Re: Driving the 37 and lost a wheel
[Re: 68KillerBee]
#1992346
01/17/16 12:58 AM
01/17/16 12:58 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Ok, I got the front drums/hubs off. Looks like the 2 are just riveted together. Looks like there is plenty of meat to install wheel studs. I know this needs to be pretty exact so should I have a machine shop drill and press in the studs?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#1992356
01/17/16 01:32 AM
01/17/16 01:32 AM
AZ_A12_BEE
Dreaming of the 808
New wheels for the rear arrived, I got 15x8 with a 4.5 inch backspaceing. I have some Cooper Cobra 255/60/15s coming, I'm using 15x7 in the front with 235/60/15s
37 Plymouth PU
[Re: AZ_A12_BEE]
#1992466
01/17/16 11:50 AM
01/17/16 11:50 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Looking at the pictures, I believe your original failure was caused by using the wrong wheels.
The slots you appear to be setup to run a short shank nut. Your wheel bolts are conical seats. They are not compatible and it does not appear your new rims are compatible either.
Do you plan to convert all 4 corners to studs? I hope so.
To be honest, the drum setup on a 37 isn't worth the price of studs. Non self energizing drum brakes are terrible. I know you aren't planning on it right now, but I wouldn't invest in studding out the original drums myself, I'd just go with modern brakes all around.
[Re: Supercuda]
#1992480
01/17/16 12:25 PM
01/17/16 12:25 PM
AZ_A12_BEE
Dreaming of the 808
To be honest, the drum setup on a 37 isn't worth the price of studs. Non self energizing drum brakes are terrible. I know you aren't planning on it right now, but I wouldn't invest in studding out the original drums myself, I'd just go with modern brakes all around. The rear is already studs as it is a 8 inch Ford rear end out of what appears to be a Torino by its width. I'm not changing the Front brakes out at this time, I'm just putting in the studs in and the Weld Rodlites getting rid of these old mags. This truck with the brakes it has stops just fine for as little as I drive it.
37 Plymouth PU
[Re: moparx]
#1992495
01/17/16 12:49 PM
01/17/16 12:49 PM
AZ_A12_BEE
Dreaming of the 808
one thing that is absolutely mandatory is you MUST make sure the drum retaining rivets allow the wheels of choice to fit flat on the drum mating surface. the factory wheels had a relief on the back side to allow this. a close up pic of your new wheels will tell if they will work on the drums.[personally, i don't think they will because even though they have multiple bolt patterns, the unused holes might not be large enough, or in the right place, to fit completely over the rivets] if not, you have two choices. spacers that are thick enough to go slightly above the rivet heads, or swap to modern style brakes as have been already suggested. The plan is to remove the rivets after the studs are pressed in, the rivets are not needed after it has studs
37 Plymouth PU
[Re: AZ_A12_BEE]
#1992584
01/17/16 02:33 PM
01/17/16 02:33 PM
Supercuda
About to go away
About to go away
up yours
OK, didn't realize, or most likely I forgot, you had the 8.8 in there, at least those brakes are modern.
[Re: AZ_A12_BEE]
#1992599
01/17/16 02:47 PM
01/17/16 02:47 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Just a thought...instead of drilling them out now for studs (which is fine in itself of course IMO), if the threads in them are 1/2" already..why not just use screw in studs from the rear like the style used on rear axles and commonly sold? Might save a step and some time at least... http://www.summitracing.com/parts/msr-8002/overview/There are plenty of different brands out there, but those as an example at least.
[Re: OzHemi]
#1992642
01/17/16 03:25 PM
01/17/16 03:25 PM
AZ_A12_BEE
Dreaming of the 808
Just a thought...instead of drilling them out now for studs (which is fine in itself of course IMO), if the threads in them are 1/2" already..why not just use screw in studs from the rear like the style used on rear axles and commonly sold? Might save a step and some time at least... http://www.summitracing.com/parts/msr-8002/overview/There are plenty of different brands out there, but those as an example at least. Some of the threads have partial stripping out, I'm a little afraid there might not be enough thread to grab them, maybe if I used some Loctite
37 Plymouth PU
[Re: poorboy]
#1994588
01/20/16 01:05 AM
01/20/16 01:05 AM
AZ_A12_BEE
Dreaming of the 808
Ok guys, after cleaning out the treads in the drums with a tap I decided to use bolts as a stud instead of pressed in studs. I went out and got 10 1.5 inch grade 8 bolts and ran them in from the backside with red Loctite. I also removed the rivets so the drum and hub is 2 separate pieces.
37 Plymouth PU
[Re: AZ_A12_BEE]
#1994597
01/20/16 01:13 AM
01/20/16 01:13 AM
AZ_A12_BEE
Dreaming of the 808
New wheels/tires, 15x7 with 235/60 on the front, 15x8 with 255/60 on the rear, the wheels are Weld Rodlites
37 Plymouth PU
[Re: AZ_A12_BEE]
#1994601
01/20/16 01:18 AM
01/20/16 01:18 AM
AZ_A12_BEE
Dreaming of the 808
The 15x8 wheels with 4.5 inch back spacing really tuck the rear tires in, the is about 1/2 an inch between the inner sidewall and bed.
37 Plymouth PU
[Re: OzHemi]
#1994609
01/20/16 01:24 AM
01/20/16 01:24 AM
AZ_A12_BEE
Dreaming of the 808
Looks good! You used the correct style lug nuts to get the right thread engagement and seat to the wheels (with washers) and all too of course can assume? Yes, I used the long 1 3/8 shank lugs and correct washers, tons of thread engagement
37 Plymouth PU
