Cracked Balancer
#2014038
02/17/16 04:33 PM
02/17/16 04:33 PM
Posts: 368 Jacksonville, Fl
426runner
Jacksonville, Fl
My real question... can this be repaired?
Later, Sandy
'70 HEMI Road Runner B5/B5, 4 spd
"Sandy's Garage" on Facebook
Re: Cracked Balancer
[Re: 426runner]
#2014044
02/17/16 04:38 PM
02/17/16 04:38 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Hmmmm..... would I take a cracked piece of steel weighing about 5 lbs. and spin it up to 7000 rpm a few feet from me? NOPE
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: stumpy]
#2014111
02/17/16 07:05 PM
02/17/16 07:05 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
When you consider the potential for damage, it would be foolish to reuse this part. I think you just dodged a bullet when you found that.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#2014122
02/17/16 07:27 PM
02/17/16 07:27 PM
Posts: 3,391 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Not to mention the pits and the crack will make it hard for the timing cover seal to seal on the snout. You could sleeve it, of course but prob not worth it.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: Morty426]
#2014420
02/18/16 01:58 AM
02/18/16 01:58 AM
Posts: 22,715 Bitopia
jcc
Bitopia
I spoke with "JC" at ATI at the 2015 PRI show about adding a second keyway in a mopar damper. We were looking at one he had on display, he was very concerned about how much "meat" was left for strength if I choose that option, and wanted me to find a larger front seal so he could increase damper oustide snout diameter on a custom damper. I was leary, now, not so much.
[Re: jcc]
#2014540
02/18/16 10:26 AM
02/18/16 10:26 AM
RapidRobert
I wouldn't have an engineering problem with cutting another key way as I dont think there'd even be close to a strength issue there but that'd be unrelated to the current crack situation (as said toss it & definitely Kudos for catching that as most wouldn't as it is such a trouble free/stout piece & unless I am missing something I'd think the only reason to cut another keyway would be to reclock the dampener slit location & considering the time/money to do that (properly) I'd just get another used one as they are pretty much bulletproof (yours is the only bad one I've ever seen unfortunately).
[Re: 68jim]
#2014555
02/18/16 11:11 AM
02/18/16 11:11 AM
426runner
Jacksonville, Fl
Yes, this was on the car.
Later, Sandy
[Re: RapidRobert]
#2015040
02/18/16 11:17 PM
02/18/16 11:17 PM
jcc
Bitopia
I wouldn't have an engineering problem with cutting another key way as I dont think there'd even be close to a strength issue there but that'd be unrelated to the current crack situation (as said toss it & definitely Kudos for catching that as most wouldn't as it is such a trouble free/stout piece & unless I am missing something I'd think the only reason to cut another keyway would be to reclock the dampener slit location & considering the time/money to do that (properly) I'd just get another used one as they are pretty much bulletproof (yours is the only bad one I've ever seen unfortunately). My conversation with ATI centered (pun intended) on my use of a centrifugal supercharger overloading a single OEM keyway. The Op's broke at the keyway as best as I can tell, and is apparently the weak point that ATI was trying to beat into my brain, and it looks like they have seen this before.
[Re: jcc]
#2015052
02/18/16 11:40 PM
02/18/16 11:40 PM
RapidRobert
Yeah in the middle of my reply I knew I was off track/missing something! kinda like way way back when I had a car that you could lock by holding the outside door button that is under the handle in while you are shutting the door only to realize seconds later that the keys are still in the ign! (& a vague thought in the middle of the 3 second event that sumpin ain't right). the gut never lies
