Re: ***UPDATE ON 440 SOURCE HEADED STROKER*** [Re: RobX4406] #198738
01/20/09 11:39 PM
01/20/09 11:39 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I did. Is there another something I should look at?
Re: ***UPDATE ON 440 SOURCE HEADED STROKER*** [Re: goldmember] #198739
01/20/09 11:53 PM
01/20/09 11:53 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Maybe 5252?
Damon
Re: ***UPDATE ON 440 SOURCE HEADED STROKER*** [Re: goldmember] #198740
01/20/09 11:54 PM
01/20/09 11:54 PM
AndyF Offline
AndyF  Offline
They cross at the right spot. Both are around 530 in the 5250 range. You just have to study the screen for a moment to see it.
Re: ***UPDATE ON 440 SOURCE HEADED STROKER*** [Re: AndyF] #198741
01/21/09 12:12 AM
01/21/09 12:12 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
OK
Re: ***UPDATE ON 440 SOURCE HEADED STROKER*** [Re: Brian Hafliger] #198742
01/21/09 02:33 AM
01/21/09 02:33 AM
SoCal
Brian Hafliger Offline OP
SoCal
Brian Hafliger
Re: ***UPDATE ON 440 SOURCE HEADED STROKER*** [Re: Brian Hafliger] #198743
01/21/09 02:52 AM
01/21/09 02:52 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Cool vid,,sounds really good!
Re: ***UPDATE ON 440 SOURCE HEADED STROKER*** [Re: Brian Hafliger] #198744
01/21/09 02:55 AM
01/21/09 02:55 AM
Utah
topbrent Offline
topbrent  Offline
Utah
This may be a silly question, but what kind of fuel economy could one expect out of something like that.
For example...if it were installed in a 1976 3/4 ton truck.
That massive tq curve and small cam would allow you to keep your foot out of the throttle when towing up big grades.
Re: ***UPDATE ON 440 SOURCE HEADED STROKER*** [Re: topbrent] #198745
01/21/09 03:31 AM
01/21/09 03:31 AM
SoCal
SoCal
Funny you should bring this up. Carl, my customer was joking about the "racing" carb I told him to run on this engine. He likes oem stuff so anyways...with some load on the engine at 2300rpm, fuel flow was pretty low. I would imagine your right, but it would depend on the rpm of the engine at your typical cruise speed as to just how much fuel the engine will consume.
I can tell you with a smaller carb than this one, and tuned sharply, fuel mileage might not be so bad...but when you floor it....fogetaboutit
Re: ***UPDATE ON 440 SOURCE HEADED STROKER*** [Re: goldmember] #198746
01/21/09 10:45 AM
01/21/09 10:45 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
"Why are the torque and hp crossing paths at 4300rpm?"
Because they are using 2 different scales for the HP and TQ.
