trans trouble #1993100
01/18/16 01:58 AM
01/18/16 01:58 AM
florida dade
cesar perez Offline OP
florida dade
I had my t/f rebuilt and trans brake installed I I installed the trans and now the trans does not move forward or backwards any hints what could it be. don't want to remove trans
Re: trans trouble [Re: cesar perez] #1993102
01/18/16 02:02 AM
01/18/16 02:02 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Check the fluid level.
Re: trans trouble [Re: cesar perez] #1993113
01/18/16 02:37 AM
01/18/16 02:37 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
is the converter installed correctly...did the hub engage the pump?
Tony
70 AARCuda Vitamin C
Re: trans trouble [Re: cesar perez] #1993193
01/18/16 10:54 AM
01/18/16 10:54 AM
NC
440Jim Offline
440Jim  Offline
NC
Put a pressure gauge on it. See tech manual.
Re: trans trouble [Re: cesar perez] #1993213
01/18/16 11:31 AM
01/18/16 11:31 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Check the dipstick level not running. Then start it and check in nuetral. If the level didn't go down the pump most likely is broken.
Doug
