Re: Spark plug gap with MSD
[Re: Monte_Smith]
#1995249
01/21/16 12:24 AM
01/21/16 12:24 AM
Posts: 7,506 Az
Crizila
Az
I read what you said, but I thought you might give some actual facts or results to back up your claim, as nothing you said made sense..........but obviously you don't understand ignition systems nor electricity. It's also been proven time and time again, that tighter gaps make better power and eat less ignition parts or a race car.
Fuel cars run two plugs, because they run two Mags and nitro is impossibly hard to light under boost. And they run really tight gaps
Pump gas hard to light......really?........Guess that's why it detonates so easily, because it's hard to light.
Oh, sorry I left out the "ple" when I stated that MSD stood for Multi Spark Discharge, but they mean the same thing I gave you actual facts and you referred to them as old wives tales, when in actuality, you couldn't relate to what I said. Getting in to a pizzing contest with you ( and close minded people like you )is a waste of MY time. BTW, fuel cars do run a tight plug gap - but IT'S THE LARGEST GAP THEY CAN GET AWAY WITH! Light bulb come on yet???
Fastest 300
[Re: madscientist]
#1995267
01/21/16 12:50 AM
01/21/16 12:50 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use .035... I did try larger but it didnt do anything.. as said already.. a large gap is load on the ignition system which can break stuff
[Re: MR_P_BODY]
#1995304
01/21/16 01:50 AM
01/21/16 01:50 AM
Posts: 3,519 pacific northwest
Stroker Scamp
pacific northwest
.035 here MSD 6 AL, Blaster coil, firecore wires, NGK plug
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: MR_P_BODY]
#1995338
01/21/16 02:38 AM
01/21/16 02:38 AM
Posts: 7,506 Az
Crizila
Az
I use .035... I did try larger but it didnt do anything.. as said already.. a large gap is load on the ignition system which can break stuff I will say it one last time. You wanna run the largest gap you can get away with AND STILL BE ABLE TO LIGHT THE PLUGS - what ever that # might be. In your case, it was probably .035" I have an ignition system that is easily capable of 55K+ open voltage. Seen it on a scope. I run lots of boost - 21 psi in the lights. I also spray some water. Can't run gaps wider than .030" in that application. Ran the same ignition in a NA motor I was running. Could easily run .045 gap with no problem - and I did! In that application, why would I want to run a plug gap of .030"??? For more HP??? No way! Like everything else we do with race engines, you want to make full use of what you spent your hard earned $ on - because it equates to more HP. If you want to make full use of that big $ ignition system you bought, you should be using all of it. We do that with every other component in the engine. If you are concerned about putting undo load on stuff or breaking stuff, you are in the wrong hobby. The scenario I previously gave about the smog era and improved ignition systems is an example of why a higher voltage, larger spark, and longer ( in duration ) spark is better. Has nothing to do with the quality of the fuel, but with the extremely lean ratios coupled with the infusion of exhaust gas ( EGR) to control NOX - to meet emissions. Conventional ignition systems of the day couldn't lite it. Welcome to HEI! Higher voltage, longer duration (MSD )and bigger plug gaps COULD light it. No matter what causes a poor environment for lighting the fuel in your combustion chamber ( lean, rich, high CR, boost, N20, etc), higher voltage, larger spark, longer duration is always the better way to go. Hence my comment to the OP, " you want to run the largest plug gap you can and still be able to light the plugs".
Fastest 300
[Re: Crizila]
#1995347
01/21/16 02:52 AM
01/21/16 02:52 AM
MR_P_BODY
What does it take for you... I said I tried larger gaps and seen ZERO change in ET or MPH... that was from a .025 to .060.. in .005 increments... you can run what ever floats your boat.. I use .035 now and have for a long time now... my 7AL makes the 55K+ and I have seen it on a scope also EDIT Maybe you play with emissions... I dont on any of my cars that I race
[Re: The Sphinx]
#1995355
01/21/16 03:12 AM
01/21/16 03:12 AM
Posts: 102 Australia
Project kickin A
Australia
std stroke 446 with MSD 7 with a 16 volt battery 11.6 to 1, ran .035 liked it... tried .040 didn't like it so much but still ran hard, was told I should run .018 didn't like that at all so went back to .035, next I will test ,032 and see.
[Re: The Sphinx]
#1995391
01/21/16 08:50 AM
01/21/16 08:50 AM
Jerry Kathe
[Re: The Sphinx]
#1995455
01/21/16 12:30 PM
01/21/16 12:30 PM
Posts: 4,219 New York
polyspheric
New York
Mag gap isn't relevant, they produce very little voltage at cranking speed and wouldn't start without a small gap.
Boffin Emeritus
[Re: Crizila]
#1995479
01/21/16 01:17 PM
01/21/16 01:17 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Oh, sorry I left out the "ple" when I stated that MSD stood for Multi Spark Discharge, but they mean the same thing I gave you actual facts and you referred to them as old wives tales, when in actuality, you couldn't relate to what I said. Getting in to a pizzing contest with you ( and close minded people like you )is a waste of MY time. BTW, fuel cars do run a tight plug gap - but IT'S THE LARGEST GAP THEY CAN GET AWAY WITH! Light bulb come on yet??? Your argument is STILL based on "because I say so". You have given no facts, only your opinion and related things about new cars, which has zero bearing on the subject. While there have been several that claimed smaller gaps gave greater power......your reply is "you had something else wrong". Again, that's a "because I say so" argument. And earlier, when I asked you to elaborate, I didn't see the post where somebody had already asked you to do the same and your answer to them. It didn't come up on my screen for whatever reason. Guess I hadn't refreshed the browser. But anyway, you got defensive and decided to be a smart azz about it, when I just wanted to see your reasoning.
[Re: Monte_Smith]
#1995505
01/21/16 02:20 PM
01/21/16 02:20 PM
Posts: 8,166 Left Coast
BobR
Left Coast
If you can lightem, the wider the better. Why?..........care to elaborate?.......In truth, all the wide gap does is force your ignition components to work way TOO hard to jump that gap. It does ZERO to make any more power or fire the mixture easier. The big gap stuff is just an old wives tale from the days of points ignitions........Why, because points firing was ONE spark, so let it jump as far as it can and it has a better chance of lighting..........MSD, stands for MULTI Spark Discharge. Gap is meaningless. We run some REAL high cylinder pressure stuff at as little gap as .010. If it will light that, if will surely light your 10.1 street motor at .035 without issue With a magneto and 50+ pounds of boost our gap is .014.
[Re: Monte_Smith]
#1995554
01/21/16 03:49 PM
01/21/16 03:49 PM
Posts: 7,506 Az
Crizila
Az
Oh, sorry I left out the "ple" when I stated that MSD stood for Multi Spark Discharge, but they mean the same thing I gave you actual facts and you referred to them as old wives tales, when in actuality, you couldn't relate to what I said. Getting in to a pizzing contest with you ( and close minded people like you )is a waste of MY time. BTW, fuel cars do run a tight plug gap - but IT'S THE LARGEST GAP THEY CAN GET AWAY WITH! Light bulb come on yet??? Your argument is STILL based on "because I say so". You have given no facts, only your opinion and related things about new cars, which has zero bearing on the subject. While there have been several that claimed smaller gaps gave greater power......your reply is "you had something else wrong". Again, that's a "because I say so" argument. And earlier, when I asked you to elaborate, I didn't see the post where somebody had already asked you to do the same and your answer to them. It didn't come up on my screen for whatever reason. Guess I hadn't refreshed the browser. But anyway, you got defensive and decided to be a smart azz about it, when I just wanted to see your reasoning. You started the smart azz crap Mr "oldwives tale". That comment was unnecessary and to quote YOU, " has zero bearing on the subject". I can give you as many claims for a wider gap as you can for a smaller gap. Here are two from a very reputable source ( which I will not divulge - including his age). "Insufficient gap can cause pre-ignition, detonation, and engine damage." " A larger spark to the A/F mixture maximizes burn efficiency". Claims and opinions are just that. So are facts for that matter. We all have opinions, and YOU probably have one of the largest OPINIONS on this web sight!!
Fastest 300
[Re: The Sphinx]
#1995723
01/21/16 07:05 PM
01/21/16 07:05 PM
Posts: 12,318 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
This conversation reminds me of the old time spark plug cleaner/tester machines. You could clean the plug and then test it by screwing it into a sealed chamber in the machine, hooking an ignition lead to it, and pressing a button to make the plug fire. Look in the window and turn up the air pressure until it blew the spark out like blowing out a candle. Higher pressure = harder to get it to fire. Only 2 options, turn up the voltage or tighten the gap.
My gaps have tightened up quite a bit over the years.
[Re: The Sphinx]
#1995876
01/21/16 10:02 PM
01/21/16 10:02 PM
Posts: 591 Champion City
The Sphinx
Champion City
After doing some more reading on the web, plus im hitting it with a 100 shot of nitrous,Im going to stick with .035. Thanks everyone
BTW this car is race only, never to see the street
[Re: The Sphinx]
#1995941
01/21/16 10:59 PM
01/21/16 10:59 PM
Posts: 4,457 Washington
madscientist
Washington
BTW this car is race only, never to see the street I would start at .035 and close it up until it slows down. Also you SHOULD be using a racing plug, and they have cut back ground wires, which effectively opens the gap without increasing it.
[Re: 70HemiGTX]
#1996032
01/22/16 12:44 AM
01/22/16 12:44 AM
Monte_Smith
North Alabama
Today I happened to pick up an old (OLD from the early 90's) magazine. Can't even remember what is was. I think maybe Popular Hotrodding, but not sure. They had a story on different "performance tips". One was spark plug gaps. It said for Supercharged/Nitrous engines like .020 - .022 and high compression engines .022 - .025. They didn't mention MSD or anything like that so I'm figuring they were using old style electronic or points. Remember this was the early 90's.
I can see their point of close gaps. "Quicker" spark and probably a "shorter/fatter" spark.
That's just my take on their theory. Is it right or wrong? ????? Here is the thing about modern ignition systems. It puts out, what it puts out. You can make spark jump a mile, but it will be no hotter and no more intense. It just is what it is. And as already covered, the MSD is a multi(ple) spark discharge, meaning you get more than a single pulse of spark per event. You get multiple sparks. An MSD is also a CD ignition, meaning capacitive discharge, which produces a VERY high spark voltage, by charging the coil quickly with high power. A digital 7 for example, produces 190 millijoules per spark. CD ignitions, while hot, produce a very short burst and that is why the Multi spark concept was designed. If the arc time is short, just make a lot of them. Factory cars on the other hand, have "induction" type ignition systems and always have, which means the fire is relative to the saturation time on the coils and is a single spark. That's why old schools coils are so big. More windings, more saturation, more energy. The problem with induction ignition, is dwell time to charge the coil. Whats good at low speed, is not good at high speed, so it's a compromise at best and can't be adjusted. If you remember points days, the number was generally 32* of dwell. That's a compromise, because at low speed 15* would be better and at high speed 60* would be, but we couldn't do that. This is where HEI came in. It is basically a little computer that adjusts dwell time in relation to rpm, but it had a small range of about 15-40*. But ALL inductive systems still suffer from a thing called "roll off". Which means as rpm increases the saturation time on the coil gets too short to be efficient and spark energy gets weak. Now that ignition basics and how it works are covered......do we want to talk about coils. Because the box is the box and makes the power it makes. It's ONE and ONLY job is to charge the coil. The COIL is what delivers the energy to the dist and or plugs and they come in various styles. Some have very quick peak energy and some have sustained energy. So as with any other part of a car, the TOTAL SYSTEM is what matters, not one individual component. Right box, wrong coil..the system won't work well.
