Re: Help Disengaging Front Torsion Bars from K-Member
[Re: vinnyd76]
#2004975
02/03/16 06:39 PM
02/03/16 06:39 PM
Posts: 10,863 Freeport IL USA
poorboy
Freeport IL USA
I believe you will need to bolt the K member back onto the body before the torsion bars will come out. Both ends are in a machined housing and need to move about 2" - 3" backwards to come out. The hex on each end of the bar is also a machined surface about 1 1/2" long. Picture a nut in a deep well socket, the bar is the nut, the socket on one end is the lower control arm pivot, and the other end socket is the trans crossmember. The nuts are one piece, the ends do not give or flex. I don't believe the bars will move through the machined housings with the weight of the K member hanging on them.
The other option is to unbolt the lower control arm pivot point on both control arms and pull the K member forward off the control arm pivot points, then you may be able to remove each lower control arm off the torsion bars individually. Once the control arms are removed from the bars, they will probably come out of the trans crossmember.
When you reassemble it, install everything except the torsion bar adjusting bolts, be sure the control arms are pointing down, then install the bars, then the adjusting bolts. If the control arm torsion bar sockets are not oriented correctly, the bars will bot have enough tension to support the car. Gene
[Re: vinnyd76]
#2007883
02/08/16 12:48 PM
02/08/16 12:48 PM
Posts: 7,548 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Here's the home made device I came up with to clamp my torsion bars so I could whack them out…. you don't want to hit or damage the bars! Took a hell of a beating to get them loose, wore myself out with a 5lb sledge… if I did it again I'd heat up the receiving end at the subframe with a plumber's blowtorch first. Good luck, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
