70 - 74 Cuda Header panel #1983042
01/03/16 09:48 PM
01/03/16 09:48 PM
Gateway to the West.
hemi_harvester Offline OP
AMD shows 70 header as different that all the rest, is it the way the grill mounts or ? I dont see the difference
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: 70 - 74 Cuda Header panel [Re: hemi_harvester] #1983056
01/03/16 10:03 PM
01/03/16 10:03 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
The 70 holds in the headlight buckets and all that stuff. The 1971 seems to be similar but they must have broke it down to more pieces. I have both, but this is a 1970 and I'll take a picture of the 1971 that I have in the shed and show you it. The rest of the years I don't know the differences.
Devin
Re: 70 - 74 Cuda Header panel [Re: hemi_harvester] #1983057
01/03/16 10:05 PM
01/03/16 10:05 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Found a picture, it is the yellow piece. Or at least this is how I have interpreted the differences from looking at our AAR and my sisters 71. I'm new to the E-body world.
Re: 70 - 74 Cuda Header panel [Re: 68KillerBee] #1983095
01/03/16 10:48 PM
01/03/16 10:48 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
70 is the one in the first picture up against the tree. The yellow one in the second picture is either a 1971 or 1972-4.
Re: 70 - 74 Cuda Header panel [Re: m46rat] #1983255
01/04/16 02:22 AM
01/04/16 02:22 AM
Re: 70 - 74 Cuda Header panel [Re: hemi_harvester] #1983259
01/04/16 02:47 AM
01/04/16 02:47 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
70 has the bottom part made into it, the 71-up is just the top.
Re: 70 - 74 Cuda Header panel [Re: hemi_harvester] #1983352
01/04/16 12:31 PM
01/04/16 12:31 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
And the 71 is unique also.. The attachment holes/tabs are in a different orientation.. It looks the same as the 72- up but is slightly different...
Re: 70 - 74 Cuda Header panel [Re: screamindriver] #1983453
01/04/16 03:14 PM
01/04/16 03:14 PM
m46rat Offline
m46rat  Offline
72-4 has a bracket welded to the center brace. This is for the mounting of the two horns for the car. 71 does not have that bracket.
