Page 2 of 3 1 2 3
Re: 2944450 Aficiando's Please......... [Re: Neil] #2001434
01/29/16 08:44 PM
01/29/16 08:44 PM
New Jersey
FC7 cuda Offline
FC7 cuda  Offline
New Jersey
How is this reproduction?
Re: 2944450 Aficiando's Please......... [Re: FC7 cuda] #2001474
01/29/16 09:53 PM
01/29/16 09:53 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
How come no close up pics of the stampings or of the back sides?
Re: 2944450 Aficiando's Please......... [Re: ScottSmith_Harms] #2001542
01/29/16 11:03 PM
01/29/16 11:03 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By ScottSmith_Harms
Morty,
Good eye! It's not mine but there are 4 identical ones and a 5th I've seen elsewhere dated one day later.
Have you noticed the elephant in the room? No Pentastar on any of them, and these are 100% real wheels. Never blasted, never welded on, shown in raw steel that I personally stripped pff with paint stripper,
Wow! I didn't catch that. That's really strange.
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2001650
01/30/16 01:22 AM
01/30/16 01:22 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This is one of the best reproductions I've seen so far, rim shape and stampings. These were made up from original wheel centers and rims, combined to give the correct appearance, (not new stampings). While there are a couple "Tells" you better know your stuff to spot them! The stampings might look crude but with some paint and primer I'd bet they'd pass scrutiny by some of the best eyes out there.
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2001652
01/30/16 01:23 AM
01/30/16 01:23 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Stampings
Re: 2944450 Aficiando's Please......... [Re: ScottSmith_Harms] #2001779
01/30/16 09:09 AM
01/30/16 09:09 AM
New Jersey
FC7 cuda Offline
FC7 cuda  Offline
New Jersey
A couple more
64e1a4df-cbf2-47d5-aab7-c36ec8c97336.jpg722e0721-3348-4397-8d48-89fd03ca2be0.jpga99fb2a4-d426-4aa2-a161-2fd3f0435b17.jpg
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2001827
01/30/16 12:33 PM
01/30/16 12:33 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
Scott - What are the "tells" between those reproduction rims and original 450's? I assume one of them is potentially the Motor Wheel stampings/date codes on the inside of the barrel, which you wouldn’t be able to see unless the tire was off the rim?
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2001856
01/30/16 01:12 PM
01/30/16 01:12 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
As Doctor Diff mentioned, the edge of the drop center is "soft" on the original posters repro wheels. Stands out to me even not looking side ny side with an original. This is because the outer wheel is likely a "new" product. I have made a few "repro" wheel myself using Olds painted SuperStock wheels. I even used a rare AMC "GoPack" wheel as a core 15x7 shell. The olds wheels can be had cheap at $25 each. It's not EZ to find Correct core 14 inch wheels you can carve the center out though. The problem with making them is the WIDTH of the drop center. The wheel center needs to be welded at the very back edge of the drop center to get the correct offset. Now a factory 450 wheel has a drop center that is very wide, say 3 inches. I think the drop an an Olds wheel is say 2.75. So the narrower the drop, the "shallower" your wheel is going to look at the face.
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2001868
01/30/16 01:22 PM
01/30/16 01:22 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Pic of one I made
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2001879
01/30/16 01:32 PM
01/30/16 01:32 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
The other telltale sign of using a "NEW" China made outer shell is the wide step at the face of the wheel. A China wheel has the step at a 90 degree angle, any original 15x7 wheel whether its Mopar or Olds is going to be slanted back. So if you want the best looking "fake 450" use an original 15x7 rim for a core.
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2004924
02/03/16 04:58 PM
02/03/16 04:58 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
That would have been Curt McKim , owner of McWheels out in Slater , Iowa.
Re: 2944450 Aficiando's Please......... [Re: duster2] #2146494
09/02/16 11:41 PM
09/02/16 11:41 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Got my rims from Stockton today, they look great. And for $200.00 shipped to my door, my wallet is one happy camper as well! boogie
Admiration For Multiple Carburetor Vehicles...
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2146947
09/03/16 07:56 PM
09/03/16 07:56 PM
New Jersey
FC7 cuda Offline
FC7 cuda  Offline
New Jersey
Did they use an olds wheel hoop?
Re: 2944450 Aficiando's Please......... [Re: FC7 cuda] #2147418
09/04/16 05:23 PM
09/04/16 05:23 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Original 14" center and repro hoop, not sure what kind?
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2147918
09/05/16 12:33 PM
09/05/16 12:33 PM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Originally Posted By Neil
Once upon a time I thought I saw someone on here who'd made their own 450 look-a-likes using the outer hoops from 15x7 Olds Cutlass wheels?
The picture of the wheel on the tailgate in this post is one of our reproductions. This is made with the original 14 inch center and GM barrel. It is the closest you will get without spending big bucks.
An accurate reproduction can be made with an original 15x7 MOPAR barrel. This involves cutting apart a set of 15 x 7 ralleys and finding original 14"centers. This is all tricky as you take the risk of deforming any one of the pieces involved. Balance and run out quickly become an issue.
There has been discussion of these being reproduced in China by several people. I have not seen them yet. Supposedly the firm doing them does enough Chrysler products that the licensing fee will not be an issue. Again, this was 2 plus years ago, and nothing yet.
As Scott says, there are certain things to look for, of which many have been discussed in this thread.
I hope this adds value to the post. Feel free to PM me if you are interested in a set.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2147931
09/05/16 12:55 PM
09/05/16 12:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Which 14" wheel centers are the ones to look for?
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2148005
09/05/16 02:32 PM
09/05/16 02:32 PM
MI
MI Mopar Works Offline
MI
I recently got this one out of the trunk of a 78 Diplomat at the local junkyard. Paid $10 bucks for it. Guess I did ok.
MI Mopar Works (734)624-2212
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2148156
09/05/16 06:03 PM
09/05/16 06:03 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Go back to the junkyard and see if the registration is in the glove box, ask them where the others wheels are, might be In the garage!
Re: 2944450 Aficiando's Please......... [Re: Alaskan_TA] #2148190
09/05/16 07:08 PM
09/05/16 07:08 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
70-71 date coded 14 X 6 are best, but all will work.......
Re: 2944450 Aficiando's Please......... [Re: Stewpar] #2148239
09/05/16 08:25 PM
09/05/16 08:25 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
What's with the 78 dip wheel is it the 450s cousin.
Page 2 of 3 1 2 3
