Cracked Balancer #2014038
02/17/16 04:33 PM
02/17/16 04:33 PM
Jacksonville, Fl
426runner Offline OP
Jacksonville, Fl
My real question... can this be repaired?
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Cracked Balancer [Re: 426runner] #2014044
02/17/16 04:38 PM
02/17/16 04:38 PM
Chicago
PurpleBeeper Offline
Chicago
Hmmmm..... would I take a cracked piece of steel weighing about 5 lbs. and spin it up to 7000 rpm a few feet from me? NOPE
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Cracked Balancer [Re: 426runner] #2014075
02/17/16 05:22 PM
02/17/16 05:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No way I would trust any repair on that.
Re: Cracked Balancer [Re: stumpy] #2014111
02/17/16 07:05 PM
02/17/16 07:05 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
When you consider the potential for damage, it would be foolish to reuse this part. I think you just dodged a bullet when you found that.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Cracked Balancer [Re: Polarapete] #2014122
02/17/16 07:27 PM
02/17/16 07:27 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Not to mention the pits and the crack will make it hard for the timing cover seal to seal on the snout. You could sleeve it, of course but prob not worth it.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Cracked Balancer [Re: 426runner] #2014155
02/17/16 08:04 PM
02/17/16 08:04 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
What they said. Throw it away or used as wall art.
Re: Cracked Balancer [Re: fastmark] #2014176
02/17/16 08:29 PM
02/17/16 08:29 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Sandy,
Is this off the Runner or someone else's car?
Re: Cracked Balancer [Re: 426runner] #2014203
02/17/16 09:08 PM
02/17/16 09:08 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
One word. JUNK
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Cracked Balancer [Re: yella71] #2014288
02/17/16 11:24 PM
02/17/16 11:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
With all of the above Otherwise fan panic realcrazy twocents
Re: Cracked Balancer [Re: 426runner] #2014346
02/18/16 12:26 AM
02/18/16 12:26 AM
Kirkland, Washington
Pacnorthcuda Offline
My comment is kudos to you for catching it. Great that it just wasn't reinstalled. I recently scrapped one that had a sloppy key way. No way was I gonna run it!
Re: Cracked Balancer [Re: 426runner] #2014409
02/18/16 01:46 AM
02/18/16 01:46 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It's not worth it.
Re: Cracked Balancer [Re: Morty426] #2014420
02/18/16 01:58 AM
02/18/16 01:58 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I spoke with "JC" at ATI at the 2015 PRI show about adding a second keyway in a mopar damper. We were looking at one he had on display, he was very concerned about how much "meat" was left for strength if I choose that option, and wanted me to find a larger front seal so he could increase damper oustide snout diameter on a custom damper. I was leary, now, not so much.
Re: Cracked Balancer [Re: jcc] #2014540
02/18/16 10:26 AM
02/18/16 10:26 AM
I wouldn't have an engineering problem with cutting another key way as I dont think there'd even be close to a strength issue there but that'd be unrelated to the current crack situation (as said toss it & definitely Kudos for catching that as most wouldn't as it is such a trouble free/stout piece & unless I am missing something I'd think the only reason to cut another keyway would be to reclock the dampener slit location & considering the time/money to do that (properly) I'd just get another used one as they are pretty much bulletproof (yours is the only bad one I've ever seen unfortunately).
Re: Cracked Balancer [Re: 68jim] #2014555
02/18/16 11:11 AM
02/18/16 11:11 AM
Jacksonville, Fl
Jacksonville, Fl
Yes, this was on the car.
Re: Cracked Balancer [Re: 426runner] #2014719
02/18/16 03:55 PM
02/18/16 03:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's junk , find another.
Re: Cracked Balancer [Re: 426runner] #2014985
02/18/16 09:55 PM
02/18/16 09:55 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
junk!
Re: Cracked Balancer [Re: RapidRobert] #2015040
02/18/16 11:17 PM
02/18/16 11:17 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My conversation with ATI centered (pun intended) on my use of a centrifugal supercharger overloading a single OEM keyway. The Op's broke at the keyway as best as I can tell, and is apparently the weak point that ATI was trying to beat into my brain, and it looks like they have seen this before.
Re: Cracked Balancer [Re: jcc] #2015052
02/18/16 11:40 PM
02/18/16 11:40 PM
Yeah in the middle of my reply I knew I was off track/missing something! kinda like way way back when I had a car that you could lock by holding the outside door button that is under the handle in while you are shutting the door only to realize seconds later that the keys are still in the ign! (& a vague thought in the middle of the 3 second event that sumpin ain't right). the gut never lies
