B Body Bucket Seat Mystery Frame #2014951
02/18/16 09:04 PM
02/18/16 09:04 PM
California, United States and ...
Dibbons Offline OP
Dibbons  Offline OP
I am in the process of reupholstering the buckets seats on my 1972 Satellite Sebring Plus project car. First of all, let me say I am not sure if the buckets are actually from a '72 model, they may be from a '71. Anyway, I purchased Tamraz's 72-74 Mopar B Body Front Bucket Seat Bun Foam to replace the rotted foam in my front seats. The old driver's side bucket was so torn up that I could see a wire type frame showing through along both sides of the bucket seat back. The new foam doesn't seem to have this wire support built into the foam and my upholstery guy says he can't use the old frame structure (or whatever you call it) with the new foam. It seems without this steel support, my bucket seat with just the new foam will be all floppy on the sides. Am I predicting the negative outcome correctly or is old metal frame built into the original seat foam not really needed? Thank you from someone worried about breaking my seat back (or my own back).
Re: B Body Bucket Seat Mystery Frame [Re: Dibbons] #2014968
02/18/16 09:29 PM
02/18/16 09:29 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Pictures of your frames would really help, but if anyone reproduces 1972-74 foam it is news to me.
Re: B Body Bucket Seat Mystery Frame [Re: Dibbons] #2015073
02/19/16 12:10 AM
02/19/16 12:10 AM
Dibbons Offline OP
Dibbons  Offline OP
Here is a foto of the torn bucket seat with the rods showing in the side missing the foam (it is the second foto on my build page)
[img]http://www.forbbodiesonly.com/moparforum...-Satellite-quot[/img]
Here is the ebay listing for the bucket seat foam:
[img]http://www.ebay.com/itm/72-74-Mopar-B-Bo...=item5af463fb6c[/img]
Re: B Body Bucket Seat Mystery Frame [Re: Dibbons] #2015210
02/19/16 02:50 AM
02/19/16 02:50 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
those are for sure not 70-71 b frames
Re: B Body Bucket Seat Mystery Frame [Re: Dibbons] #2015262
02/19/16 09:09 AM
02/19/16 09:09 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
They could be late 1971 frames, remove the back & look for the spring basket. If it is not there, then they are 1972 or newer. You should find part number tags with date codes inside also.
Re: B Body Bucket Seat Mystery Frame [Re: Dibbons] #2015334
02/19/16 11:54 AM
02/19/16 11:54 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
With a small release button??
I wasn't aware that
The side covers and buttons
Were interchangeable between them.
Re: B Body Bucket Seat Mystery Frame [Re: Dibbons] #2015357
02/19/16 12:19 PM
02/19/16 12:19 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
Somewhere in mid 1971 production, they changed the buckets slightly to have the smaller release button and 1 peice seat back/ hinge cover. They carried that style over into 72 with the only difference being the tracks.. That seat should be correct for a mid/ late 71/ 72.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: B Body Bucket Seat Mystery Frame [Re: Dibbons] #2015415
02/19/16 01:50 PM
02/19/16 01:50 PM
Dibbons Offline OP
Dibbons  Offline OP
These seats have a one piece plastic seat back and hinge cover. But the old seat back foam has built in metal rods to support the sides and I am still wondering why the aftermarket does not have that, and what happens when I lean back on the seat without that extra support. Maybe someone who has used the aftermarket foam can answer that?
Re: B Body Bucket Seat Mystery Frame [Re: Dibbons] #2015430
02/19/16 02:17 PM
02/19/16 02:17 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
The seat is correct for 71/72 . I think your frame may be broken on the door side . The metal wires inside the orig foam have to be reused/replaced on the new foam ,same with most all replacement foam for seats. Most all shops should know this .
