Re: Spark plug gap with MSD
[Re: The Sphinx]
#1993496
01/18/16 07:12 PM
01/18/16 07:12 PM
Posts: 4,457 Washington
madscientist
Washington
It depends. But I almost never go over .040 and most of the time I'm at .030-.035. I've gone lower than that with powere adders.
Generally, if you can go over .040 you have low compression, small cam, stocker type components.
[Re: The Sphinx]
#1993515
01/18/16 07:39 PM
01/18/16 07:39 PM
Posts: 43,741 Bend,OR USA
Cab_Burge
Good luck on that digital six living AKA, the plug gap is determined by many things, compression ratio,intended upper RPM limit, fuel type and most important is the spark plug wire type I've never used any of the street and strip MSD boxes so I've never read the instruction for them, does it say to use resistor type plug wires only? If so does it say to use spiral wound outer solid wire around the center core? If not use the ones you like the best, same thing if it does say to use the more expensive race spiral wound type wires If you want to find the best gap for your current combination start off at .055 and drive it, if you like it and you want to test and experiment try .065 and so on upwards until it starts to miss at the upper RPM If it misses at .055 close it down to .045 and see if that is the best gap for your combination Let us know what you do
[Re: The Sphinx]
#1993665
01/18/16 10:25 PM
01/18/16 10:25 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have been running my Digital 6 for 5 years also and I have only ran my gap at .035. MSD distributor and MSD wires.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: The Sphinx]
#1993792
01/19/16 12:40 AM
01/19/16 12:40 AM
Cab_Burge
[Re: The Sphinx]
#1993846
01/19/16 01:36 AM
01/19/16 01:36 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Come on, Cab.... First it's "good luck with the D6+", then later it's "I've never run an MSD street-strip ignition"..... I'll consider that opinion baseless. I've been running my D6+ box for 6 or 7 years with no issue.
I run MSD's suggestion of a .055 gap; no issue with caps, wires, plugs.... figure they know more about ignition than I do. My guess is that's true for just about anyone here as well. If you're gonna run their product, might as well take their advice on how to run it.
[Re: StealthWedge67]
#1993895
01/19/16 03:21 AM
01/19/16 03:21 AM
Posts: 1,115 Massillon, Ohio
cudatom
Massillon, Ohio
I run MSD's suggestion of a .055 gap; no issue with caps, wires, plugs.... figure they know more about ignition than I do. My guess is that's true for just about anyone here as well. If you're gonna run their product, might as well take their advice on how to run it. I have been using MSD products since the the late 70's. W/each unit I tried to run the gap as suggested. All the engines ran better w/a much tighter gap. On my street engines I typically ran .40 on my strip engines usually .35 but on some closer to .30. I had better plug life and performance. I understand that the manufacture may suggest one thing but that is a general recommendation not an absolute. By the way very nice 67.
Ok
[Re: The Sphinx]
#1993921
01/19/16 09:05 AM
01/19/16 09:05 AM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
For what's worth my digital six box caught on fire during drag week 2014, while I was going down the road.
That same year I spoke with msd tech on sight because my spare digital box had a high end misfire. He claimed large gaps did nothing but make your ignition work harder and there was little if anything to gain. I got a little frustrated with their products and dropped them all together.
68 Barracuda Formula S 340
[Re: The Sphinx]
#1993948
01/19/16 11:02 AM
01/19/16 11:02 AM
crabman173
crabman173
.055 is too much and just not needed Less issues with tighter gaps--.035-.040 will do just fine with any plug/wire combo
If you take a lawn mower in because it will not start they close the gap and she fires right up
I run a .017 gap with my alky injected with Vertex mag always fires at the plug and not somewhere else--runs great!
Close your gap car will run better!
[Re: ]
#1993975
01/19/16 11:51 AM
01/19/16 11:51 AM
Posts: 7,506 Az
Crizila
Az
---and the average is ---- .042".
Fastest 300
[Re: Crizila]
#1993983
01/19/16 12:06 PM
01/19/16 12:06 PM
Posts: 8,166 Left Coast
BobR
Left Coast
---and the average is ---- .042". When I ran my 340 Duster in stock eliminator with a 7al any gap larger than .045 slowed the car down. I ran it at .035.
[Re: The Sphinx]
#1994100
01/19/16 03:04 PM
01/19/16 03:04 PM
Posts: 4,332 Morrow, OH
markz528
Morrow, OH
My advice is stay on the lower side. As stated, wide gap is not needed.
I ran 0.042 inch gap with a 7AL2 and old small coil. 14:1 compression. Installed a MSD heavy duty (high output) coil and preceded to waste several distributor caps as the center electrode was overheating. Changed to 0.030 inch gap and all good.
[Re: markz528]
#1994101
01/19/16 03:06 PM
01/19/16 03:06 PM
Thumperdart
State of confusion
Yep, and I`m on my second MSD 6200 box in 20+ years.............
