Fusible link under dash? #1987427
01/10/16 10:01 AM
01/10/16 10:01 AM
Connecticut
W
wayno56 Offline OP
wayno56  Offline OP
W
Connecticut
I have a 70 Challenger that has a fusible link connected to the red wire under the dash and don't see where it would connect. It has the same lug and connector on it as the one on the starter relay. Not sure if this is supposed to be there as the wiring diagram in the service does not show it. Any help would be appreciated.
Re: Fusible link under dash? [Re: wayno56] #1987440
01/10/16 11:18 AM
01/10/16 11:18 AM
IN
ahy Offline
ahy  Offline
IN
Sounds like it was added. On my '70 the fusible link was under hood. In general, the link protects from overloads/shorts from the main power sources: battery and alternator. Both are under hood so I wouldn't see benefit from a link in the cab.
Perhaps there was a mishap in the past... especially good idea to check main power connections at the bulkhead, ammeter (if equipped) and in cab column connectors.
Also worth mentioning the 1/4" blade connector is a weak spot on OE links. On my re-pop harness, I replaced the blade with two eyes and a bolt + tape after a connection failure.
Re: Fusible link under dash? [Re: wayno56] #1987468
01/10/16 12:29 PM
01/10/16 12:29 PM
NC
1970A66 Offline
1970A66  Offline
NC
This would be correct for a 70 Challenger:
http://www.linric.com/challenger/Assembly2-1.jpg
Re: Fusible link under dash? [Re: 1970A66] #1987540
01/10/16 01:54 PM
01/10/16 01:54 PM
Connecticut
W
wayno56 Offline OP
wayno56  Offline OP
W
Connecticut
Yes that is how my engine compartment is wired. I'm trying to insert a photo but am not having any luck.
Re: Fusible link under dash? [Re: wayno56] #1987888
01/10/16 08:43 PM
01/10/16 08:43 PM
NC
1970A66 Offline
1970A66  Offline
NC
There was no factory fusible link under the dash on a 70 Challenger. The fusible link coming off your starter relay goes to the ammeter.
Who knows why someone added one at your dash............
