Re: tunnel ram users can i get your advise
[Re: ProSport]
#2013319
02/16/16 06:57 PM
02/16/16 06:57 PM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
Yeah, that sure is true. My 8 gallon fuel cell used to last through 3 time runs and 3 rounds of racing. Now I'm filling it up after warm up and time runs.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: mopar dave]
#2013324
02/16/16 06:57 PM
02/16/16 06:57 PM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
Yea it got kind of annoying lol, but I loved that TR!
[Re: mopar dave]
#2013326
02/16/16 07:00 PM
02/16/16 07:00 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I ran a tunnel ram on the street with a matched set of 750 dp's with no problems except spark plugs fouling probably due to low RPM's. On the track they worked great
[Re: mopar dave]
#2013374
02/16/16 08:14 PM
02/16/16 08:14 PM
Posts: 4,219 New York
polyspheric
New York
Bill Jenkins (if anyone but me remembers the fastest small block engines on the planet at the time?) remarked 40 years ago that the carburetors and plenum volume that produced the highest steady-state power on the dyno are at least 10% too big for best acceleration.
Boffin Emeritus
[Re: mopar dave]
#2013415
02/16/16 09:08 PM
02/16/16 09:08 PM
ProSport
Akron, Ohio
You'll be happy with 750 double pumpers. I don't know how necessary it is, but my Quickfuel carbs were custom calibrated for a TR and had wedge shaped floats for a TR with sideways mounted carbs. They were pretty much spot-on right out of the box.
[Re: ProSport]
#2013478
02/16/16 10:27 PM
02/16/16 10:27 PM
Posts: 12,478 Taxes & Virus's R-US, NY
Dragula
You'll be happy with 750 double pumpers. I don't know how necessary it is, but my Quickfuel carbs were custom calibrated for a TR and had wedge shaped floats for a TR with sideways mounted carbs. They were pretty much spot-on right out of the box. I have had very good luck with custom QF carbs over the years. ALthough, they are under new ownership now correct? I have not bought one since the change, but I would be curious to know. I still use a lot of they're parts over Holley stuff.
[Re: mopar dave]
#2013506
02/16/16 10:56 PM
02/16/16 10:56 PM
ProSport
Akron, Ohio
Cool! Do you know what qf put in them for IFR and main jets? Square jetted or PV out of the box? I no longer own the car, I know I ran them square jetted with no power valves but I can't remember if they came that way. I'll try to see if new owner still has the build sheets for the carbs. I'm sure he'll know what jets are in them. Dragula, I did not know Quickfuel was under new ownership. I wonder if some of the guys stayed.?
[Re: mopar dave]
#2013762
02/17/16 05:52 AM
02/17/16 05:52 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Just put a pair of 950 TRE carbs on my 528 street strip Cuda and Love it, still have some bugs but picked up about 40hp over dominator and went 608 rwhp. Did have a little trouble starting it but I turned off the start retard so it's all in 34deg and now fires up great, I would also say it feels better on the street. Go for it.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: mopar dave]
#2013862
02/17/16 12:42 PM
02/17/16 12:42 PM
Posts: 5,173 CT
GTX MATT
CT
Many racers out there that like their 660's. I asked Mark about them and he didn't have much to say. Besides the center squirter and straight boosters what makes them so different or better than a 650dp? I believe it is simply that they are well calibrated to a tunnel ram OOTB, and the 1:1 linkage works well for fuel distribution
[Re: mopar dave]
#2013882
02/17/16 01:12 PM
02/17/16 01:12 PM
polyspheric
New York
Once you say "no power valves, no vacuum advance", a question about mileage is pointless.
Boffin Emeritus
[Re: polyspheric]
#2013931
02/17/16 02:32 PM
02/17/16 02:32 PM
Posts: 8,075 Mt Morris Michigan
mopar dave
Mt Morris Michigan
oh, these will have pv when street driven and square jetted while at the track.
