Re: small block distributor/computer controlled
[Re: gch]
#1999497
01/27/16 12:38 AM
01/27/16 12:38 AM
RapidRobert
What distributor should I use to bypass this crap and I wouldn't mind having vacuum advance(not equipped now)? Are you wanting to use a 70's regular vac adv dist setup? If so just get an ECU and a ballast & the vac adv dist & wire it up & the diagram is in the archives, just dont run (T) the yellow start wire over to the ballast like the archives show. More later when we clarify what you are after.
[Re: gch]
#1999536
01/27/16 01:27 AM
01/27/16 01:27 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
http://www.ebay.com/itm/Small-Block-Mopar-Dodge-Chrysler-318-340-360-Complete-Electronic-Distributor-HEI-/380453707588?hash=item5894cedf44:g:AEMAAOxy3zNSnhsm&vxp=mtr
Using this on my 88 dodge D250...not only did i bypass the computer...I removed it from the truck..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: gch]
#1999672
01/27/16 12:17 PM
01/27/16 12:17 PM
Posts: 3,138 Central NC
gch
Central NC
I am looking for simple and don't want the hassle of wiring up the old electronic setup. Prefer a ready to run plug and play setup.Being this is my first small block and having to deal with an early computer I figured someone here had been there done that and recommend a simple proven swap. I would love to reuse my brand new plug wires but not a deal breaker. http://www.summitracing.com/parts/sum-850028/overview/year/1987/make/dodge/model/d150I saw this one last night.
[Re: 70AARcuda]
#2000270
01/28/16 02:57 AM
01/28/16 02:57 AM
Posts: 1,083 SE PA
Yellow Fever
SE PA
Using this on my 88 dodge D250...not only did i bypass the computer...I removed it from the truck.. I have one like that and it works good. You can always go to the parts store and get a cheap rebuilt electronic dizzy and add the gm module, I've done that successfully too.
