Heater control valve line on water pump #1994944
01/20/16 03:46 PM
01/20/16 03:46 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
On my 440 engine I have two heater hose ports on the engine. One is smaller then the other. Which line does the heater Valve go to?
Re: Heater control valve line on water pump [Re: roy2345] #1995058
01/20/16 05:53 PM
01/20/16 05:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The smaller one is hot coolant out to the valve and the larger is return.
Re: Heater control valve line on water pump [Re: John_Kunkel] #1995064
01/20/16 06:01 PM
01/20/16 06:01 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Thank u sir!!
