Page 1 of 4 1 2 3 4
Mopar 337 intake info and pics here. #2012801
02/15/16 11:23 PM
02/15/16 11:23 PM
North Dakota
Azzkikrcuda Offline OP
North Dakota
Not alot of info out there on this intake, I got one and compared it to my M1 RB 4150 single plane and thought I would post the info. The 337 is a 4150 flange single plane for RB with Max wedge sized ports with a cast in valley pan. While it is billed as Max Wedge size ports they are far undersize. This should allow them to be used on std. port heads with some port work. It it shorter then the std. M1 intake and is around $260.
The only Carbs I care about are under the hood!
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2012803
02/15/16 11:24 PM
02/15/16 11:24 PM
North Dakota
North Dakota
As cast port sizes, Max Wedge should be around 2.63 x 1.35
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2012804
02/15/16 11:25 PM
02/15/16 11:25 PM
North Dakota
North Dakota
Std. gasket
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2012805
02/15/16 11:26 PM
02/15/16 11:26 PM
North Dakota
North Dakota
It is about 1/4 shorter at front and 3/8 shorter at the rear of the carb flange.
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2012806
02/15/16 11:26 PM
02/15/16 11:26 PM
North Dakota
North Dakota
Carb flange is straight not tilted like the Std. M1
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2012807
02/15/16 11:27 PM
02/15/16 11:27 PM
North Dakota
North Dakota
Plenum
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2012808
02/15/16 11:27 PM
02/15/16 11:27 PM
North Dakota
North Dakota
Std. M1 plenum
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2012809
02/15/16 11:28 PM
02/15/16 11:28 PM
North Dakota
North Dakota
Rough measurement of how much the intake ports on a Std. port Trick Flow head will need to be opened up to work with this intake. To the outside of the markings, Should be around a 2.47 x 1.32 port opening.
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2012845
02/16/16 12:15 AM
02/16/16 12:15 AM
AndyF Offline
AndyF  Offline
The 337 is a really good intake. It solves a problem that no other intake solves and it works a lot better than it looks. I made 800 hp with that intake on my old 505. That was out of the box, I'm sure it would've picked up another 25 hp or more if it had been port matched.
http://www.hotrod.com/how-to/engine/mopp-1206-project-505-the-final-chapter/
Re: Mopar 337 intake info and pics here. [Re: AndyF] #2012902
02/16/16 01:34 AM
02/16/16 01:34 AM
Weddington, N.C.
Streetwize Online content
Streetwize  Online Content
Weddington, N.C.
I have a ported 337 on my 517, works great
WIZE
In Car:
Re: Mopar 337 intake info and pics here. [Re: Streetwize] #2012908
02/16/16 01:46 AM
02/16/16 01:46 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Is this intake available again?
I thought it was unobtainable a few months back... shruggy
Re: Mopar 337 intake info and pics here. [Re: GY3] #2012920
02/16/16 02:02 AM
02/16/16 02:02 AM
North Dakota
North Dakota
I just got this one last week from my local Mopar dealer. Summit and Jegs showed it on back order. I had it in 3 days from the dealer and they said there were 3 more left in the system at that time.
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2012925
02/16/16 02:11 AM
02/16/16 02:11 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Interesting info & pics.
It would probably take some serious grinding and Belzona to make a '337' work for me, but it looks cool.
Re: Mopar 337 intake info and pics here. [Re: BradH] #2012940
02/16/16 02:26 AM
02/16/16 02:26 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
It is one of the best BB intakes made
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2013061
02/16/16 12:46 PM
02/16/16 12:46 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
It's one of the best intakes no one uses. I have one on a 440 with MW Performers and it runs great. Good price and the built in valley tray is a big plus.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Mopar 337 intake info and pics here. [Re: d7cook] #2013076
02/16/16 01:01 PM
02/16/16 01:01 PM
Weddington, N.C.
Weddington, N.C.
It also makes for a nice fit on a Low Deck with Stage VI heads
WIZE
In Car:
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2013115
02/16/16 02:14 PM
02/16/16 02:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I wonder if the TF heads would pick up any flow by making them the size of that manifold.
There is certainly plenty of meat on the head to go that big(or even out to full MW size).
Re: Mopar 337 intake info and pics here. [Re: BradH] #2013121
02/16/16 02:18 PM
02/16/16 02:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
Mmmmmmm, not so much I think.
The bigger question in my mind would be, how well does it work on a 440-470ci street strip combo?
493+ I'm sure it's good...... Might be a tad big on a 440-470(depending on the rest of the combo of course).
Re: Mopar 337 intake info and pics here. [Re: fast68plymouth] #2013127
02/16/16 02:26 PM
02/16/16 02:26 PM
Weddington, N.C.
Weddington, N.C.
I had commented before that as delivered the ports are about 1/2 way between 906 and true Max Wedge, I really think they did this on purpose ( or maybe, knowing Ma MoPar) probably more a 'fortunate accident'....for a change.
What's key to this manifold is the awesome taper ratio from the plenum to the port, great for Horsepower although lower end torque may be down a tad vs say a traditional M1 off idle on a 440-470" motor.
WIZE
In Car:
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2013131
02/16/16 02:29 PM
02/16/16 02:29 PM
So. Burlington, Vt.
So. Burlington, Vt.
I'd love to see someone try it.
It's a little unsightly with the extra bosses and such on it too......I'd have to trim that stuff off if I were going to actually run it in my car.
Page 1 of 4 1 2 3 4
