Re: BFG TA
[Re: Grizzly]
#2010909
02/13/16 02:04 AM
02/13/16 02:04 AM
Posts: 1,915 central P.A.
HEMIDOG 70
central P.A.
Sxrxrnr: Agree with you. Have several sets of T/A's and just the odd one will discolor. But, won't run anything but BF's. x3 My bfg ta 235-60-15 letters are turning brown the one tire in particular. I have used sos soap pads,bleach white and even a little solvent on a rag just on the letters. Nothing gets them back to a true white color. They are better after cleaning but still stained. The letters on my 275-60-15's on the rear are much better. Anyone use the white tire pens do they work and look ok?
Re: BFG TA
[Re: Dons Dart]
#2069189
05/08/16 07:59 AM
05/08/16 07:59 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
My recently installed under warranty third set of TA's have now turned brown and look horrible.
I was at a event 2 weeks ago and saw a Roadrunner with TA's that had very nice raised letters. I asked the owner how old the tires. He's said 9 years old. I did note that the lettering was quite a bit more raised from the tire body than is on my tires.
At anothe event today at a very well known local high quality restoration shop. There was a 69 Camaro parked outside that looked as it had been recently dragged out of a lake. Had TA's on it that looked 20 years old. However the letters were white as a sheet and likely not cleaned for years. Took some photos.
I had scrubbed my tires with Bleache Wite, Simple Green and SOS Pads yesterday, the best that I could do is this sickly yellow. Note in the photos the whiteness of the likely non-scrubbed old tires on the Camaro.
As I suggest in earlier postings above,,,this staining is caused by the oils in the tire carcass bleeding up thru the lettering by osmotic action. . Where BF Goodrich, now owned by Michelin is screwing up is the mystery.
Still suspect a Coker connection on TA's as an answer. I have forwarded a link to this post to Coker to find if they have any thoughts on cause.
Note: Remain uncertain if they have any relationship to TA's. Michelin has been who I contact for warranty services. If nothing else perhaps Coker can suggest what is causing the issues. Michelin has been cooperative in warranty replacement of tires. Replacement tires start out as somewhat white but in short time they too are again stained badly.
Anyone with MT or Cooper rwl tires, how are they doing? I believe both versions are made by Cooper.
Was wondering if anyone manufacturing so called "stick on" white lettering is yet selling a kit to specifically improve the appearance of TA's to resolve this issue.
Plan to place a call to Tire Rack to find if they can shed any information with on issue and their experience. Perhaps build dates, build factories, tire sizes, warranty claims, any other information
Re: BFG TA
[Re: dvw]
#2069211
05/08/16 10:04 AM
05/08/16 10:04 AM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
I HATE 17", 18", 20" on older cars, puke ,yuck, ugly Doug Amen!!!!!
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: BFG TA
[Re: Dons Dart]
#2069316
05/08/16 01:15 PM
05/08/16 01:15 PM
Posts: 6,033 Salem
Grizzly
Moparts Proctologist
Salem
Someone needs to petition Michelin to re-design the t/a. A more modern tread pattern and 140mph speed rating.
Or, just bring back the Comp t/a
Mo' Farts
Moderated by "tbagger".
Re: BFG TA
[Re: Sxrxrnr]
#2069347
05/08/16 01:58 PM
05/08/16 01:58 PM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
Some people pay extra for that pateana, Roger.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: BFG TA
[Re: DAYCLONA]
#2074697
05/16/16 07:58 PM
05/16/16 07:58 PM
Sxrxrnr
Northern Calyfornua
BFG discontinued most of the 14-15 inch line, any tires made now are from Coker, they bought the trademark/license to produce them
The largest 14 BFG is the 245-60-14 Jegs has them for $130 each pn# 131-96965
I emailed Coker a copy of this thread along with a bit of commentary. They responded by suggesting that I was not cleaning properly or perhaps that the manufacturer had changed the formula of the ingredients of the tire. They denied that they are the manufacturer, that they just sell them. I now have called Michelin Customer Relations. After a rather lengthy conversation with some direct questions of the agent I spoke with, I did obtain agreement that Michelin had sold the molds to Coker for "certain sizes" and that they are building the tires as Dayclona has suggested. This explains a lot in my opinion. Enough said for now on that. I asked the Michelin agent regarding my sizes of 275-60-15 and 255-60-15's. She said she did not have a record of the sizes that Michelin had turned over to Coker. After more pressing for whom would know this answer, she then requested that I read the 'DOT' code off the tires in question. I provided these codes to her and she said she would do research and get back to me. I also asked that she query engineering or marketing staff to find what they may know that is not public knowledge of what is at the root of this problem. It is very likely that there are those in the know at Coker and/or Michelin that is not being disclosed of what the problems are and whether corrective action will be taken. I sensed a certain reticence in this entire conversation. I also called Tire Rack sales and marketing. Their agent says he has not heard of any such problems. Be aware that if you have a warranty issue on a Tire Rack purchase according to the agent I spoke with, to get a replacement tire, you must send them your old tire(s) to gain a warranty replacement. That could prove very expensive in shipping, dismounting, mounting etc. and highly inconvenient. Perhaps this only applies to cosmetic issues,,,,which now Michelin has told me that their warranty does not cover,,,even though they have replaced my tires twice now at modest charge one time and no cost the second time. A search of the web, I find a number of hits on radial TA lettering turning brown. All fixes basically suggest trying different chemicals to clean,,,just as I have found on this thread. The issue is beyond improper cleaning. Ask some questions and do your homework before paying your money to buy these tires.
Re: BFG TA
[Re: Dons Dart]
#2074751
05/16/16 09:56 PM
05/16/16 09:56 PM
Posts: 819 Eugene, Oregon
Secret Chimp
Eugene, Oregon
BFG T/As are terrible tires by today's standards. There is absolutely no reason to buy them unless you really want raised lettering. The number of guys rolling around on hard-as-a-rock tires they bought half a decade ago or more because the letters still look cool is scary too.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: BFG TA
[Re: Dons Dart]
#2074758
05/16/16 10:10 PM
05/16/16 10:10 PM
Posts: 3,698 jersey
Spaceman Spiff
jersey
i've never had an issue with radial t/a's. in fact a buddy of mine back in the late 90's went 10.90's on a beat set of radial t/a's in a big block powered cutlass. with slicks that car went 10.60's... i've run those tires since '97 and never had issues with them. last pair i bought was 2010.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: BFG TA
[Re: Dons Dart]
#2074802
05/16/16 11:02 PM
05/16/16 11:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
"The Cobra Radial G/T is Cooper’s all-season cosmetic performance tire that is targeted to buyers who prefer raised white-letter styling in an all-season tire."
The Kelly Bundy of tires, looks good but empty in the head.
Re: BFG TA
[Re: Dons Dart]
#2074845
05/16/16 11:55 PM
05/16/16 11:55 PM
Posts: 3,386 KY USA
mopargem
KY USA
One of my radial t/a's desided to sidewall split and delaminate the first layer. Good thing I wasn't driving! I'm not real sure anout the quality of them even though I still use them because lack of choices for rwl.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
Re: BFG TA
[Re: mopargem]
#2151320
09/09/16 10:57 PM
09/09/16 10:57 PM
Posts: 6,232 JERSEY
RJS
JERSEY
I wanted to bring this thread back to the top. I've been buying T/A radials since 1978, in fact I used to buy blems with zero problems. This past February I bought 2 245 60-15's and 2 275 60-15's from DISCOUNT Tire Direct. After 2 weeks the 275 60-15's started turning brown no matter what cleaner was used. The front 245 60-15's are still bright White and never even wiped off in the same time frame. Finally in July I called Discount tire and told them of the situation. They said first they heard but wanted me to be happy and sent me 2 new 275 60-15's for a charge of $45.00. OK I wait till the day before the Mopar show at English Town and mount up the new pair. About 5 hours into the day they start turning Brown also. So here I am with Bright White front letters which by the way are larger than the letters on the rear 275 60-15's (both sets) again. I hate the look of my car now and after using BF Goodrich T/A radials on numerous cars for 38 years don't know what to do next with these ugly paper weights!!!! Ron
