75 W100 wiring/electrical issue...help!
#1996149
01/22/16 08:33 AM
01/22/16 08:33 AM
Posts: 2,423 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
So, my son has a 75 W100 Club Cab, he's driving down the road last weekend and every gauge in the dash pegs to the right side, he pulls over and calls me and I instruct him to quickly pull the fuse. Soon as he removed the fuse all the gauges dropped to the left peg, put the fuse back in and immediately they go back full right. Since the turn signals are on the same fuse he now has no signals or gauges with the fuse removed. I've spent the last few days chasing wires, pulling the fuse box, replacing fuses and I'm officially stumped...anybody got any ideas? Help please. Thanks
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
Re: 75 W100 wiring/electrical issue...help!
[Re: RapidusMaximus]
#1996154
01/22/16 08:46 AM
01/22/16 08:46 AM
Posts: 6,263 ohio
ruderunner
ohio
Bad voltage regulator for the guages. You should be able to pull it and reinstall the fuse. Gets you lights but no guages. Iirc the regulator is still available.
Angry white pureblood male
[Re: ruderunner]
#1996159
01/22/16 08:57 AM
01/22/16 08:57 AM
RapidusMaximus
Weatherford, Texas
Is that going to be the little unit that looks like a points condenser?
#1996231
01/22/16 12:41 PM
01/22/16 12:41 PM
Posts: 1,897 Spahn Ranch
RMCHRGR
Spahn Ranch
It's on the back of the printed circuit board. Kind of looks like a points condenser I guess but more of a rectangle. It's held in with blade terminals, no wire connections. Easy to replace if he can reach it, just have to lay on the floor and reach up to get it though he probably won't be able to see it. Probably just as easy and better to pull the cluster and inspect for burns/resistance etc., especially on the ammeter connections. He should be able to pull it out just far enough without having to disconnect stuff.
Today is your lucky day, I took some pics so you can see what to look for. First is is of the V.R. itself, second is of the circuit board with the empty slots and third is where it gets installed.
'71 Duster '72 Challenger '17 Ram 1500
#1996382
01/22/16 04:37 PM
01/22/16 04:37 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
That part is 1/2 the price of that Year One link at lots of other suppliers....
#1996565
01/22/16 08:53 PM
01/22/16 08:53 PM
Posts: 6,263 ohio
ruderunner
ohio
This regulator has nothing to do with the amp guage. You may have bad connections or a failing alternator or charging system voltage regulator.
[Re: ruderunner]
#1996768
01/23/16 01:18 AM
01/23/16 01:18 AM
Posts: 4,299 State of Fascism
52savoy
State of Fascism
This regulator has nothing to do with the amp guage. You may have bad connections or a failing alternator or charging system voltage regulator. That may be.. I'm busy fixing just about everything else right now so instrument woes aren't a priority for now.
[Re: RMCHRGR]
#1996857
01/23/16 08:29 AM
01/23/16 08:29 AM
RapidusMaximus
Weatherford, Texas
Yep, all you can say after browsing through that is WOW...lol
