Adding part-throttle kickdown to earlier VB? #199000
01/20/09 03:51 PM
01/20/09 03:51 PM
Washington State
70Duster440 Offline OP
Washington State
I've got a '68 727 with TF2 kit. Converter stalls at about 2500-2800. Shifts fine. Full-throttle kickdown works fine.
At slow speeds, under a load (such as turning up an incline) it stays in 3rd and essentially becomes a dog unless I mash the throttle or manually downshift.
Is it possible to add part-throttle kickdown without changing the VB?
This guy promises an amazing transformation with a mod that costs as much as a new VB: http://www.brauerengineering.com/trans/index.htm
Re: Adding part-throttle kickdown to earlier VB? [Re: 70Duster440] #199001
01/20/09 04:56 PM
01/20/09 04:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
PTK can be added to any '67 or later 727/904 VB, just replace the cover plate with the PTK module. When installing the early version of the PTK one screw must be changed to a thinner head to clear the casting.
Re: Adding part-throttle kickdown to earlier VB? [Re: John_Kunkel] #199002
01/20/09 05:11 PM
01/20/09 05:11 PM
Washington State
Washington State
Cool - thanks, John. I've got a later VB I can steal the PTK parts from.
Is it also true that if you decrease the space between the kickdown valve and the throttle pressure cam that it will downshift at a higher "closed throttle" condition? If so, is this a good or bad thing?
Re: Adding part-throttle kickdown to earlier VB? [Re: 70Duster440] #199003
01/21/09 08:37 PM
01/21/09 08:37 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Erik's valve bodies are quite amazing. Have one in everything I own that is TF equipped except for one. He's a little hard to get ahold of these days but if you can, it's well worth it. His mods are completely different than any off the shelf kit as he epoxies certain passages to make the VB do what he wants. Can't wait till I can get him out to do the last one!
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Adding part-throttle kickdown to earlier VB? [Re: 70Duster440] #199004
01/22/09 01:14 PM
01/22/09 01:14 PM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
I'm confused here. Is there a Part throttle kickdown AND a Full throttle kickdown or are they one and the same?? I'm asking because I recently changed to a higher stall converter and while shift points are good, kickdown doesn't come in exactly where I want it since rpm is a little higher. linkage adjusted to get great shift points up come down a little late. before converter swap, kickdown came in at a better point
thanks
Re: Adding part-throttle kickdown to earlier VB? [Re: solarguy] #199005
01/22/09 01:20 PM
01/22/09 01:20 PM
I'm confused here. Is there a Part throttle kickdown AND a Full throttle kickdown or are they one and the same?? thanks
different EDIT the full throttle KD would come from the kickdown lever moved all(or most of the way)back at full throttle & part throttle KB would come about from the right combo of valves/springs or the addition of the cover that Kunkel showed.
Re: Adding part-throttle kickdown to earlier VB? [Re: RapidRobert] #199006
01/22/09 01:32 PM
01/22/09 01:32 PM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
So let me guess Robert, if I have to floor it to downshift from 3 to 2, that would be FULL throttle kickdown? Part throttle would just require less than full throttle deployment?
If thats the case, I'm going looking for a differnt valve body.
Re: Adding part-throttle kickdown to earlier VB? [Re: solarguy] #199007
01/22/09 01:34 PM
01/22/09 01:34 PM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
posted after your edit, gotcha
Re: Adding part-throttle kickdown to earlier VB? [Re: solarguy] #199008
01/22/09 03:42 PM
01/22/09 03:42 PM
You might consult with someone about modifying the valve/springs in your current VB. You wouldn't want to buy another one & have it not give you what you want for the PTK to be lower
Re: Adding part-throttle kickdown to earlier VB? [Re: 70Duster440] #199009
01/22/09 10:51 PM
01/22/09 10:51 PM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
Mopar action aug 1998 had an article on this.I have both 68-70,and 70-up PTKs,PM if interested
Re: Adding part-throttle kickdown to earlier VB? [Re: RapidRobert] #199010
01/23/09 04:49 PM
01/23/09 04:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The early PTK like the one pictured in my original reply has no limit valve, depending on the axle ratio the PTK can occur at some pretty high road speeds and this can be annoying. My '57 NY with 2.94 gears will still PTK at 60 mph.
The '71 and later PTK module contains a limit valve and spring to limit the PTK to below 40 mph but the limit function won't work when retrofitting the '71 and later module to the earlier VB. The only way to get the limit feature in an earlier trans is to swap in the entire VB.
Re: Adding part-throttle kickdown to earlier VB? [Re: John_Kunkel] #199011
01/23/09 07:56 PM
01/23/09 07:56 PM
Washington State
Washington State
So John, which PTK module below would be best for a '68 VB? I have an old lockup VB that has the upper one that I was going to steal.
Also, is it true that if you decrease the space between the kickdown valve and the throttle pressure cam that it will downshift at a higher "closed throttle" condition? If so, is this a good or bad thing?
Re: Adding part-throttle kickdown to earlier VB? [Re: 70Duster440] #199012
01/23/09 08:23 PM
01/23/09 08:23 PM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
70Duster440, do you have a part number and source for those prepackaged modules?
Re: Adding part-throttle kickdown to earlier VB? [Re: 70Duster440] #199013
01/23/09 08:49 PM
01/23/09 08:49 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
"Also, is it true that if you decrease the space between the kickdown valve and the throttle pressure cam that it will downshift at a higher "closed throttle" condition?""
Bump
Re: Adding part-throttle kickdown to earlier VB? [Re: 70Duster440] #199014
01/23/09 08:53 PM
01/23/09 08:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The lower one, the limit valve won't function in a '68.
Not unless you make it real tight. There is no advantage.
Re: Adding part-throttle kickdown to earlier VB? [Re: solarguy] #199015
01/23/09 09:47 PM
01/23/09 09:47 PM
Washington State
Washington State
Sorry, I don't. Sounds like bigslant6fan (above) might though.
Re: Adding part-throttle kickdown to earlier VB? [Re: solarguy] #199016
01/23/09 11:15 PM
01/23/09 11:15 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
http://www.aandatrans.com/Products/727-3-2-Kick-Down-Module-(1966-69)__22740-32SI.aspx
Re: Adding part-throttle kickdown to earlier VB? [Re: BSB67] #199017
01/24/09 09:14 AM
01/24/09 09:14 AM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
Thanks for that link, I had seeen that one but was actually looking for the later model one with the limit valve.
Re: Adding part-throttle kickdown to earlier VB? [Re: 70Duster440] #199018
01/24/09 03:52 PM
01/24/09 03:52 PM
Taneytown, MD
Taneytown, MD
sorry I don,t,all mine are used,and the square type doesn,t even have any casting nos.
Re: Adding part-throttle kickdown to earlier VB? [Re: solarguy] #199019
01/24/09 05:32 PM
01/24/09 05:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
E-bay vendor T'Flite Patty usually has the PTK modules available.
http://stores.ebay.com/TFlite-Pattys-Shop-Mart
Let me repeat, the limit valve won't function when retrofit to a pre-'71 valve body.
