Timken vs. Koyo bearings?
#2013847
02/17/16 12:10 PM
02/17/16 12:10 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
What are your thoughts on the quality of Timken vs. Koyo bearings? Looking at bearing kits for a Dana 60 and there's a pretty big difference in price...Timken being more expensive. Are they worth it?
Re: Timken vs. Koyo bearings?
[Re: an8sec70cuda]
#2013919
02/17/16 02:16 PM
02/17/16 02:16 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
As you might know I'm a 27 year Toyota technician and almost all Toyota transmissions use Koyo bearings and I the only bearing failures I see are from fluid loss or contamination. Toyota trucks use Koyo bearings on their carriers and go 300K without any troubles I use them in my rebuilds without hesitation Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: an8sec70cuda]
#2013935
02/17/16 02:35 PM
02/17/16 02:35 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
What are your thoughts on the quality of Timken vs. Koyo bearings? Looking at bearing kits for a Dana 60 and there's a pretty big difference in price...Timken being more expensive. Are they worth it? I got Timken bearing to use for set up for about $10 ea at Vatozone........
[Re: Thumperdart]
#2013944
02/17/16 02:45 PM
02/17/16 02:45 PM
fourgearsavoy
Rittman Ohio
What are your thoughts on the quality of Timken vs. Koyo bearings? Looking at bearing kits for a Dana 60 and there's a pretty big difference in price...Timken being more expensive. Are they worth it? I got Timken bearing to use for set up for about $10 ea at Vatozone........ I'm pretty sure you didn't get Dana carrier bearings for $10 ea Those don't come cheap by any company Gus
[Re: an8sec70cuda]
#2013954
02/17/16 02:56 PM
02/17/16 02:56 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Chip, FWIW I worked in the bearing industry for 26 years. Years ago I would have said Timken hands down but because of overseas competition Timken now makes all of their small bore bearing overseas as well. With that said KOYO will be fine but I personally would still buy the Timken. lol
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: fourgearsavoy]
#2013961
02/17/16 03:00 PM
02/17/16 03:00 PM
Thumperdart
State of confusion
What are your thoughts on the quality of Timken vs. Koyo bearings? Looking at bearing kits for a Dana 60 and there's a pretty big difference in price...Timken being more expensive. Are they worth it? I got Timken bearing to use for set up for about $10 ea at Vatozone........ I'm pretty sure you didn't get Dana carrier bearings for $10 ea Those don't come cheap by any company Gus True just pinion bearings for my lowly 8 3/4...........
[Re: Thumperdart]
#2014116
02/17/16 07:13 PM
02/17/16 07:13 PM
Posts: 5,161 CT
GTX MATT
CT
What are your thoughts on the quality of Timken vs. Koyo bearings? Looking at bearing kits for a Dana 60 and there's a pretty big difference in price...Timken being more expensive. Are they worth it? I got Timken bearing to use for set up for about $10 ea at Vatozone........ Really? Mine only shows the outer bearing for the 8 3/4 I used a Koyo from a part store when I made my setup bearing last time, it was a mistake on my part. When I pressed the Timken on it was slightly different depth, didn't kill the pattern, but went from a perfect pattern to a just OK pattern. The Koyo has less rollers in it. So I need to get a Timken this time, and rehone (PITA)
[Re: Hot 340]
#2014154
02/17/16 08:04 PM
02/17/16 08:04 PM
Posts: 3,395 Pa
Hot 340
Pa
[Re: GTX MATT]
#2014163
02/17/16 08:11 PM
02/17/16 08:11 PM
Posts: 6,389 Abilene, Texas
fastmark
Abilene, Texas
What are your thoughts on the quality of Timken vs. Koyo bearings? Looking at bearing kits for a Dana 60 and there's a pretty big difference in price...Timken being more expensive. Are they worth it? I got Timken bearing to use for set up for about $10 ea at Vatozone........ Really? Mine only shows the outer bearing for the 8 3/4 I used a Koyo from a part store when I made my setup bearing last time, it was a mistake on my part. When I pressed the Timken on it was slightly different depth, didn't kill the pattern, but went from a perfect pattern to a just OK pattern. The Koyo has less rollers in it. So I need to get a Timken this time, and rehone (PITA) Well I just did this setup. I honed an older Timken bearing, installed it, and measured my depth. I then pressed on a newer Timken bearing and it was .003 deeper in the case. The pattern was still ok so I installed it.
[Re: GTX MATT]
#2014171
02/17/16 08:22 PM
02/17/16 08:22 PM
Thumperdart
State of confusion
What are your thoughts on the quality of Timken vs. Koyo bearings? Looking at bearing kits for a Dana 60 and there's a pretty big difference in price...Timken being more expensive. Are they worth it? I got Timken bearing to use for set up for about $10 ea at Vatozone........ Really? Mine only shows the outer bearing for the 8 3/4 I used a Koyo from a part store when I made my setup bearing last time, it was a mistake on my part. When I pressed the Timken on it was slightly different depth, didn't kill the pattern, but went from a perfect pattern to a just OK pattern. The Koyo has less rollers in it. So I need to get a Timken this time, and rehone (PITA) Part # M804049......Inner..........
[Re: an8sec70cuda]
#2014258
02/17/16 10:41 PM
02/17/16 10:41 PM
Posts: 12,019 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The last Timkens that I bought were made in Eastern Europe.
Master, again and still
[Re: 71birdJ68]
#2014261
02/17/16 10:44 PM
02/17/16 10:44 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
Timken use to offer a lot of thier Timken tapered roller wheel bearings in many different quality of bearings with the same part number except the suffix. I complained once about the price of a set of wheel bearings on my small single engine airplane when I had the fisrt annual inspection done on it, the shop charged me around $38.00 for the bearing and race, the same part number at the local auto parts store was $8.00 The auto parts bearing had a A suffix and the airplane bearing had a G suffix on it The FBO shop mechanix explianed the difference was in how close the tolerances where between the two, .0010 compared to .0001 That airplane took off and landed at 85 MPH + and the tires where very small in diameter so the wheel bearings on landing would go from a dead stop to real fast in a very short period of time I put a bunch of time in that airplane, 1100+ hours and a lot of take offs and landings in that time and never had another wheel bearing failure after the first annual, I did remove and repack them every 100 hours per the factory recommended servicing That airplane had sat in northern CA for in a hangar 18 months on the north end of San Fransisco bay area for 18 months before I bought it so the salty air moisture content up there may have cause the pitting on the bearings and races I now buy the recommended bearings from the manufacture for that specific application
[Re: an8sec70cuda]
#2014267
02/17/16 10:53 PM
02/17/16 10:53 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Chip, I've seen issues with Koyo bearings in the transmissions in the dealership. I'm sure Chrysler's policy of "The cheapest bidder" has something to do with it, but I would still feel better with Timken. Like you, and all of the Moparts people have told me, after all of the investment that has been made into our toys, are you going to cheap out now for a set of axle bearings?
[image][/image]
[Re: Hot 340]
#2014314
02/17/16 11:49 PM
02/17/16 11:49 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
That one sold me, I need carrier bearings for my aam axle and koyo are 1/2 the price.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: an8sec70cuda]
#2014365
02/18/16 12:55 AM
02/18/16 12:55 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
My last set of Timken 387 carrier bearings said made in the USA. try amazon
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
