Re: Cam choice for 505 to run 10.50's
[Re: Sport440]
#2007517
02/07/16 07:17 PM
02/07/16 07:17 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Tex [/quote]
I agree, if those were my only choices, I would run the smallest, the Howards cam.
But, what do you mean that all those cams were ground on a 104 Intake centerline.
Cams are grounds at A LSA and not at a Intake centerline. They are installed at a specific ICL
You stated differences of 110-108-106 LSA for the three separate cams. Im sure they weren't all ground on a 104 LSA Did , you mean a recommended installed 104 ICL
Also, I wouldnt use any of the cams you listed for what your doing. The hughes cam listed 6872 would be better IMO too.
[/quote] Yes the Howards is 104ICL installed , all cams are installed 4 degrees advanced ICL over the lobe separation .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2007532
02/07/16 07:39 PM
02/07/16 07:39 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I guess I'll leave it with this...... Go to some of the on line dynamic compression calculators and see what those long duration cams and 10.5cr add up to...... And see if that number resonates in your mind as something that's going to make big power.
[Re: Roadrunner451]
#2016326
02/20/16 10:51 PM
02/20/16 10:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'll apologise for bringing this back up, but I find this a very interesting topic. I'm sure I'm not the only one as there are a lot of people in a similar situation. Having some people post with real world experience and have guys who do this sort of thing as a living has been pretty interesting. But there's a couple of things I was curious about.
Would it not make sense to run a bit more duration, but keep the lobe centers kind of on the tight side to keep the dynamic compression up ?
Run as much lift as you think you can tolerate ? I would think this would be up to the individual though.
Is more exhaust duration needed on a street/strip car even if it has a good exhaust system ?
Just some things I'm thinking about for my own car as well. I've had two reccomendations from two different cam grinders, and they are considerably different. The one I received had a lot of duration and a wide lobe center. Not really getting the wide lobe center thing at all. You would have to state what your gonna do with the car and all the specs to the engine.. a wide LSA will give a flatter torque curve but the narrow one will give more bottom end torque... where do you need it at.. if its a street/strip you might want the wider LSA but advance the cam
[Re: Roadrunner451]
#2016366
02/21/16 12:07 AM
02/21/16 12:07 AM
tex013
Sydney,Australia
Roadrunner451 , Yes getting the most input can help . After running dynamic comp numbers like Fast said , it appears i will need to aim for around 60deg ABDC or less to gain/retain good compression . With my numbers there was nearly 1 point of compression between cam choices .As to tight lobe seperation i understand this to make the motor power peakier , wider is flatter/broader . Still waiting for my short so on hold .
Tex
[Re: Project kickin A]
#2016645
02/21/16 04:24 PM
02/21/16 04:24 PM
BradH
I run a 585 260@ 50 installed at 104 fast ramp Engle flat tap solid in a std RB 446 with sidewinder heads, hooker fender exits with a M1 and 1090 BG it went 10.55 last weekend, foot brake glide nothing too radical At what weight, gear & stall speed? My old combo was 266 at .050" / .600" / 108 LSA + 4 SFT Comp grind from Porter Racing Heads, 452 RB w/ ported Stage VI heads (10.70 CR & 93-oct E10 fuel), BG 4150 carb, 2" headers & full exhaust, 4.10s & 4500-flash converter... ran 10.5s at 3750+ #s at near sea level tracks, and 2-3 tenths slower in summer heat and higher altitude tracks. IMO, the OP doesn't need a "big" cam to run his posted #, just one that's a good fit for the rest of the combination. The Hughes 6872 on 108 LSA looks reasonable to me, too. As always... just my opinion.
