow with just the weight of the empty trailer... I run a 43' trailer with 2 axles.. very heavy duty ones.. I buy the best tires for the 16" rims.. I have had 1 blow out.. that was after 7 years on them.. and that was part my fault.. the wheel cover fell off on the sunny side of the trailer and it sat for a few months like that.. I run the MAX air pressure the wheel can take..95psi and I check the pressure EVERY time that trailer goes out the drive way(the tire can take 100psi but the wheels are only 90psi so I run a couple psi high for the wheel EDIT The 43' is not Haulmark.. thats my home made trailer.. my old 26' was a Haulmark care to share what you consider the BEST tire.i,d rather spend more than waste less.
Re: trailer tire
[Re: bonefish]
#2015977
02/20/16 12:01 PM
02/20/16 12:01 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Haulmark bought the cheapest crap tire you can buy(Carlisle) they could blow with just the weight of the empty trailer... I run a 43' trailer with 2 axles.. very heavy duty ones.. I buy the best tires for the 16" rims.. I have had 1 blow out.. that was after 7 years on them.. and that was part my fault.. the wheel cover fell off on the sunny side of the trailer and it sat for a few months like that.. I run the MAX air pressure the wheel can take..95psi and I check the pressure EVERY time that trailer goes out the drive way(the tire can take 100psi but the wheels are only 90psi so I run a couple psi high for the wheel EDIT The 43' is not Haulmark.. thats my home made trailer.. my old 26' was a Haulmark care to share what you consider the BEST tire.i,d rather spend more than waste less. If you go on this website and do some reading it is USUALLY kept up to date with lots of good info. I had issues with the generator in my motorhome and these guys straightened me out. Most of these guys are full-time RV'ers so they are on the road all the time. Lots of good up to date info on tires. For me like I said I'm stuck with 15 inch tires and 3500 pound axles so I'm overloaded (not legal) every-time I go to the track. I have had very good luck with the Carliles upgraded 10 ply tires. I get 4 years out of my tires and I tow 80 mile round trip every week from April 1st to the second week of November and usually 3 trips a year to Norwalk a year at 400 miles round-trip. I park on gravel at home during the week and over the Winter. Trailer is always parked outside in PA weather with the tires uncovered. http://www.rv.net/
Re: trailer tire
[Re: bonefish]
#2015982
02/20/16 12:08 PM
02/20/16 12:08 PM
MR_P_BODY
Haulmark bought the cheapest crap tire you can buy(Carlisle) they could blow with just the weight of the empty trailer... I run a 43' trailer with 2 axles.. very heavy duty ones.. I buy the best tires for the 16" rims.. I have had 1 blow out.. that was after 7 years on them.. and that was part my fault.. the wheel cover fell off on the sunny side of the trailer and it sat for a few months like that.. I run the MAX air pressure the wheel can take..95psi and I check the pressure EVERY time that trailer goes out the drive way(the tire can take 100psi but the wheels are only 90psi so I run a couple psi high for the wheel EDIT The 43' is not Haulmark.. thats my home made trailer.. my old 26' was a Haulmark care to share what you consider the BEST tire.i,d rather spend more than waste less. Dont quote me but I believe the last set I bought were Marathon trailer tire(Goodyear).. the heaviest rated I could buy. was F or G rated... I have tried others but they werent rated as high.... I'm not home right now so I cant go see what I have
Re: trailer tire
[Re: bonefish]
#2016443
02/21/16 01:50 AM
02/21/16 01:50 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
My Haulmark which I purchased in 97 was equipped with Goodyear Marathons. After two years or so a sizable egg appeared on the sidewall..... Goodyear replaced all four tires no questions asked (recall). As I remember the score card read like this. 2 sets of GY Marathons, Carlisle (needed tires NOW.... tread was coming off GY, noted at the track.... might have been three to four years on those, I was in denial about them lasting), cheap Chinese tires two years, my first set of Maxxis 10 plys... two years, second set of some sort of 10 ply, two years...
My present trailer has "HI RUN" 16" tires on it. Max psi listed at 90, but I run 80. The trailer was originally equipped with some other Chinese tire.
I hate trailer tires....
Re: trailer tire
[Re: bonefish]
#2016516
02/21/16 10:42 AM
02/21/16 10:42 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Those goofy looking airless tires they make for heavy equipment might eventually find an application here. However I am sure age and lack of use causes problems with those as well.
68 Barracuda Formula S 340
Re: trailer tire
[Re: bonefish]
#2016591
02/21/16 02:02 PM
02/21/16 02:02 PM
J_BODY
aZLiViN
In the 16" arena there is also the G rated tire with it's max inflation of around 120 psi, but I don't think my steel wheels are rated for them.... that and I'm not sure living in the desert that they would be prone to lasting any longer due to the environment. Back in June I left town to race in vegas. The road temp was 168 degrees. Stopped about 1/2 way for a snack break and my tire temps were 159. you can literally spend days reading info and stories on this subject. This was one bit of helpful info I found years ago at Discount Tires web site:
Trailer Tire Applications •Trailer tires are designed for use on trailer axle positions only. They are not built to handle the loads applied to, or the traction required by, drive or steering axles.
Inflation •Always inflate trailer tires to the maximum inflation indicated on the sidewall. •Check inflation when the tires are cool and have not been exposed to the sun. •If the tires are hot to the touch from operation, add three psi to the max inflation. •Underinflation is the number one cause of trailer tire failure.
Load Carrying Capacity •All tires must be identical in size for the tires to properly manage the weight of the trailer. •The combined capacity of the tires must equal or exceed the Gross Vehicle Weight (GVW) of the axle. •The combined capacity of all of the tires should exceed the loaded trailer weight by 20 percent. •If the actual weight is not available, use the trailer GVW. If a tire fails on a tandem axle trailer, you should replace both tires on that side. The remaining tire is likely to have been subjected to excessive loading. •If the tires are replaced with tires of larger diameter, the tongue height may need to be adjusted to maintain proper weight distribution.
Speed •All "ST" tires have a maximum speed rating of 65 mph. •As heat builds up, the tire's structure starts to disintegrate and weaken. •The load carrying capacity gradually decreases as the heat and stresses generated by higher speed increases.
Time •Time and the elements weaken a trailer tire. •In approximately three years, roughly one-third of the tire's strength is gone. •Three to five years is the projected life of a normal trailer tire. •It is suggested that trailer tires be replaced after three to four years of service regardless of tread depth or tire appearance.
Mileage •Trailer tires are not designed to wear out. •The life of a trailer tire is limited by time and duty cycles. •The mileage expectation of a trailer tire is 5,000 to 12,000 miles
One of the more "enlightening" things I noted was the "time" information, the "heat", and the general statement about pretty much not going by "tread wear".
