Re: Done with Champion plugs
[Re: Hyper Henry]
#2011155
02/13/16 04:27 PM
02/13/16 04:27 PM
dartman366
Mt. Vernon, Ohio
I have run Autolites for years, even the one's made in mehico with excellent results, switched to NGK's a couple of years ago and have just as good of results with them, standard Champion's used to be a good plug but seem to have gone down hill a number of years ago, I ran the Champion racing plug for a while and had sucess with them too but they are harder to find around here, so I went back to Autolites.
[Re: Hyper Henry]
#2011277
02/13/16 07:29 PM
02/13/16 07:29 PM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
I have had less than stellar luck with Champions and Autolites. On 2 different occasions I put a new set of Autolites in a car I'd owned and the engine had a miss immediately afterward. Put the old plugs in and it cleared up.
I've never had bad luck with NGK's, in everything from race cars to lawn equipment.
[Re: Hyper Henry]
#2011321
02/13/16 08:45 PM
02/13/16 08:45 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I would correct the air fuel ratio first, jetting or fuel map, to stop the plug fouling first and go from there I've used all three brands of spark plugs with good results with all of them On your deal with Autolites on the street I would start with Auolite # 3924 resitor plugs or thier # 3911 non resitor race plugs IHTHs
[Re: Cab_Burge]
#2011336
02/13/16 09:12 PM
02/13/16 09:12 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I run Denso plugs in my engine. I had my heads out on the bench at work and had a Tundra in my rack getting a tune up. So I screwed on of the Denso Iridium plugs from the Tundra into my Indy head and they looked good in the chamber. So I snagged a set out of parts just to break in my 493 and surprise!!! they are still in there after about 6 years. They don't foul and never miss a beat EVER!!! I'll never use another brand plug in my engine.Been using Denso plugs in all my engines since I've been an import technician Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Hyper Henry]
#2011438
02/13/16 11:34 PM
02/13/16 11:34 PM
Cab_Burge
# 3924 for the street car, 3911 or maybe 3910 for the race car Try the 3911 first and go from there Summit stocks and sells them also
