Re: Hot Rod Drag Week 2015: The Experience.
[Re: MoparBilly]
#1989768
01/13/16 10:20 AM
01/13/16 10:20 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
The only difference between Dale's launch of the Gremlin at Great Lakes as opposed to the first two days, was that he knew what was coming. It spun just as hard at the hit of the second stage of nitrous, then pushed itself out of the groove, but he pedaled and recovered much quicker with the knowledge of what to expect. From my vantage point four sets of cars back, it looked like a decent pass, and I was expecting another 9.0 at a buck fifty. The 9.26-141 was a little concerning, but with two aggressive stages fed by a common line and a single bottle, usually anytime his mph falls off it simply means he was running out of spray.
Rachael was in the next pair, and I knew the chances of her not having enough nitrous in the current bottle was pretty good, as she had made her previous three runs on it, and I had used it for a half pass in Vegas. When she went 12.35-111, I figured it was the bottle, but it trailed a good bit of blue smoke in the shutdown, and I was reminded of listening to the engine with Robert the night before. Maybe the old 440 was just too tired for the beatings we were giving it.
![Name: IMG_20150916_123954843 - Copy.jpg
ID: 225069 IMG_20150916_123954843 - Copy.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/225069/filename/IMG_20150916_123954843 - Copy.jpg) ![Name: 12034322_10153737416798938_3878665745077505490_o.jpg
ID: 225070 12034322_10153737416798938_3878665745077505490_o.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/225070/filename/12034322_10153737416798938_3878665745077505490_o.jpg)
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1989771
01/13/16 10:43 AM
01/13/16 10:43 AM
MoparBilly
Phoenix, AZ
I was the straggler of our group, and there were two sets of cars between Rachael and myself. The first pair were Charlie Ogle in his Challenger, and Jay Brown in his SOHC Shelby. Like Rachael and I, both of these guys made multiple hits in the last two hours at Great Lakes. Jay was chasing electrical issues in his fuel delivery system, and Charlie's Gold Dodge wasn't getting anywhere near the number he ran at Indy.
[Re: MoparBilly]
#1990025
01/13/16 05:25 PM
01/13/16 05:25 PM
Posts: 409 Texas
mprhound
Texas
Not even close, little did I know that I had pushed a head gasket. Found out as I left the gate and I finished it off. I pulled over on the side of the road at the first turn. Part of my problem was solved by one of the staff from great lakes drag way, he came by and told us we could work on it at his place that was about a mile down the road, we (Billy my trunk monkey, Jason and my nephew Dillon in the Cuda) got it down there and then realized the next problem, I had a blown head gasket and only one spare gasket, so which head do I pull? I decided to pull the left head because that was the side the O2 sensor was on and the afr gauge was going crazy. In the mean time the Great Lakes crew member ( for the life of me I can't remember his name) located another head gasket, so Jason takes off in the Cuda to get it. So with two head gaskets we go ahead and pull the other head, the left one was pushed into the water passage and the right one was almost there, so with two fresh head gaskets and 4 1/2 hours later we got back on the road, thank god it was the short trip that day! The next day with good head gaskets I blew through the clutch and had to baby it the rest of the way, at that point I was still in the top 32 but could not muster up a quick enough pass the last day to keep me there with all if the clutch issues. Made the top 32 in 2014 but bent the clutch fork in Tulsa and told them I couldn't make the bracket race, broke a pressure plate bolt in 2013 in Memphis, every year a common theme so when I got home after last year I called John at Cope racing trans and ordered a killer 727, and a gear vendor, we will see if that gets the monkey off my back next year! And Billy thanks for the pic of my brothers car on the line that is one I did not have.
![Name: image.jpg
ID: 225115 image.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/225115/filename/image.jpg) ![Name: image.jpg
ID: 225116 image.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/225116/filename/image.jpg)
[Re: MoparBilly]
#1990258
01/13/16 10:45 PM
01/13/16 10:45 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
His name isn't Don is it?
68 Barracuda Formula S 340
[Re: MoparBilly]
#1990286
01/13/16 11:24 PM
01/13/16 11:24 PM
MoparBilly
Phoenix, AZ
Always like to hear tales of a trunk monkey earning his or her keep Charlie! Seems co-pilots named Bill don't always pull their weight. While yours was turning wrenches, this is what my Dad was doing! I'll let Clark decide where his Dad is on that spectrum...
[Re: MoparBilly]
#1990350
01/14/16 01:09 AM
01/14/16 01:09 AM
MoparBilly
Phoenix, AZ
I was paired for my first hit with Nick Plewniak, and his stretchy truck. I raced Nick last year in the shootout, and I know he takes quite a while to do his burnout and stage, so I decided to wait on him in the water. One of the frustrating things for a drag racer who'd trying to race a street car with a t-stat is engine temperature, and I was trying to get at least one pass in without the thing being completely heat soaked.
I was shocked when Nick did a shorter than normal burnout, so I went ahead and did mine, and approached the line, then waited, waited, and waited some more. When I looked back over my shoulder, guys had both doors to the S-10 open, and appeared to be helping Nick with something. I motioned at the starter, but he told me to sit tight. Apparently Nick had pulled the same stunt Boone had, and they were putting his belts on him while my tires got colder and my engine hotter. The Valiant hesitated at the hit again, then spun a little, so I was already formulating my plan for the next run as I approached the finish line. I remembered John's description of the shutdown area and track exit, so I decided to concentrate on that, halfway through the braking zone the track falls away from you downhill, then you navigate a quick button hook onto the return road which had me wondering how a 250+ inch dragster would ever make it!
![Name: 12080211_10153737417663938_205917471386381950_o - Copy.jpg
ID: 225155 12080211_10153737417663938_205917471386381950_o - Copy.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/225155/filename/12080211_10153737417663938_205917471386381950_o - Copy.jpg) ![Name: 10572109_10207606227381078_4820870465344668111_o.jpg
ID: 225156 10572109_10207606227381078_4820870465344668111_o.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/225156/filename/10572109_10207606227381078_4820870465344668111_o.jpg)
[Re: MoparBilly]
#1990379
01/14/16 01:57 AM
01/14/16 01:57 AM
Bad340fish
Tulsa OK
Always like to hear tales of a trunk monkey earning his or her keep Charlie! Seems co-pilots named Bill don't always pull their weight. While yours was turning wrenches, this is what my Dad was doing! I'll let Clark decide where his Dad is on that spectrum... My dad Bill is a great trunk monkey, I haven't caught him napping in the pits yet! We have been fortunate enough to get more sleep than you guys have on the last few DWs however. This is what I woke up to in Cordova, I know none of your cars were there when I went to sleep.
[Re: Bad340fish]
#1990513
01/14/16 10:42 AM
01/14/16 10:42 AM
Posts: 409 Texas
mprhound
Texas
His name isn't Don is it? Don sounds right, he was a great help.
[Re: MoparBilly]
#1990523
01/14/16 11:05 AM
01/14/16 11:05 AM
MoparBilly
Phoenix, AZ
The 10.62-126.7 slip, with a 1.53 short time, didn't leave me all warm and fuzzy, but the drive down the return road with all the cheering and thumbs up from fans hanging on the fence certainly did. Usually by 1:00pm on Drag Week, the energy is definitely waning, replaced with desperation as a handful of racers struggle for that money time slip. With the GLD crowd, that simply wasn't the case, and their enthusiasm permeated the pits. John went up for a second run in his Valiant, not because he needed a quicker pass, just for the enjoyment of running at a track he may never visit again, an d to enjoy the atmosphere. He wasn't alone in that regard either, Clark Strong's 69 Road Runner had already went 11.55 without a bar, about as close as he could cut it, but he made at least three more runs after that.
I changed squirters again on the Valiant, and took a half pound out of the Hoosiers, then helped Skippy swap bottles in the Belvedere after Rachael's second run, staying on the nitrous out the back door, had only netted an 11.89-114.5. My second run was forty minutes after the first, and after complaining about my less than stellar launch the first time, John walked over to help me get the burnout right. The Valiant pushed through the line lock twice, so he backed me off, and had the track official re-spray the pad. With a good burnout, and a quick stage, my confidence that this would be a good run was high, but that slight hesitation at the drop of the pedal was still there. 10.53-126.9 with a 1.51 60' was the third quickest ET. the car has ran NA, but coming off a 10.39 the day before, and knowing it's went a 1.42 already to the first clocks...I wasn't satisfied.
![Name: 12045208_10153737361228938_3327464923565613190_o.jpg
ID: 225229 12045208_10153737361228938_3327464923565613190_o.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/225229/filename/12045208_10153737361228938_3327464923565613190_o.jpg) ![Name: 12079999_10153737464413938_1916146455248414917_o - Copy.jpg
ID: 225230 12079999_10153737464413938_1916146455248414917_o - Copy.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/225230/filename/12079999_10153737464413938_1916146455248414917_o - Copy.jpg)
[Re: MoparBilly]
#1991048
01/15/16 01:43 AM
01/15/16 01:43 AM
MoparBilly
Phoenix, AZ
Dustin and Jason, in the lanes at Great Lakes Dragaway.
[Re: MoparBilly]
#1991084
01/15/16 02:57 AM
01/15/16 02:57 AM
MoparBilly
Phoenix, AZ
Rachael's third run of the day was a single, probably the first she's ever ran. The change in routine and the nervous jitters of the fresh bottle on board, caused her to drive through the beams before the tree activated, and she didn't get a time.
I had parked in our pit area, and was expecting her return, but she drove directly back to the lanes and was re-staging the Belvedere a scant six minutes later. "It's almost like one of those jokes about three guys walking into a bar when you see the Gebharts going down the highway..." Hot Rod Drag Week Announcer Brian Lohnes boomed out as she staged. I was pretty anxious to hear where he was going to take this comment, I mean this is the same guy who once introduced my Valiant with the age old line about beauty being skin deep, but ugly was to the bone! "Because it's like a Belvedere, a Valiant, and a Gremlin are going down the highway", he continued , "and there should be a punchline, but the only punchline is, they're all really fast, and really reliable, and belong to people who love this event with all their beings..."
"Dang", I thought, "He was going completely off the cuff, and put together a wonderful compliment on the fly...that's real talent, no wonder NHRA hired him."
"We have to thank the Gebharts for putting the data together that we are using here to look at the historic numbers that have been run at Drag Week", David Freiburger followed up on Brian's comments, "they keep a list...like we have not, and they've got it nailed!" "Yeah, absolutely, he's got it locked down", Brian added. "It got us talking last night about how we really should put together an official record book, but who knew eleven years ago that this thing would get this big...kinda crazy!" Freiburger finished up.
I saw Rachael lift off the nitrous just past 1000ft., but judging by how hard the Belvedere left with the fresh hit, I had doubts it would make a difference. 11.30, at only 114...best ET ever for the car! Stood there shaking my head, wishing she would have just ran it out!
![Name: 12006421_10153737473203938_3203500540455140695_o (2).jpg
ID: 225344 12006421_10153737473203938_3203500540455140695_o (2).jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/225344/filename/12006421_10153737473203938_3203500540455140695_o (2).jpg) ![Name: 12087781_10153737444258938_7541141788912494574_o.jpg
ID: 225345 12087781_10153737444258938_7541141788912494574_o.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/225345/filename/12087781_10153737444258938_7541141788912494574_o.jpg)
[Re: MoparBilly]
#1991089
01/15/16 03:15 AM
01/15/16 03:15 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Billy.. how do you remember all of this... do you have a tape recorder that you tape that days events then do that daily... even with the help of the family member no one can remember all this.. nice job... hell I have a hard time remembering my name
[Re: MR_P_BODY]
#1991309
01/15/16 03:58 PM
01/15/16 03:58 PM
Posts: 4,592 Motor City
6PKRTSE
Motor City
My friend of ours Donnie had the TT Chevette this year going 7:80's for some of the events until he got called home for an emergency family reasons.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: MR_P_BODY]
#1991358
01/15/16 04:58 PM
01/15/16 04:58 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Billy.. how do you remember all of this... do you have a tape recorder that you tape that days events then do that daily... even with the help of the family member no one can remember all this.. nice job... hell I have a hard time remembering my name He must have a photographic memory...although I can remember how I set up my first race car over 35 years ago, I can't remember what I had for breakfast yesterday. You remember what is important to you.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
