Re: wheel horsepower vs. ET
[Re: Duner]
#2006400
02/05/16 11:55 PM
02/05/16 11:55 PM
Posts: 570 UK
rb446
UK
To get that mph..........810hp +62 Power to Weight Ratio: 5.17 60 Foot E.T. : 1.40 1/8 Mile E.T. : 6.36 1/8 Mile Trap Speed : 106.94 1/4 Mile E.T. : 10.07 1/4 Mile Trap Speed : 133
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#2006412
02/06/16 12:08 AM
02/06/16 12:08 AM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
To get that mph..........810hp +62 Power to Weight Ratio: 5.17 60 Foot E.T. : 1.40 1/8 Mile E.T. : 6.36 1/8 Mile Trap Speed : 106.94 1/4 Mile E.T. : 10.07 1/4 Mile Trap Speed : 133 Thanks! I can't help but laugh at the 1.40 60' and 10.0 combo. Man, that's pie in the sky stuff for my heap right there! When it went 133 mph I hurt a piston. When it went a 1.43 60' it hurt the transmission. I can never seem to get all my ducks in a row.... but I'm workin' on it! So 810 at the flywheel? What should that look like at the wheels?
[Re: mcat4321]
#2006492
02/06/16 02:10 AM
02/06/16 02:10 AM
Posts: 707 California
BigDaddy440
California
370rwhp (street 440 w/ edelbrock rpm heads)
3600 lb 68 B body dodge + 160lb driver (fiberglass Hood etc)
3.91 gears
Automatic Trans
1.70 60ft
150ft elevation
11.96 @ 114.5mph
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#2006532
02/06/16 04:01 AM
02/06/16 04:01 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
moroso hp 800 seems to work out to fly wheel hp race weight 3550 lbs 60 ft 1.35 1/8 6.0 @ 112 1/4 9.56 @ 143 600 ft above sea level
[Re: Duner]
#2006584
02/06/16 09:39 AM
02/06/16 09:39 AM
Posts: 570 UK
rb446
UK
To get that mph..........810hp +62 Power to Weight Ratio: 5.17 60 Foot E.T. : 1.40 1/8 Mile E.T. : 6.36 1/8 Mile Trap Speed : 106.94 1/4 Mile E.T. : 10.07 1/4 Mile Trap Speed : 133 Thanks! I can't help but laugh at the 1.40 60' and 10.0 combo. Man, that's pie in the sky stuff for my heap right there! When it went 133 mph I hurt a piston. When it went a 1.43 60' it hurt the transmission. I can never seem to get all my ducks in a row.... but I'm workin' on it! So 810 at the flywheel? What should that look like at the wheels? Yes Flywheel HP, can use the other Wallace calc that gives you rwhp and fly but thats miles out cos they only rate a 10% loss. Can't see you ever working out hp losses through the drivetrain accurately as too many variables to take into account of.
[Re: BigDaddy440]
#2006585
02/06/16 09:44 AM
02/06/16 09:44 AM
Posts: 570 UK
rb446
UK
3.91 gears
Automatic Trans
1.70 60ft
150ft elevation
11.96 @ 114.5mph
Power to Weight Ratio: 8.17 60 Foot E.T. : 1.63 1/8 Mile E.T. : 7.40 1/8 Mile Trap Speed : 91.81 1/4 Mile E.T. : 11.73 1/4 Mile Trap Speed : 114 460 Fly HP/3760lbsThe numbers shown are on an optimum run.
[Re: mcat4321]
#2006651
02/06/16 12:37 PM
02/06/16 12:37 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
How about these, car is 3195lbs and has a 28" tire and is shifted at 7200.
NA 1.35 6.05 113.8 9.51 142.1
Now on a single 93 jet 1.36 5.52 129.3 8.57 162.3
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: mcat4321]
#2006657
02/06/16 12:48 PM
02/06/16 12:48 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
So where is the altitude correction calc?
Mopar to the bone!!!
[Re: mcat4321]
#2006665
02/06/16 01:00 PM
02/06/16 01:00 PM
Posts: 570 UK
rb446
UK
NA = 744HP Power to Weight Ratio: 4.29 60 Foot E.T. : 1.32 1/8 Mile E.T. : 5.97 1/8 Mile Trap Speed : 113.78 1/4 Mile E.T. : 9.47 1/4 Mile Trap Speed : 142
93 jet = 1004hp Power to Weight Ratio: 3.18 60 Foot E.T. : 1.19 1/8 Mile E.T. : 5.41 1/8 Mile Trap Speed : 125.73 1/4 Mile E.T. : 8.57 1/4 Mile Trap Speed : 156 260hp to gain a second?
We had a guy hold the mph record in Super Modified with a 67 Camaro (N20 BBC 509ci motored car)> 7.61@184mph!!..was a Lenco + a lightweight car though, wallace only showed it at 176......N20 is cool stuff!
[Re: rb446]
#2006669
02/06/16 01:03 PM
02/06/16 01:03 PM
Duner
Chandler, AZ
Thanks. I hope in the future to also see what the difference is between a rollerized 727 and this 46RE. I've heard good reports about performance gains from the swap.... but I do like my overdrive and lockup.
[Re: rb446]
#2006844
02/06/16 05:39 PM
02/06/16 05:39 PM
1967dartgt
Hilltown Pa
93 jet = 1004hp Power to Weight Ratio: 3.18 60 Foot E.T. : 1.19 1/8 Mile E.T. : 5.41 1/8 Mile Trap Speed : 125.73 should be 129 1/4 Mile E.T. : 8.57 1/4 Mile Trap Speed : 156 Should be 162 260hp to gain a second?
We had a guy hold the mph record in Super Modified with a 67 Camaro (N20 BBC 509ci motored car)> 7.61@184mph!!..was a Lenco + a lightweight car though, wallace only showed it at 176......N20 is cool stuff! You forgot some mph and just matched et.
[Re: mcat4321]
#2006960
02/06/16 08:50 PM
02/06/16 08:50 PM
Posts: 570 UK
rb446
UK
Yes I did this time, ok I'll mph the 93 jet run> 60 Foot E.T. : 1.15 1/8 Mile E.T. : 5.23 1/8 Mile Trap Speed : 130.05 1/4 Mile E.T. : 8.28 1/4 Mile Trap Speed : 162 1111 hp
[Re: mcat4321]
#2008325
02/09/16 12:32 AM
02/09/16 12:32 AM
Posts: 570 UK
rb446
UK
139mph/3550 = 788fwhp on the day, thats approx a 20% loss on dyno figs on the day> Power to Weight Ratio: 4.51 60 Foot E.T. : 1.34 1/8 Mile E.T. : 6.07 1/8 Mile Trap Speed : 111.98 1/4 Mile E.T. : 9.62 1/4 Mile Trap Speed : 139
I don't have my time slips from 1990 but my last but 1 run in the '69 10:1 SCR 446ci Cuda, I ran 10.7@125, stock very heavy 6-pk bottom end,(pistons 900gms, rods 1100gms) 2.14/1.81 906's, 4500 verter, 850DP, Team G, 2" f/wells, CC .650"/290@.050 solid flat cam, 4.88's/14x32's, ladders/coil-overs, stock front w/90-10's....3000lbs all in, 60 Foot E.T. : 1.49 1/8 Mile E.T. : 6.75 1/8 Mile Trap Speed : 100.68 1/4 Mile E.T. : 10.70 1/4 Mile Trap Speed : 125 = 484hp 60 was actually 1.46
With Spray, last ever run 60 Foot E.T. : 1.39 1/8 Mile E.T. : 6.29 1/8 Mile Trap Speed : 108.03 1/4 Mile E.T. : 9.97 1/4 Mile Trap Speed : 134 1/4 Mile Trap RPM : 6,891 It trapped at 7250 with verter slip Ran a 1.38 60, 9.96@133.9 = 598HP luckily Anglia TV who was there at the Pod captured the run.
[Re: rb446]
#2008569
02/09/16 02:41 PM
02/09/16 02:41 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
With Spray, last ever run 60 Foot E.T. : 1.39 1/8 Mile E.T. : 6.29 1/8 Mile Trap Speed : 108.03 1/4 Mile E.T. : 9.97 1/4 Mile Trap Speed : 134 1/4 Mile Trap RPM : 6,891 It trapped at 7250 with verter slip Ran a 1.38 60, 9.96@133.9 = 598HP luckily Anglia TV who was there at the Pod captured the run. Are you just plugging numbers into the wallace calculator, or do you have this converted into a spreadsheet?
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: mcat4321]
#2008595
02/09/16 03:38 PM
02/09/16 03:38 PM
Posts: 570 UK
rb446
UK
I'm inputting the numbers straight into only 1 of the Calcs but using some race knowledge and actual time slips along with it in doing so to verify accuracy of calc.
[Re: fast68plymouth]
#2008600
02/09/16 03:48 PM
02/09/16 03:48 PM
Posts: 570 UK
rb446
UK
3450lbs, 1.48 60', 10.63 @ 125.8 = ??? 561hp>
Power to Weight Ratio: 6.15 60 Foot E.T. : 1.48 1/8 Mile E.T. : 6.73 1/8 Mile Trap Speed : 100.94 1/4 Mile E.T. : 10.67 1/4 Mile Trap Speed : 126
