Anyone buy stroker crate motor at Indy cylinder Head #201092
01/22/09 03:27 PM
01/22/09 03:27 PM
fl &TN
track pak Offline OP
fl &TN
Anyone buy crate motor from Indy cylinder Head .Thinking about buying 500' stroker engine from these guys Any feedback or thoughts would be great. 500 street wedge Ez-1 heads 9.5 to 1 compression comp hydraulic cam (.509)Sw Indy dual plane intake 750 demon carb wiseco piston steel crank eagle rods. They clam this is 600 hp but i have been told that this is not a good cam that does come alive till 3,000 rmp really want a cam that lopes hard at idle power down low with out a lot of gear Any input on indys quality and service would be very helpful. Were can you find the engine guys on here ? Is there any other mopar only engine builder they would recommend that does great crate motors with this combo? Thanks a ton
Re: Anyone buystroker crate motor at Indy cylinder Head [Re: track pak] #201093
01/22/09 03:50 PM
01/22/09 03:50 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I would talk to one of the engine guys on this board about building one before buy an engine from Indy.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Post deleted by Defbob [Re: Dap] #201094
01/22/09 04:07 PM
01/22/09 04:07 PM
Re: Anyone buystroker crate motor at Indy cylinder Head #201095
01/22/09 04:20 PM
01/22/09 04:20 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I bought a Hemi from them and still feel the pain.
there are members here like BG Racing and a few others that will give you what you pay for with no pain involved
Yeah I gave you what you wanted and have felt the pain ever since.When does it stop hurting?
Re: Anyone buystroker crate motor at Indy cylinder Head [Re: B G Racing] #201096
01/22/09 04:31 PM
01/22/09 04:31 PM
Illinois
colt340 Offline
colt340  Offline
Illinois
Good one!
Post deleted by Defbob [Re: B G Racing] #201097
01/22/09 04:37 PM
01/22/09 04:37 PM
Re: Anyone buy stroker crate motor at Indy cylinder Head [Re: track pak] #201098
01/22/09 04:38 PM
01/22/09 04:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Call Chuck or Pete at Best Machine, they're both
big Mopar guys and can take good care of your needs.
Their web page is in my sig... great guys to deal with
plus they're members here on the board
Re: Anyone buy stroker crate motor at Indy cylinder Head [Re: MR_P_BODY] #201099
01/22/09 04:45 PM
01/22/09 04:45 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
given your locations listed (TN and FL) I'd talk to Hensley in knoxville TN or Performance only (DRAM) he's somewhere down in florida.
2017 Grand Cherokee Overland
Re: Anyone buy stroker crate motor at Indy cylinder Head [Re: patrick] #201100
01/22/09 05:28 PM
01/22/09 05:28 PM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
I would have to agree. I am currently dealing with Indy issues and have no good words for them. So i will stop there.
Have heard good things about Hensley and Koffels
Re: Anyone buy stroker crate motor at Indy cylinder Head [Re: Plumcrazyracing] #201101
01/22/09 06:29 PM
01/22/09 06:29 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
call Mike or Eric at Muscle Motors
can't go wrong great to deal with and something Indy doesn't have customer service !!
I get all my parts from them
Re: Anyone buy stroker crate motor at Indy cylinder Hea [Re: MOPARCHAS] #201102
01/22/09 07:34 PM
01/22/09 07:34 PM
Indiana
79_W200 Offline
79_W200  Offline
Indiana
i bought a 470 kit & block and a set of areo heads and it worked great for me i delt with Sam i believe and his cust. service was every thing i expected just my
1979 W200 470
Re: Anyone buy stroker crate motor at Indy cylinder Head [Re: MOPARCHAS] #201103
01/22/09 07:36 PM
01/22/09 07:36 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Go ahead and get your Indy motor, get a GER converter, a TF with a stock drum, an 8-3/4 rear end with 0 degrees pinion angle, paint your engine compartment black, order some parts from Laysons and you'll be set.
If you have any problems, member Quicktree is down in FL and will help you out.
Re: Anyone buy stroker crate motor at Indy cylinder Head [Re: cgall] #201104
01/22/09 07:58 PM
01/22/09 07:58 PM
fl &TN
fl &TN
Yeah is that how you guys do it up in Ohio ? This MOPARTS NOT BOWTIES!! Keep those engine bays black!!!!! Bowtie Thanks for the useless info and direction
Re: Anyone buy stroker crate motor at Indy cylinder Hea [Re: 79_W200] #201105
01/22/09 08:08 PM
01/22/09 08:08 PM
Central Coast
P
P
Central Coast
Yes indeed, Sam is an excellent customer service addition to Indy. He has been very "friendly" to me as well. However, when you have cracked valve guide bosses, weak spring pressure, too much valve run out at the seat and Sam's boss (Russ, or Jim) get on the telephone and tell you that "All you guys think you're building prostock motors" you'll feel my pain. I was told "all these heads have cracks" referring to the valve guide boss/spring locator. Indy refused to even let me send the heads back (on their dime) to have them check the heads themselves.
I am currently having a complete valve job and the guides replaced and moving on. But Indy will not get any more business from me.
I know this is not the place for negative experience chatter, but i do believe it is important for one to be aware of consumer problems.
I truly hope that the issues i have had are not carried over to other customers.
Re: Anyone buy stroker crate motor at Indy cylinder Head [Re: track pak] #201106
01/22/09 08:09 PM
01/22/09 08:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
don't pay him no mind he's from ohio what do you expect the rest of the guys have good info.
Re: Anyone buy stroker crate motor at Indy cylinder Hea [Re: Plumcrazyracing] #201107
01/22/09 08:11 PM
01/22/09 08:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It`s ok just say it...........they are a couple of ego headed, self richeous grumpy dillweeds.......too much time on yellowbullet will do it to ya.
Re: Anyone buy stroker crate motor at Indy cylinder Hea [Re: Thumperdart] #201108
01/22/09 08:45 PM
01/22/09 08:45 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I for one am grateful Indy is there. They have made more performance parts for Mopars than any other company including Mopar and most of us have an indy part or two .
HOWEVER, I really think they're better used as a PARTS supplier with YOUR machine shop of choice doing AlL the machine processes to ALL the parts. Those guys up their are more than capable of doing everything right, but I really don't think they're going to be very personally picky about everything that goes out the door, if for no other reason than being too busy with parts sales. Sam is very nice and they need a guy like him. The old guys are salty and I'm sure quite completely burned out with dealing with those "pesky" customers.
Re: Anyone buy stroker crate motor at Indy cylinder Hea [Re: dthemi] #201109
01/22/09 08:52 PM
01/22/09 08:52 PM
Central Coast
P
P
Central Coast
Well said!
Re: Anyone buy stroker crate motor at Indy cylinder Hea [Re: Plumcrazyracing] #201110
01/22/09 10:44 PM
01/22/09 10:44 PM
.........However, when you have cracked valve guide bosses, weak spring pressure, too much valve run out at the seat and Sam's boss (Russ, or Jim) get on the telephone and tell you that "All you guys think you're building prostock motors" you'll feel my pain. I was told "all these heads have cracks" referring to the valve guide boss/spring locator. Indy refused to even let me send the heads back (on their dime) to have them check the heads themselves.
I went through that EXACT same scenario about two years ago and haven't dealt with them since......
I agree that they do have good parts, but their machine work and customer service is terrible though......
Re: Anyone buy stroker crate motor at Indy cylinder Hea #201111
01/22/09 10:53 PM
01/22/09 10:53 PM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
I would be skeptical of ANY crate engine. There are some here that suggest that YOU THE CUSTOMER should check everything before using ...so why pay someone to assemble it in the first-place ?
