Re: SETTING PINION DEPTH............
[Re: 451Mopar]
#2006178
02/05/16 05:25 PM
02/05/16 05:25 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
The clamshell type bearing remover will allow you remove the bearings without damage if you need to change the shims.
I'll have to see someone pull this off before I believe it. I've tried it many times. Heated the bearing. Iced the pinion. Never gotten one off without damaging the needle-cage first.
[Re: Thumperdart]
#2006184
02/05/16 05:49 PM
02/05/16 05:49 PM
Posts: 11,655 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The tool uses the race to compress and contain the rollers and the cage. Takes some using it to get it right. If you're using it on the pinion, you'll have to have a second bearing race.
[Re: BuckeyeBrawler]
#2006256
02/05/16 07:50 PM
02/05/16 07:50 PM
Thumperdart
State of confusion
Thankxxx Cass recommended .007-.008.............I sure wish I had a carrier vise but hopefully my friend will build me one...... I will always be a footbrake guy at least w/this car....... Crazy question but do you guys think the filler plug assists in structural strength? The reason I ask is I was thinking of getting an alum. plug instead......
[Re: WedgeFED]
#2006311
02/05/16 09:15 PM
02/05/16 09:15 PM
Thumperdart
State of confusion
Looks cool but after talking to Cass, he said he doesn`t even use em and that it`s more of a hastle and takes more time messing w/those than it does to set em up sometimes.........
[Re: Thumperdart]
#2006351
02/05/16 10:51 PM
02/05/16 10:51 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
Maybe you should just send it to me and I will send my carb to you for an even labor swap I have set up probably over 100 gears and never once used a pinion depth tool. I do use set-up bearings for all the ones I do though so I guess it's just developing a feel for it. Just remember to de-burr the shims before you start Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2006353
02/05/16 11:01 PM
02/05/16 11:01 PM
Thumperdart
State of confusion
Maybe you should just send it to me and I will send my carb to you for an even labor swap I have set up probably over 100 gears and never once used a pinion depth tool. I do use set-up bearings for all the ones I do though so I guess it's just developing a feel for it. Just remember to de-burr the shims before you start Gus I would if u were closer cos the fed ex monkey literally dropped the damn thing on my porch plus I need to learn how but thankxxx anyhow........
#2006428
02/06/16 12:29 AM
02/06/16 12:29 AM
Thumperdart
State of confusion
Aluminum plug !! Dom you've been hanging out with Full Metal Jacket and DVW too much. Aluminum plug will be fine. Had to ask............ Ya 451mopar, it`s the 489 set up w/the solid spacer..........
[Re: Thumperdart]
#2006487
02/06/16 02:03 AM
02/06/16 02:03 AM
StealthWedge67
Puyallup, WA
Thankxxx Cass recommended .007-.008.............I sure wish I had a carrier vise but hopefully my friend will build me one...... I got myself a 3 ft section of drilled angle steel at home depot for a few bucks. bolted the chunk to it at about the center through the mounting holes. I can then put the chunk on the floor and stand on the angle steel on either side. it holds the chunk in place for torqueing the cap bolts.
[Re: StealthWedge67]
#2006510
02/06/16 02:56 AM
02/06/16 02:56 AM
Thumperdart
State of confusion
Thankxxx Cass recommended .007-.008.............I sure wish I had a carrier vise but hopefully my friend will build me one...... I got myself a 3 ft section of drilled angle steel at home depot for a few bucks. bolted the chunk to it at about the center through the mounting holes. I can then put the chunk on the floor and stand on the angle steel on either side. it holds the chunk in place for torqueing the cap bolts. I may have to steal this if u don`t mind..........
[Re: Monte_Smith]
#2006595
02/06/16 10:14 AM
02/06/16 10:14 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I have to wonder why all the fuss about pulling bearings. Why not just polish the pinion, spool, what have you, so that the bearings are not a press fit and be done with it. Where does anybody think the bearing is going to GO if it's not pressed on tightly Thank you. Needed to be said.
[image][/image]
[Re: sgcuda]
#2006686
02/06/16 01:24 PM
02/06/16 01:24 PM
Thumperdart
State of confusion
I was wondering the same thing about the crazy press fit because once everything`s tight where`s it gonna go? I have grinding bits and flapper wheels so I`ll mike the pinion after I polish it up and the bearing id`s and slowly remove the needed material from the bearing id and go from there..........
[Re: Thumperdart]
#2006726
02/06/16 01:59 PM
02/06/16 01:59 PM
Posts: 5,166 CT
GTX MATT
CT
Well why is anything bearing press fit? I thought so that the inner ring doesn't spin on whatever its pressed on, rather than the bearing spinning. Be careful how much you remove.
