Does anyone make an inline fuel filter with a check valve?
#2005615
02/04/16 07:43 PM
02/04/16 07:43 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I have a number of cars and since I work 2 weeks out of town sometimes when I get around to driving them I have to spin them a minute to pick up fuel to fire. It doesn't occur if it is driven regularly and it's not like it spins enough to kill a battery but I do feel it takes it toll on starters. It happens to everything from 2 to 6 barrell, Holley and otherwise and all of the big 3. Generally only 3-4 weeks at worst between being driven. I have considered that it is the ethanol evaporating causing even the bowls to be dry.
Thanks in advance, Kevin
Careful, your character's showing!
Re: Does anyone make an inline fuel filter with a check valve?
[Re: Porter67]
#2005693
02/04/16 09:31 PM
02/04/16 09:31 PM
Posts: 2,655 western PA
mopar4ya
western PA
1 to 2oz of gas down the carb is easy enough... Not if it is a shaker hood car.
[Re: mopar346]
#2005709
02/04/16 09:57 PM
02/04/16 09:57 PM
mopar346
Don't want to put an electric pump on most of the cars for a number of reasons and no doubt I could prime them but I really don't know why I should have to. They all have aftermarket stock pumps and clear fuel filters. It's not a huge deal but mainly irritating cause I like my cars to work right. The one with the least trouble is my dually which is a GM with a Q-jet, it has the carb filter with the check valve and even after a month or so it fires after minimal spinning. I'm reasonably sure I'm not the only one with this issue and I'm thinking surely someone make an inline filter with a check valve.
[Re: mopar346]
#2005796
02/04/16 11:43 PM
02/04/16 11:43 PM
mopar346
I have considered that due to the ethanol boiling but I thought I might try it. They don't sit long enough for generic evaporation but with the heat and ethanol maybe. Strangely enough if doesn't do it if I start them the next day with one exception but it's a Ford so who knows what it's issue is.
[Re: mopar346]
#2005822
02/05/16 12:25 AM
02/05/16 12:25 AM
Posts: 10,605 Freeport IL USA
poorboy
Freeport IL USA
Time for all new fuel lines, hoses, hose clams and maybe a new fuel pump.
I suppose the fuel could evaporate from the carb, it has air bleeds that could allow evaporation, (the bowl vent has a hose going to the carbon canister to collect the fumes, right?) The fuel has to be draining back through the pump to make the line between the pump and carb empty. Otherwise it shouldn't take very long for a good fuel pump to refill the carb, unless there was no fuel at the pump. I don't see the fuel flowing back up into the tank, which is often higher then the line. (The fuel line is higher then the tank where it run above the rear axle before dropping down to the frame rails) The section of fuel line above the axle should stop and fuel from returning into the tank between it and the pump. If the fuel can't return to the tank, the fuel line, hoses, or hose clamps must be leaking, or the pump is leaking fuel, or is too weak to move the fuel like it should, otherwise where did the fuel go? Gene
[Re: mopar346]
#2005877
02/05/16 01:26 AM
02/05/16 01:26 AM
mopar346
Well the new parts describe half the cars, only one of the cars was born with a charcoal canister and it is disabled. My guess is that the aftermarket pumps, most of which are new, don't have check valves in them allowing the fuel to drain back, further I think the fuel may be boiling in the line running on the frame rail by the exhaust manifold (factory, everything correctly located and in good shape). The key may be in the quality of fuel which I haven't completely resolved in my head. Most are parked on level surfaces so the line hiegths are correct and prevent drain back into the tank. No fuel leaks that are noticeable under pressure. Not arguing with the ideas just thinking through then out loud. I need to start looking at the fuel filters before fire up to make sure it is what I think it is but I cant imagine it can be anything else the way they act.
[Re: mopar346]
#2005970
02/05/16 09:01 AM
02/05/16 09:01 AM
Posts: 5,903 ohio
ruderunner
ohio
I have the same problem. See through filters mounted code to and slightly above the pumps will tell the tale.
Yes fuel evap from the carbs is going to happen but a good pump will overcome that quickly.
Worst I saw was anew pummp on a cj5, it would go epty in a matter of minutes.
Angry white pureblood male
[Re: mopar346]
#2006015
02/05/16 11:52 AM
02/05/16 11:52 AM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
My 340 Dart does the same thing. I have a Carter "performance" mechanical pump and the new mini starter. That combo gets fuel to the carb pretty quick.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: mopar346]
#2006045
02/05/16 01:25 PM
02/05/16 01:25 PM
DaytonaTurbo
Manitoba, Canada
I have considered that due to the ethanol boiling but I thought I might try it. They don't sit long enough for generic evaporation but with the heat and ethanol maybe. Strangely enough if doesn't do it if I start them the next day with one exception but it's a Ford so who knows what it's issue is. That would be an incorrect assumption. Fuel isn't going to drain uphill, through your needle and seat to leave the carb. Yet when you go to start your car after it's been sitting for weeks there's no fuel in the bowls, requiring much cranking to refill them enough to fire the car. At starter rpm, mechanical pumps don't seem to refill the carbs all that quick. Fuel's evaporating out of your carb, it happens to all of us with this modern pump swill they call gasoline. A check valve won't do anything for you. My last two carbed vehicles I changed over to electric fuel pumps. All my fueling trouble vanished. Turn the key to run for a few seconds so the electric pump can fill the bowls, pump the gas and hit the key. Doesn't get any easier than that.
[Re: Alaskan_TA]
#2006448
02/06/16 01:08 AM
02/06/16 01:08 AM
mopar346
With four cars, only the /6 car will start quickly after a month. For the three 318 cars, I keep gas in a used mustard bottle, with a squirt down the carb throat they always start. Might just try some high octane mustard. OK, I know the fuel is junk for the most part but I wasn't putting that much creedance in it was just the fuel since others seem to react better than others, all in the same parking conditions. I have 110 leaded out of the pump hear, I might try it in a few cars for a tank and see how they act. I'm not adding electic pumps to most of my cars so that's a no car, is there any additive that has been proven to work? Any that claim to work? Thanks for the input folks.
