Re: 383 Factory Piston Dish CC's?
[Re: CoDart]
#1998726
01/25/16 11:26 PM
01/25/16 11:26 PM
RapidRobert
Hello Ori, JohnRR would (likely) be the man with that info, he's the 383 guru
[Re: CoDart]
#1998803
01/26/16 02:16 AM
01/26/16 02:16 AM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
2bbl had a dish
[Re: CoDart]
#2001193
01/29/16 03:01 PM
01/29/16 03:01 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
I want to say it's 8cc. I have a piston but never measured it.
The difference in ADVERTISED ratio between the 4bbl engine and 2 bbl engine in 68/69 is .8 , to get that difference using a compression ratio calculator I come up with 8.5cc.
[Re: dogdays]
#2001208
01/29/16 03:11 PM
01/29/16 03:11 PM
JohnRR
U.S.S.A.
I'm surprised JohnRR hasn't answered this post, maybe it's beneath him to talk about 2-barrel engines? He knows more about stock 383 pistons than about anyone else here.
R.
I posted 5 mins before you did
[Re: dogdays]
#2001211
01/29/16 03:16 PM
01/29/16 03:16 PM
RapidRobert
Ori if you have the piston in front of you, you might measure the diameter and depth of the trough as close as you can cuz it sure ain't gonna be a perfect geometric figure. if you get a cubic inches number (length x width x depth) then multiply that by 16.387064 to get CC's. EDIT How about this! Ori fill the trough with clay (dead even level) then take the clay out (all of it) & have your burette filled to maybe 50 CC dead even on the 50 CC mark then drop the clay in & see how far the water level rises. (knead the clay into a thin rope so it dont catch on the sides of the burette). MORE EDIT forget the burette, take the clay out & knead it into a perfect square then measure the sides (l/w/h) & do the math. MORE EDIT roll it into a ball in the palms of your hands cuz that will be way easier than molding it into a square then put the math on that, volume = 4/3 x (Pi x radius cubed) & the radius will be 1/2 of the balls' diameter then convert that cubic inch number you get into CC's. MORE EDIT Hey Dog, John is a post ho & he would not pass up an opportunity to kick his numbers' higher & he does know the 383 piston ins/outs
[Re: Alchemi]
#2003019
01/31/16 11:15 PM
01/31/16 11:15 PM
RapidRobert
8.9cc's Did mine last year thats too easy! Hey thanks for helping my buddy Ori out
