Re: 440 Source Roller Rocker arms (any good)
[Re: batt2rm]
#1995190
01/20/16 10:49 PM
01/20/16 10:49 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I had a set on my 440 for about three years. The quality seemed OK and I didn't have any issues with them. However, after reading a few first-hand accounts of them failing over on the Unlawfl Race & Engine Tech board, I got a little worried and ended up buying a set of Harland Sharps. You may want to post on the Unlawfl board and get some more feedback. Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: batt2rm]
#1995193
01/20/16 10:55 PM
01/20/16 10:55 PM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
I have a low milage set of source rockers on source shafts with their hold downs I just took off my stroker 505 as I wanted to go the crane route so they would fit under my stock valve covers. They worked great for me for the couple thousand street miles I used them. PM me if you are interested in a very nice used set cheaper than new as I would do $175 for it all plus the shipping. Thanks
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
[Re: vette1986]
#1995273
01/21/16 12:55 AM
01/21/16 12:55 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have seen a few guys with mild engines run them and be ok but I have also seen some on engines built more and give trouble. My brother has a car in garage right now that ate up the roller bearing in one rocker. Course he has not determined what caused the bearing to go bad. Ron
[Re: 383man]
#1995296
01/21/16 01:39 AM
01/21/16 01:39 AM
Posts: 198 TN Hoosier
jb500
TN Hoosier
I have seen a few guys with mild engines run them and be ok but I have also seen some on engines built more and give trouble. My brother has a car in garage right now that ate up the roller bearing in one rocker. Course he has not determined what caused the bearing to go bad. Ron I would bet it is because the rocker shafts are undersized for roller/needle bearings.
[Re: busboy]
#1995348
01/21/16 02:53 AM
01/21/16 02:53 AM
jb500
TN Hoosier
"Rocker shafts undersized for roller/needle bearings" ?? Can you elaborate? The shaft needs to be a true .8750 dia (can't recall tolerances) with a hardness in the upper 50's/lower 60's. The reason is to distribute the load evenly to all the needles (no slop) and the hardness is needed to prevent the rollers from digging into the shaft. I found out all this info after the needles in my 440S rockers let go. Stock OEM style shafts were supplied in my kit. To the OP: Remember....cheap parts cost less up front, but twice as much when they fail and even more to clean up the mess. Don't skimp on the rockers.
[Re: batt2rm]
#1995657
01/21/16 05:55 PM
01/21/16 05:55 PM
Posts: 5,435 So Cal
Sinitro
So Cal
Bad place to gamble to save a few $... Valve train components do an incredible task... Use quality proven parts.. IMHO... Why risk an engine.... Just my $0.02....
[Re: batt2rm]
#1995849
01/21/16 09:42 PM
01/21/16 09:42 PM
Posts: 4,457 Washington
madscientist
Washington
NEVER PUT NEEDLE BEARINGS ON A RECIPROCATING SHAFT. EVER.
Why would you want to copy the sorry crap the chevy guys had to use?
Find a rocker that has no needle bearings on the shaft.
[Re: madscientist]
#1996006
01/22/16 12:08 AM
01/22/16 12:08 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
NEVER PUT NEEDLE BEARINGS ON A RECIPROCATING SHAFT. EVER. Best answer yet.
[Re: Supercuda]
#1996107
01/22/16 03:18 AM
01/22/16 03:18 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I hate '2nd hand stories' of 'my buddy...'
But, I saw the damage first hand, does that count?
They failed. After not many miles. Maybe 1500? Motor was fairly mild too
**Photobucket sucks**
[Re: jb500]
#1996110
01/22/16 03:29 AM
01/22/16 03:29 AM
383man
Balt. Md
"Rocker shafts undersized for roller/needle bearings" ?? Can you elaborate? The shaft needs to be a true .8750 dia (can't recall tolerances) with a hardness in the upper 50's/lower 60's. The reason is to distribute the load evenly to all the needles (no slop) and the hardness is needed to prevent the rollers from digging into the shaft. I found out all this info after the needles in my 440S rockers let go. Stock OEM style shafts were supplied in my kit. To the OP: Remember....cheap parts cost less up front, but twice as much when they fail and even more to clean up the mess. Don't skimp on the rockers. I agree that its not good to scimp on valvetrain parts. I really like my Hughes rockers and shafts I use. They are only roller tipped rockers no needle bearings on the shaft and they have held up very good for me. With the more horror stories about the Source roller rockers I would use the ductile iron Crane or Isky rockers first as I used them for many years on some of my older builds and always had good luck with them. Ron
[Re: RapidRobert]
#1996164
01/22/16 09:37 AM
01/22/16 09:37 AM
Posts: 444 upstate NY
batt2rm
upstate NY
Wow getting some great help here guys, thanks! I guess I will look at the hughes rockers.
[Re: Tempest]
#1996213
01/22/16 12:27 PM
01/22/16 12:27 PM
Posts: 5,442 Indiana
YO7_A66
Indiana
Using the above picture, look at the spacing between the roller bearings on the top rocker. Now look at the spacing between the roller bearings on this attached picture. I have read that when going to a roller rocker, the more bearing count the better for the load. I have also read that when purchasing a roller bearing rocker, you need to purchase the shaft that is compatible with that bearing. As mentioned previously, the tolerances on the shaft must be held tighter on a roller bearing rocker.
I have seen "new" roller rockers for sale without shafts. They say to use existing shafts or can be used on stock shafts. This would scare me away from purchasing that rocker set. If I was to purchase a roller rocker set, I would want the shafts included.
Good thread!!
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
