Re: It fits...barely
[Re: BobR]
#2452341
02/15/18 10:45 PM
02/15/18 10:45 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
What's your timeline for completion? Very nice indeed. Previous timeline was last summer ! However everything looks very positive for this summers/
76 Duster
work in progress
[Re: Forest]
#2452351
02/15/18 11:01 PM
02/15/18 11:01 PM
Edge
Alberta Canada
Bad to the bone! Dumb question, but is this the same car that was originally built by JCR Chassisworks? Also this thing outta run bottom 6's huh? Different car than the JCR build...that is a very nicely built car for sure. Even considering that this is the same car I will take as a complement. The way I have supercharger pullied we wont be making enough power for bottom sixes and the driver is not ready for that matter. We will try to take it one step at a time.
76 Duster
work in progress
[Re: Biginchmopar]
#2455874
02/22/18 11:16 PM
02/22/18 11:16 PM
Edge
Alberta Canada
Injectors have been cleaned, flowed and installed ( 210's and 700's), car will idle and run part throttle on the 210's. Fuel lines and oil lines in place. Injector harness is next.
76 Duster
work in progress
[Re: Edge]
#2456670
02/24/18 02:29 PM
02/24/18 02:29 PM
Edge
Alberta Canada
Line lock and brake lines now installed
76 Duster
work in progress
[Re: FastmOp]
#2476463
04/02/18 09:34 PM
04/02/18 09:34 PM
Edge
Alberta Canada
Getting closer !
Vent tank and lines running from burndown tubes to the back of the car. Decided better to have any oil behind the rear wheels and I see more cars with the vent tank in the rear more recently.
Should be firing car up pretty soon !
76 Duster
work in progress
[Re: Edge]
#2476644
04/03/18 08:28 AM
04/03/18 08:28 AM
Posts: 4,066 Mo.
racerx
Mo.
[Re: 80arrow]
#2477178
04/04/18 01:01 AM
04/04/18 01:01 AM
Edge
Alberta Canada
For the vent tubing 1 1/4 inch is specified by NHRA for blown alcohol. NHRA also lists some different types of "approved vent tube". The spec tubing is available on line for example at quartermax for $11 -$20/foot. Spent way too much time looking for alternatives as well 1 1/4 is not a popular ID. Good vibrations sells a simple PVC hose however PVC hose does not stand up well to methanol or oil. The line I used is PVC with a urethane coating on the inside it is actually air seeder hose that I had laying around right under my nose the whole time. In theory it should stand up well but we will see. The urethane coating is intended for reduce wear flowing abrasive material in the hose. You can buy it at most farm supply stores. If I recall this came from the John Deere dealership.
76 Duster
work in progress
[Re: 80arrow]
#2477192
04/04/18 01:19 AM
04/04/18 01:19 AM
Edge
Alberta Canada
Here are a few more pics of the routing of the vent lines from the burn down tubes, through fire wall and finally along frame rail. My fabricator built a catch can at the low point of the tubing so any oil that accumulates in the lines can be drained from the system.
76 Duster
work in progress
[Re: Edge]
#2477193
04/04/18 01:20 AM
04/04/18 01:20 AM
Edge
Alberta Canada
I have no idea why some of these photos are flipped when I upload them ?
76 Duster
work in progress
