Page 3 of 3 1 2 3
Re: 360 losing oil pressure when reved up. [Re: dirt] #1979618
12/30/15 09:00 PM
12/30/15 09:00 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Awesome topic... Another year, another reply! LOL
Re: 360 losing oil pressure when reved up. [Re: dirt] #1979627
12/30/15 09:01 PM
12/30/15 09:01 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
cut the filter open see what it looks like
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: 360 losing oil pressure when reved up. [Re: yella71] #1979842
12/31/15 01:04 AM
12/31/15 01:04 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
We'll see the answer in 2017 if history is any guide.
Don't be the exception.
Re: 360 losing oil pressure when reved up. [Re: dirt] #1980161
12/31/15 03:00 PM
12/31/15 03:00 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
For the amount of time this post has taken, I would have torn it down and threw rings, bearings and gaskets in it and been back on the road if there is not too much of a ridge. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 360 losing oil pressure when reved up. [Re: yella71] #1980472
12/31/15 07:03 PM
12/31/15 07:03 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I dont get much free time to work on this but i hope i am about done now. I allready junked the filter. There was no sludge anywhere in the motor that i could find. But i did find a busted valve stem seal so i replaced all of them, bolted in a new oil pump and plan on putting it in my 68 D100 this weekend.
It will be nice to have the extra power when pulling a trailer. The old 318 works pretty hard pulling it up hills.
Re: 360 losing oil pressure when reved up. [Re: dirt] #1980481
12/31/15 07:11 PM
12/31/15 07:11 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
make sure the oil pick up is more then hand tight. i would think it could suck air if not.
Re: 360 losing oil pressure when reved up. [Re: mopars4ever] #1981494
01/01/16 09:35 PM
01/01/16 09:35 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I installed a new oil pump and tightened the pickup tube with a wrench this time.
I was replacing the valve stem seals and noticed i had 2 different kinds. One looked like the original ones and the others were smaller . One is the umbrella style and one is the positive style. I got 8 of each in my kit. Any idea why?
Re: 360 losing oil pressure when reved up. [Re: dirt] #1981594
01/01/16 11:11 PM
01/01/16 11:11 PM
JCFcuda Offline
JCFcuda  Offline
Umbrella seals go on the exhaust valves
Re: 360 losing oil pressure when reved up. [Re: JCFcuda] #1981639
01/02/16 12:09 AM
01/02/16 12:09 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Ok, thanks. I will be bolting it in my truck tomorrow.
Re: 360 losing oil pressure when reved up. [Re: dirt] #1983867
01/04/16 11:56 PM
01/04/16 11:56 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I got to go for a test drive and it seems to be ok. I only have an idiot light for oil pressure but it goes off as soon as it starts. I still am going to put in an aftermarket oil gauge.
Only issue i have is that i think i need a smaller carburetor. I used a 750 that i had but probably on a stock motor a 650 would be better.
Re: 360 losing oil pressure when reved up. [Re: dirt] #1983878
01/05/16 12:14 AM
01/05/16 12:14 AM
md
md
Hopefully all is well now. Good luck. BTW, Is the 750 a holley with vacuum secondaries? You should be fine with that with a little tuning.
Re: 360 losing oil pressure when reved up. [Re: mopars4ever] #1983941
01/05/16 02:04 AM
01/05/16 02:04 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Yes it is a 750 holley vaccum secondaries. It is just the way it came out of the box. It hesitates a little when i floor it but i did not try adjusting it or rejetting it yet.
Its surprising how well a stock 1971 360 runs with a 4 barrel. The motor has never been apart. Only thing i did was change oil pump and valve stem seals. Its way better than the 318 it replaced.
Re: 360 losing oil pressure when reved up. [Re: dirt] #1990302
01/13/16 11:47 PM
01/13/16 11:47 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I put an oil pressure gauge in and it has 45 lbs at idle and as soon as I touch the gas it goes to 60. so it looks like the problem is gone now. only took me 6 years to figure it out lol
Re: 360 losing oil pressure when reved up. [Re: mopars4ever] #3040219
05/06/22 08:48 AM
05/06/22 08:48 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I ended up putting a 600 on it and it runs great. Got 87,000 miles on it now. It pulls my box trailer much better than the 318 did. I put an overdrive A833 behind it and it is pretty fun to drive anywhere. It is starting to leak oil pretty bad from the rear of the motor now. Hopefully it's an easy fix.
Page 3 of 3 1 2 3
