How big can you comfortably bore a LA 360 Block?
#2010085
02/11/16 08:35 PM
02/11/16 08:35 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have been storing some engine cores that I have acquired in the "dirty side" of my shop and yesterday I finally opened up the LA 360 truck motor that I have had for a couple of years. I was told it was rebuilt and it has to be because at least one of the pistons is marked .040. The bores are smooth with almost no ridge with the exception of one and there is some pitting in the top of that bore about 1.5" down, so I am guessing it may require a bore but I may be able to get by with honing, particularly if I go with a forged piston.
The object of this exercise is replace the existing LA 318 in my daily driver with a fresh engine and more power. I also have a LA 318 pass core that I know is original and I could use that block with the "974" 360 cylinder heads if they are not cracked for better breathing.
I did the same kind of a swap years ago in a '74 D 100 with a 360, a new truck pan and a B&M flex plate so it is nothing new, but that motor was a virgin and I put .030 cast pistons in it.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: How big can you comfortably bore a LA 360 Block?
[Re: Polarapete]
#2010203
02/11/16 11:21 PM
02/11/16 11:21 PM
RapidRobert
If I was boring to 60 I'd likely be on the safe side & sonic check it esp as you are going to subject it to some spirited driving. If just honing out for forged I'd likely go as is (if it will clean up).
[Re: Paul_Fancsali]
#2010603
02/12/16 06:13 PM
02/12/16 06:13 PM
Polarapete
Graham, WA
I have been doing some reading in the Mopar Engine bible for another issue and found that the '76 and earlier 360 can be bored to .060 as they used the 340 casting molds, but the '77 and later 360s used a lighter weight casting. So I may be good to go with this block and because it came with the truck pan it was a good buy at $100.00 for the long block. Now I just hope the "974" heads are salvageable...or I will turn in my winning $5.00 Mega Millions ticket for another winner and go nuts on this build.
[Re: Polarapete]
#2010878
02/13/16 12:47 AM
02/13/16 12:47 AM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
The motor I used to have in my Duster was a 360 that was bored +0.040 over already and had some wear.
I was picking up my 340 from Mike at MRL Performance and casually mentioned that I thought my old block was just a scrap heap junker being a 1977 model block and being +0.040" already.
He didn't seem phased so after I pulled it, he bought the block from me. Turns out after sonic checking it was plenty thick to go 0.060" over so they did so and the engine made 420hp. So get it sonic checked.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: Polarapete]
#2012453
02/15/16 02:50 PM
02/15/16 02:50 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
The books don't take into account the cruddy casting that was done and for the most part those are myths that have been debunked over time. Core shift which can limit the bore thickness ALL blocks should be sonic tested if you are going to non-factory strokes or they are going beyond .030 over. It would stink to have the work done and have a problem with your result because you failed to drop the extra coin on a sonic test. If you had one at .040, I'd either not sweat the pits, ridge ream it, and run it or get another one that's std bore. They are very plentiful and fairly cheap - even in Magnum form where you can use the roller cams in them.
