Page 1 of 3 1 2 3
Done with Champion plugs #2011117
02/13/16 03:22 PM
02/13/16 03:22 PM
Ontario, Canada
Hyper Henry Offline OP
Ontario, Canada
Use to run NGK's in my street and race car stuff years ago but went to Champion with my new stuff because that's what Edelbrock and 440 Source recommended for their heads but they just seem to foul way too easy!!
Both my combos run on pump gas and both around 11.0 comp. race motor is a 500 ci with CNC'd Eddy heads, roller cam and tunnel ram, street motor is 448 ci with ported Stealth's, solid cam and EFI.
What do you guys recommend besides Champion RC9YC and RC12YC.
Re: Done with Champion plugs [Re: Hyper Henry] #2011153
02/13/16 04:25 PM
02/13/16 04:25 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Went to Autolite after many years of NGK...
And after many conversations...
(Heard not so good things about NGK quality control...
Improved things about Autolite quality control...)
Champion out of the question...
First time ever running Autolite...
We'll see what happens...
Re: Done with Champion plugs [Re: Hyper Henry] #2011155
02/13/16 04:27 PM
02/13/16 04:27 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I have run Autolites for years, even the one's made in mehico with excellent results, switched to NGK's a couple of years ago and have just as good of results with them, standard Champion's used to be a good plug but seem to have gone down hill a number of years ago, I ran the Champion racing plug for a while and had sucess with them too but they are harder to find around here, so I went back to Autolites.
Re: Done with Champion plugs [Re: Hyper Henry] #2011197
02/13/16 05:24 PM
02/13/16 05:24 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Auto lite for last 10 yes on big blocks. Never an issue. Hated champions
Re: Done with Champion plugs [Re: Hyper Henry] #2011204
02/13/16 05:37 PM
02/13/16 05:37 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
using autolites in my edelbrock heads. cheap, easy to find and burn clean.
Re: Done with Champion plugs [Re: Hyper Henry] #2011223
02/13/16 06:12 PM
02/13/16 06:12 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What ignition?
Re: Done with Champion plugs [Re: Hyper Henry] #2011224
02/13/16 06:19 PM
02/13/16 06:19 PM
AndyF Offline
AndyF  Offline
Well if you like NGK then use a NGK plug. Probably want a heat range of 7 in the race motor and 6 on the street engine.
Re: Done with Champion plugs [Re: Hyper Henry] #2011277
02/13/16 07:29 PM
02/13/16 07:29 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I have had less than stellar luck with Champions and Autolites. On 2 different occasions I put a new set of Autolites in a car I'd owned and the engine had a miss immediately afterward. Put the old plugs in and it cleared up.
I've never had bad luck with NGK's, in everything from race cars to lawn equipment.
Re: Done with Champion plugs [Re: Hyper Henry] #2011281
02/13/16 07:36 PM
02/13/16 07:36 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Champions have always seemed weak for me
Re: Done with Champion plugs [Re: Hyper Henry] #2011282
02/13/16 07:40 PM
02/13/16 07:40 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Whenever I find Champion plugs in an engine/car I just bought, they always leave the area with a nice large parabolic curve.
Re: Done with Champion plugs [Re: Hyper Henry] #2011297
02/13/16 08:11 PM
02/13/16 08:11 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
autolites on both cars, one has indy heads, and other has 440 source heads. 0 issues and i run the cars rich as [censored].
Re: Done with Champion plugs [Re: Hyper Henry] #2011321
02/13/16 08:45 PM
02/13/16 08:45 PM
I would correct the air fuel ratio first, jetting or fuel map, to stop the plug fouling first and go from there up I've used all three brands of spark plugs with good results with all of them shruggy On your deal with Autolites on the street I would start with Auolite # 3924 resitor plugs or thier # 3911 non resitor race plugs twocents IHTHs
Re: Done with Champion plugs [Re: Hyper Henry] #2011335
02/13/16 09:09 PM
02/13/16 09:09 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Champions may or may not be better or worse than others. But in my mind; if you're fouling plugs, you have tune issues.
twocents
Re: Done with Champion plugs [Re: Cab_Burge] #2011336
02/13/16 09:12 PM
02/13/16 09:12 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I run Denso plugs in my engine. I had my heads out on the bench at work and had a Tundra in my rack getting a tune up. So I screwed on of the Denso Iridium plugs from the Tundra into my Indy head and they looked good in the chamber. So I snagged a set out of parts just to break in my 493 and surprise!!! they are still in there after about 6 years. They don't foul and never miss a beat EVER!!!
I'll never use another brand plug in my engine.Been using Denso plugs in all my engines since I've been an import technician twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Done with Champion plugs [Re: FastmOp] #2011404
02/13/16 10:42 PM
02/13/16 10:42 PM
Ontario, Canada
Ontario, Canada
Originally Posted By FastmOp
What ignition?
Race car has MSD dist, MSD HVC II coil, MSD wires and MSD 7AL2, street car has MSD dist, Mallory coil, MSD wires and 6AL2.
Re: Done with Champion plugs [Re: Hyper Henry] #2011408
02/13/16 10:47 PM
02/13/16 10:47 PM
Ontario, Canada
Ontario, Canada
Sounds like Autolites is what the majority are happy with. Can someone supply me with the part #'s I should use in my race car and street car please. If I don't have full part # for the kid behind the counter I might as well be asking for a fart can muffler for a tuner car!!...:o)
Re: Done with Champion plugs [Re: Hyper Henry] #2011430
02/13/16 11:25 PM
02/13/16 11:25 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Ive never had any issues with the Champion Race cut back plugs, C59 CX I think? Most misfire problems are either too rich, or to cold of a plug for the conditions.
Re: Done with Champion plugs [Re: Hyper Henry] #2011431
02/13/16 11:26 PM
02/13/16 11:26 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
if memory serves, i run the autolite 3923, and 3924's, one car is 10.15 compression, other is 10.9, both are street/track cars, never foul plugs.
Re: Done with Champion plugs [Re: Hyper Henry] #2011438
02/13/16 11:34 PM
02/13/16 11:34 PM
# 3924 for the street car, 3911 or maybe 3910 for the race car up twocents Try the 3911 first and go from there scope Summit stocks and sells them also work
Re: Done with Champion plugs [Re: Cab_Burge] #2011487
02/14/16 12:30 AM
02/14/16 12:30 AM
dogdays Offline
dogdays  Offline
AC plugs, anyone for AC? They seemed on par with the Autolites, better than the Champions in my oil burner a couple years ago.
Iridium for my street car, I just took out a set with 115K on them. Replaced with NGK Iridium TT.
R.
Page 1 of 3 1 2 3
