Quick question on Torqueflite 727... #2004336
02/02/16 07:44 PM
02/02/16 07:44 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
I really like the 727, and more since I installed TF-2 reprograming kit
My question is: when the trans. is in third at around 40 mph and I floor-it, trans donwshift to first gear.
I would like to know if the low band apply or not I don't want to dammage the sprag...
Re: Quick question on Torqueflite 727... [Re: STROKIE] #2004719
02/03/16 11:46 AM
02/03/16 11:46 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Should be fine bump
Re: Quick question on Torqueflite 727... [Re: STROKIE] #2004889
02/03/16 04:01 PM
02/03/16 04:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The rear (low) band is never applied in Drive. Forced downshifts to 1st are hard on the sprag but, since you're already rolling, not as bad as when starting off.
Re: Quick question on Torqueflite 727... [Re: John_Kunkel] #2005052
02/03/16 09:04 PM
02/03/16 09:04 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
Thanks John...
Re: Quick question on Torqueflite 727... [Re: STROKIE] #2005336
02/04/16 06:57 AM
02/04/16 06:57 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
If you are paranoid about it, pull it back with the shifter into first as you floor it and it will apply the rear band.
