Re: Exhaust turndowns???
[Re: TomsCharger70]
#2005849
02/04/16 11:54 PM
02/04/16 11:54 PM
Posts: 1,127 Massillon, Ohio
cudatom
Massillon, Ohio
I run turn downs but actually have then turned out to the side of the car(rotated 90 deg from straight down). They end right under the rear seat. They dont kick up any more dust than people w/open headers and I have no issues w/fumes.
Ok
[Re: TomsCharger70]
#2005855
02/05/16 12:00 AM
02/05/16 12:00 AM
Posts: 17,929 Akron, Ohio
ProSport
Akron, Ohio
I've never had tailpipes on any Mopar I've ever owned, but I sure wish they had them. I don't even have them on my new street car but hope to soon. I've always used turndowns at the rearend, but turn them mostly sideways, I've never had any complaints of kicking up dust but I'm pretty much always on concrete.
[Re: Alchemi]
#2006164
02/05/16 04:07 PM
02/05/16 04:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On my electric dumps I turned the outlets into the center of the car so they face each other to try and cancel out some of the noise... like it really maters with open dumps
[Re: Thumperdart]
#2006250
02/05/16 06:43 PM
02/05/16 06:43 PM
Posts: 66 Oklahoma
66 Belvedere
Oklahoma
Years ago at LACR(Desert),I had turndowns and pissed a LOT of people off in the pits blowing dust in their faces........don`t recommend it myself. Hahaha you had to get there early to get a good spot! Ray Usually drove there and back and was in line before most......... With the car in your sig? What years did you go? Ray
[Re: 66 Belvedere]
#2006272
02/05/16 07:18 PM
02/05/16 07:18 PM
Thumperdart
State of confusion
Ya, same car and first went there in 89 and raced there off and on till they closed............
[Re: TomsCharger70]
#2006306
02/05/16 08:06 PM
02/05/16 08:06 PM
Posts: 5,187 CT
GTX MATT
CT
I have turndowns but need tailpipes, I smell like hydrocarbons when I'm out in the car long
[Re: TomsCharger70]
#2006376
02/05/16 10:29 PM
02/05/16 10:29 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have the tails off my Barracuda right now because there is a car event coming up in a few weeks, this stopped me from driving it to work because it is toooooo loud, god Im nice to my neighbours.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: racerx]
#2006609
02/06/16 10:12 AM
02/06/16 10:12 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Sense were on the subject of exhaust how muck more weight do you all think a set of tailpipes add ? I cut 3.5 ft per side out of my 3.5 exhaust and it was 50lbs. My turn Down's end under my seat way short of the rear.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#2006614
02/06/16 10:30 AM
02/06/16 10:30 AM
Posts: 4,169 Mo.
racerx
Mo.
Sense were on the subject of exhaust how muck more weight do you all think a set of tailpipes add ? I cut 3.5 ft per side out of my 3.5 exhaust and it was 50lbs. My turn Down's end under my seat way short of the rear. No sh!t never thought it would be that heavy
[Re: TomsCharger70]
#2006619
02/06/16 10:46 AM
02/06/16 10:46 AM
1967dartgt
Hilltown Pa
It was like 23 pounds per pipe, 3.5 is heavy stuff.
[Re: 1967dartgt]
#2006627
02/06/16 11:03 AM
02/06/16 11:03 AM
Posts: 11,704 W. Kentucky
justinp61
W. Kentucky
Sense were on the subject of exhaust how muck more weight do you all think a set of tailpipes add ? I cut 3.5 ft per side out of my 3.5 exhaust and it was 50lbs. My turn Down's end under my seat way short of the rear. WOW........that's over 7# per foot! I'll weigh some 3" when I go to the shop today.
[Re: TomsCharger70]
#2007311
02/07/16 12:31 PM
02/07/16 12:31 PM
Posts: 13,053 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
If 50LBS is important enough to you to accept the down sides of removing the tail pipes, what kind of racing do you do? If it is drag racing, 50LBS over and behind the rear axle might well aid the hole shot. Most tail pipes won't weigh 50LBS. A few might, but most won't. When you pull them, weigh them and let us know what they weighed and what impact it had on your performance.
Master, again and still
