Re: Adding part-throttle kickdown to earlier VB? [Re: John_Kunkel] #199020
01/24/09 07:09 PM
01/24/09 07:09 PM
Mass
charge70 Offline
charge70  Offline
Mass
E-bay vendor T'Flite Patty usually has the PTK modules available.
http://stores.ebay.com/TFlite-Pattys-Shop-Mart
Let me repeat, the limit valve won't function when retrofit to a pre-'71 valve body.
John, when you install the late PTK module on a 70 & older valvebody will it still function as a part throttle kickdown w/o the limit feature or will it not function at all.Thanks for all the help. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Adding part-throttle kickdown to earlier VB? [Re: charge70] #199021
01/24/09 08:11 PM
01/24/09 08:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '71 and later module will still function as a PTK when installed on a '70 or earlier VB but the limit function won't work.
Re: Adding part-throttle kickdown to earlier VB? *DELETED* [Re: 70Duster440] #199022
12/30/09 12:22 PM
12/30/09 12:22 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Post deleted by dkn1997
Re: Adding part-throttle kickdown to earlier VB? *DELETED* [Re: Pool Fixer] #199023
12/30/09 12:27 PM
12/30/09 12:27 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Re: Adding part-throttle kickdown to earlier VB? [Re: Pool Fixer] #199024
12/30/09 12:42 PM
12/30/09 12:42 PM
San Gabriel, CA 91775
rexus31 Offline
rexus31  Offline
Is there a PTK application for a '65 TF?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: Adding part-throttle kickdown to earlier VB? [Re: rexus31] #199025
12/30/09 02:28 PM
12/30/09 02:28 PM
scratchnfotraction Offline
Re: Adding part-throttle kickdown to earlier VB? [Re: rexus31] #199026
12/30/09 11:46 PM
12/30/09 11:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The PTK module won't work on pre-'67.
There is, however, a way to mod the early VB to accept the PTK...this involves using a '67-'68 VB main casting (which still has provisions for the rear pump check valve) and bushing the roostercomb hole down to 5/16" to accept the pre-'66 throttle shaft, then the '65 roostercomb will fit the '67-'68 VB.
The pic below shows the '67-'68 casting that can be used, the check valve provision is in the top right corner of each casting.
Re: Adding part-throttle kickdown to earlier VB? [Re: John_Kunkel] #199027
12/30/09 11:54 PM
12/30/09 11:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The roostercomb hole bushing.
Re: Adding part-throttle kickdown to earlier VB? [Re: John_Kunkel] #199028
12/31/09 11:38 AM
12/31/09 11:38 AM
Re: Adding part-throttle kickdown to earlier VB? [Re: charge70] #199029
12/31/09 03:26 PM
12/31/09 03:26 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
They have great prices also...
http://cgi.ebay.com/ebaymotors/MOPAR-Tor...s#ht_500wt_1182
