Page 1 of 3 1 2 3
SURPRISE ! 440 Source damper is crap #201417
01/22/09 08:55 PM
01/22/09 08:55 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Bought a damper from 440 Source in June of '07. Engine has maybe 3,000 street/strip miles since install. Was checking everything over the other day and noticed blistering and flaking paint along the inner and outer ring joint. Removal and closer inspection revealed rust all along the joint but then I noticed that the outer ring was loose . It would move front to rear and side to side.
I talked to 440 Source's tech today (after leaving repeated messages) and (of course) the 90 day warranty is long expired, so T. S.
This part just plain failed prematurely and could have made a real mess of things had I not just happened to have caught it. I feel they should have offered some help! I even offered to order some other things I need, it they would just help some with the new damper. Shouldn't they have at least wanted to see the thing to know what is going on? But then, I guess it doesn't matter because they don't offer this particular damper anymore. (I wonder why? )
So, anyway, anyone with their previous style of damper (black) might ought to look it over in case I have not gotten the only bad one.
Master, again and still
Re: SURPRISE ! 440 Source damper is crap [Re: DaveRS23] #201418
01/22/09 09:13 PM
01/22/09 09:13 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
I brought a SFI Damper from 440Source about 3 months ago and it is part #200-1020 on their website. It has the SFI spec sticker on it RPM SFI 18.1.
It is black and I hope it is not the same damper that you are talking about. This doesnt sound good.
I think that they should offer help with the part given the obvious defect.
Re: SURPRISE ! 440 Source damper is crap [Re: DaveRS23] #201419
01/22/09 09:15 PM
01/22/09 09:15 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Well, it is a discount type part, and as a company they never really know what happens after it leaves the warehouse. Sometimes people beat them on, or pry them off, or have them on out of balance stuff that kills them quick. I'm by no means saying you did any of that stuff to it, just that they don't know that, so it might explain why they're not helping.
I'm not trying to excuse 440 source either, but warranty duration is always a good thing to consider with the price.
Re: SURPRISE ! 440 Source damper is crap [Re: dthemi] #201420
01/22/09 09:33 PM
01/22/09 09:33 PM
Wichita,KS
Wichita,KS
Mine actually has the SFI rated sticker on it. Can they get away with that if it is not?
Re: SURPRISE ! 440 Source damper is crap [Re: dthemi] #201421
01/22/09 09:36 PM
01/22/09 09:36 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
thats one of the problems when we buy parts as we can afford them for engine builds or what ever. Warranty it had ,to bad for you it ran out. I happened to do the same thing took me over a year to buy all the parts ,then it sat at the engine shop for months before assembly. About the only thing that was bought and used right away was the oil. I'm sure if it had failed within the 90 days after purchase,Brandon would have made it right.
Re: SURPRISE ! 440 Source damper is crap [Re: dthemi] #201422
01/22/09 09:38 PM
01/22/09 09:38 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Sure, it could be something I did. I would have felt better about it if they would have wanted to see the thing. Had I beat on it or dropped it or whatever, the evidence would be readily apparent. Because they were only concerned with the purchace date and not what caused the failure ( they didn't ask a single question as to cause), they either already know what the issue is or don't care what the issue is. Either way, I'm disapponted.
I am a wholesaler myself, and have been for many years. I have never encountered a situation where discount or wholesale price reduced warranty, particularly with a repeat customer.
And this damper has the SFI 18.1 sticker on it.
Re: SURPRISE ! 440 Source damper is crap [Re: Blakcharger440] #201423
01/22/09 09:41 PM
01/22/09 09:41 PM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
I've dealt with the guys at 440 source and have had good experiences. They are fairly close by and have a good reputation with the local mopar community. I bought thier girdle kit and pan. The pan was a mess and they had no problem fixing the issue. They actually pulled several of their pans to check against mine and reassured me that the new pan would not have the same problems. Got the pan and their word was good! My
I guess a lot can be said for checking "everything" during a freshen up. Glad to hear the Damper was caught before it was too late!
Tremp
Re: SURPRISE ! 440 Source damper is crap [Re: Plumcrazyracing] #201424
01/22/09 09:46 PM
01/22/09 09:46 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I think a 90 day warranty on a SFI dampner is a joke...... I mean cmon. how many miles do you put on your car in 90 days!
Its a mazing to me how the customer service is 50/50 at best. your either liked or no...... maybe it depends on how much youve spent there...
Mopar Performance
Re: SURPRISE ! 440 Source damper is crap [Re: Plumcrazyracing] #201425
01/22/09 09:46 PM
01/22/09 09:46 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I wont say much, as damage control will be along shortly, ie either a lock or Brandon with his usual excuses.
I just laugh as I was flamed like heck for daring to share my Source experiences.
Again, I dont have anywhere near as much problem with his parts as his excuses.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: SURPRISE ! 440 Source damper is crap [Re: moparniac] #201426
01/22/09 09:46 PM
01/22/09 09:46 PM
Central Coast
P
P
Central Coast
Re: SURPRISE ! 440 Source damper is crap [Re: Plumcrazyracing] #201427
01/22/09 09:56 PM
01/22/09 09:56 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The SFI thing is an interesting issue. I'm sure SFI is very proud of what the rating means, so maybe send it to them for a re-evaluation. I know from getting things UL approved that the parts tested are sometimes not what gets made after a while though the rating stays the same. Things made far away can be more vulnerable, and it can happen without the company knowing it.
Re: SURPRISE ! 440 Source damper is crap [Re: moparniac] #201428
01/22/09 10:02 PM
01/22/09 10:02 PM
Wichita,KS
Wichita,KS
Well it has been longer than 30 days since I purchased my damper from them. I also purchased my stroker kit,oil pan and main caps from them as well as other small stuff. Guess I am probably screwed on the damper....I havent even finished putting together my 512 yet.
Re: SURPRISE ! 440 Source damper is crap [Re: Blakcharger440] #201429
01/22/09 10:05 PM
01/22/09 10:05 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
If you havent put the motor together, just how are you screwed on the damper? Did it fail??
If someone else had a problem, it doesnt mean that you will.
Re: SURPRISE ! 440 Source damper is crap [Re: 5537SG] #201430
01/22/09 10:26 PM
01/22/09 10:26 PM
NY/NJ
DV8 Offline
mopar addict
DV8  Offline
mopar addict
NY/NJ
...where are the blocks ???...
~S~
"The function of man is to live, not exist..."
Re: SURPRISE ! 440 Source damper is crap [Re: 5537SG] #201431
01/22/09 10:35 PM
01/22/09 10:35 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
IMO ....an item like this should never "fail". How many 35 year old PLUS OEM dampners have you seen be loose? ... or even move ??... I have seen many a Mopar engine and have only seen ONE dampner "move" ..and it was because the guy soaked it in solvent for a couple of days.
I think a part like this should have a lifetime warranty on it.... unless it was physically damaged.
Re: SURPRISE ! 440 Source damper is crap [Re: DaveRS23] #201432
01/22/09 10:43 PM
01/22/09 10:43 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Isn't that there to make sure the part is "safe"? I wonder what would have happened at the track if it came apart? A little kid was killed recently by stray parts from a Monster truck.
Re: SURPRISE ! 440 Source damper is crap [Re: dOc !] #201433
01/22/09 10:46 PM
01/22/09 10:46 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
X1000
Its a shame people are only after a dollar and a sale..... how many times can this happen over and over from part to part.....
I know some have had good success but just as many havnt....... not worth the gamble to me!
I am happy it worked out for some of you though
If I am selling parts I would make sure it was good before they go out...
thats a shame about the kid dying from the monster truck thing...
Mopar Performance
Re: SURPRISE ! 440 Source damper is crap [Re: DV8] #201434
01/22/09 11:05 PM
01/22/09 11:05 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
~S~
SO are they going to make the block
Quote from Brandon at 440Source:
Sorry guys, It's been put on hold for the time being. The factory we were dealing with is used to pouring blocks for major automakers. After we perfected the tooling, they told us there would be a minimum requirement of several thousand blocks, which would require us to put up millions of dollars in investment capitol.
We tried to explain to them that big block Mopars are a "hobby" engine, and no company out there is going to sell these blocks by the thousands. The first shipment alone would have had to be over 3000 blocks. The block "waiting list" which we have been keeping over the last (approx) 2 years has 105 people on it.
Of course we could make the blocks if we doubled the price, but we wanted to keep them around the $1500 level, otherwise, why wouldn't you just go out and buy a World block?
To make a long story short, the consensus is basically that everyone felt it wasnt worth making, at least for the time being. Sorry if this disapoints some people, we have been working really hard on it ourselves, so it really wasn't what we were hoping to hear.
And the comment above about World blocks is correct, they are NOT made in the USA. I'll let you take an educated guess on where they come from.
Re: SURPRISE ! 440 Source damper is crap [Re: DaveRS23] #201435
01/22/09 11:56 PM
01/22/09 11:56 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
My thought is that a 90 day warranty is what you have and you are way way past the warranty. It has been about 19 months since you bought the damper. It is our hobby/passion (so we take it a bit personal) but it is his business. I cannot fault them about this.
Bargain parts are surely not the best but they serve a place in all industries.
I am very glad that you caught the issue.
Damon
Re: SURPRISE ! 440 Source damper is crap [Re: mopardamo] #201436
01/23/09 12:13 AM
01/23/09 12:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Anyone know what the warranty is on a ATI sfi damper?
Page 1 of 3 1 2 3
