Re: Another 440 cast vs forged crank debate
[Re: Joey Johnson]
#1994417
01/19/16 10:37 PM
01/19/16 10:37 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I think that a forged crank is in order at that hp level. Why didn't you just buy a full rotating kit from 440 source to start with? A stroker kit wouldn't have cost you any more than a standard 440 kit.
[image][/image]
[Re: Joey Johnson]
#1994460
01/19/16 11:11 PM
01/19/16 11:11 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Yes we all would prefer the steel crank over the cast but how many have you seen let go ?
My first race engine was, still is, a cast crank stock LY rod engine. It's been to hell running 11.00's for years and then high 9's on the bottle over a 150 times. it has a sleeve, 7 TRW pistons and 1 Manley that was shaped with a grinder to match the others, ran a best of 9.69 @ 135. The engine is still going hard in my sons Aussie A body N/A running 11.2.
I would say that a cast crank will be fine up to 600hp.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: GY3]
#1994469
01/19/16 11:16 PM
01/19/16 11:16 PM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
I've never had a problem with a cast crank. It was the stock, cast pistons that were my undoing! This made me laugh............a lot..........
Curator at Adams County Speed Shop
[Re: 340man4ever]
#1994576
01/20/16 12:53 AM
01/20/16 12:53 AM
Posts: 4,704 Wichita
GY3
Wichita
I've never had a problem with a cast crank. It was the stock, cast pistons that were my undoing! This made me laugh............a lot.......... The people that were following me when it went "boom" on US 54 and had to drive through the cloud of antifreeze probably weren't laughing...
[Re: ozymaxwedge]
#1994675
01/20/16 02:58 AM
01/20/16 02:58 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
You know if you could get that thing to hook up, it would accelerate a lot faster... Crazy Aussies! (I wanna be a tire salesman in Austrailia!)
[Re: Joey Johnson]
#1994892
01/20/16 02:27 PM
01/20/16 02:27 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
$250 for a stock forged crank that still needs machining??? Holy crap that's high! You ought to be able to find one cheaper than that!
Realistically, I think a cast may be fine for what you want to do, but I'd rather see a forged crank in a motor making that much power. You've already spent good money on a girdle, studs, etc. Get a forged crank and don't worry about it.
[Re: cudaman1969]
#1995073
01/20/16 06:19 PM
01/20/16 06:19 PM
Thumperdart
State of confusion
Jason Pettis found my 413 forged crank 13 years ago ready to drop in my 400 block for about $250 iirc w/chevy rod sizing.........
[Re: cudaman1969]
#1996633
01/22/16 10:22 PM
01/22/16 10:22 PM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
Should be a million of the steel 440 cranks laying around with everyone using strokers now, and cheap too. Like the guy above said, maybe $250 for a done crank. As said in the next post, RB steel cranks hold a premium to go into a B-motor budget stroker. At least $100 for a core that needs turned. $200 at a swapmeet.
[Re: Jerry Kathe]
#1996926
01/23/16 12:39 PM
01/23/16 12:39 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Not splitting hairs, but they are both steel....its not cast iron v/s forged steel. One starts out as a forged billet the other is a poured casting.
Consider this, if you are a budget build (say <500hp) or a just for fun test and tuner, it probably doesn't matter much. If you are hitting it fairly hard, or drive the stripe with the throttle pedal, you should probably stay away from cast. No they are not both steel one is iron and the other is steel its sort of like saying brass and bronze are the same
[Re: The Shadow]
#1997035
01/23/16 03:02 PM
01/23/16 03:02 PM
Jerry Kathe
Consider this, if you are a budget build (say <500hp) or a just for fun test and tuner, it probably doesn't matter much. If you are hitting it fairly hard, or drive the stripe with the throttle pedal, you should probably stay away from cast. No they are not both steel one is iron and the other is steel its sort of like saying brass and bronze are the same I dont remember the ASTM number right off , but here is a link you can refer to until I find or remember it....they ARE cast steel. Not totally relevant, but as in your comment - its like calling brass and bronze as the same. Bottom line, go forged. http://www.hotrod.com/how-to/engine/1405-how-to-tell-forged-crank-from-cast-spotters-guide/
[Re: The Shadow]
#1997187
01/23/16 06:49 PM
01/23/16 06:49 PM
Thumperdart
State of confusion
I know of a low 9-second n/a smallblock mopar w/a cast crank..........
[Re: Joey Johnson]
#1997266
01/23/16 09:18 PM
01/23/16 09:18 PM
sgcuda
Can a cast crank be used in a 600 hp combo? Sure. Build anything you want. Would "I" take a chance on it living, for that small of an investment? No way! I can't afford a billet crank, or an aftermarket block, but I would find a way to come up with $200.00 for a forged crank over cast. Machine work and balancing would be the same for either crank.
[image][/image]
[Re: The Shadow]
#1997270
01/23/16 09:22 PM
01/23/16 09:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Im not sure why hotrod is calling it steel? Its a ductile cast iron afik but hey I could be wrong I agree keep away for performance. They all start out as steel... forged are pounded to get a tighter density and to align the molecules.. the cast is just that.. cast and thats the end of it (other than the machining)
[Re: MR_P_BODY]
#1997330
01/23/16 10:39 PM
01/23/16 10:39 PM
Posts: 2,175 Duloc
The Shadow
Duloc
So they are not the same Cast Iron vs Cast Steel Firstly, let us know what is the cast iron and cast steel. Cast iron usually refers to gray iron, ductile iron and malleable iron, which is iron casting with carbon content upper than 2%. Cast steel usually refers to normal carbon steel and alloy steel, or called steel casting with carbon content lower than 2%. Therefore, no big difference considering from the chemical content and raw materials for cast iron vs cast steel. However, their physical properties have many differences. The advantage and disadvantage of cast iron. The grey cast iron has good casting properties, good vibration damping, good wear resistance, good machinability and low notch sensitivity. However, its tensile strength and elongation are very low, so only can produce some metal parts with low physical requirements, such as protective cover, cover, oil pan, hand wheels, frame, floor, hammer, small handle, base, frame, box, knife, bed, bearing seat, table, wheels, cover, pump, valve, pipe, flywheel, motor blocks etc. As for the higher grades, grey cast iron can withstand greater load and a certain degree of tightness or corrosion resistance of the more important castings such as cylinder, gear, base, flywheels, bed, cylinder block, cylinder liner, piston, gear box, brake wheel, coupling Plate, medium pressure valve, etc. refer to iron-foundry.com. The ductile iron and malleable iron have high strength, ductility, heat-resistance and toughness, so a wider application, in some cases can replace the carbon steel. However, its production technology is high, production process is more complex, and production cost is higher than normal grey cast iron and cast steel, therefore, there are more casting defects for ductile iron. There are many fields that ductile iron are using for, such as Pressure pipes and fittings, Automotive applications, Agriculture, road and construction applications, General engineering applications. The advantage and disadvantage of cast steel. One of the advantages of cast steel is the design flexibility, the designer of the casting have the greatest freedom of design choices, especially the complex shape and hollow cross-section parts. Cast steel has the metallurgy manufacturing flexibility and strongest variability, you can choose a different chemical composition and control, adapted to the various requirements of different projects. By different heat treatment choice in the larger context of the mechanical properties and performance, and good weldability and workability. Cast steel is a kind of isotropic material and can be made into the overall structural strength steel castings, thereby improving the reliability of the project. Coupled with the design and weight the advantages of short delivery time, price and economy has a competitive advantage. The weight range of steel castings is larger. Little weight can be only a few dozen grams of molten mold precision castings, and the weight of large steel castings up to several tons, dozens of tons or hundreds of tons. Steel castings can be used for a variety of working conditions, and its mechanical properties superior to any other casting alloys, and a variety of high-alloy steel for special purposes. To withstand high tensile stress or dynamic load of components, it is important pressure vessel castings in low or high temperature by the large and important part load key parts, in principle, should give priority to steel castings. However, the cast steel has comparatively bad shake-suction, wear resistance, mobility and the casting performance are compared bad with cast iron, moreover, the costs are higher than normal cast iron.
[Re: The Shadow]
#1997386
01/23/16 11:50 PM
01/23/16 11:50 PM
MR_P_BODY
Crankshaft Materials … Crankshafts materials should be readily shaped, machined and heat-treated, and have adequate strength, toughness, hardness, and high fatigue strength. The crankshaft are manufactured from steel either by forging or casting. The main bearing and connecting rod bearing liners are made of babbitt, a tin and lead alloy. Forged crankshafts are stronger than the cast crankshafts, but are more expensive. Forged crankshafts are made from SAE 1045 or similar type steel. Forging makes a very dense, tough shaft with a grain running parallel to the principal stress direction. Crankshafts are cast in steel, modular iron or malleable iron. The major advantage of the casting process is that crankshaft material and machining costs are reduced because the crankshaft may be made close to the required shape and size including counterweights. Cast crankshafts can handle loads from all directions as the metal grain structure is uniform and random throughout. Counterweights on cast crankshafts are slightly larger than counterweights on a forged crankshafts because the cast metal is less dense and therefore somewhat lighter. Generally automobile crankshafts were forged in past to have all the desirable properties. However, with the evolution of the nodular cast irons and improvements in foundry techniques, cast crankshafts are now preferred for moderate loads. Only for heavy duty applications forged shafts are favoured. The selection of crankshaft materials and heat treatments for various applications are as follows.
[Re: Joey Johnson]
#1997474
01/24/16 01:56 AM
01/24/16 01:56 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Spend the small amount of extra money and get a forged crank.
[Re: Twostick]
#1997611
01/24/16 12:49 PM
01/24/16 12:49 PM
MR_P_BODY
A buddy of mine used to race FE Fords in the 70's. He started using cast cranks because they were lighter and figured that was an advantage. He used to break forged FE cranks. According to him he never broke a cast one.
I saw a quote from Joe Sherman in Hotrod many years ago. At the time he was building some pretty stout SB 400's. He said that forged cranks were for people that couldn't sleep at night.
Kevin My buddy races his 52 ford PU with w 460 BBF.. he sprays it also... the journals on that crank are huge.... its a cast one... and HEAVY
[Re: MR_P_BODY]
#1997622
01/24/16 01:05 PM
01/24/16 01:05 PM
Posts: 8,354 fredericksburg,va
cudaman1969
fredericksburg,va
Kevin My buddy races his 52 ford PU with w 460 BBF.. he sprays it also... the journals on that crank are huge.... its a cast one... and HEAVY And when they come apart they Come apart! The 460 blew and the crank "parts" where in the pan, snout and flex plate flange where the biggest pieces with the rods hanging onto there parts, never saw anything like that before. But it was making about 700 hp and had 400 or more passes.
