Re: Small block electric water pumps [Re: AndyF] #1980685
12/31/15 10:48 PM
12/31/15 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Andy.. whats the thread on your manifolds... being
a straight thread... is that like a 3/4 fine.. and
do you think it would hold in a 3/8" motor plate..
wave
Re: Small block electric water pumps [Re: RAY1969CARS] #1980792
01/01/16 01:07 AM
01/01/16 01:07 AM
AndyF Offline
AndyF  Offline
No, I don't think it will hold in a 3/8 plate, I think you would need at least 1/2 inch. It is 12 threads per inch so 1/2 inch gives you 6 threads but you need a chamfer for the o-ring to seal on so that takes away at least one thread.
Re: Small block electric water pumps [Re: AndyF] #1980949
01/01/16 11:02 AM
01/01/16 11:02 AM
BPE Offline
BPE  Offline
Where did you get the 12 point bolt for the damper? Very nice looking components also.
Rod
Re: Small block electric water pumps [Re: BPE] #1981006
01/01/16 12:59 PM
01/01/16 12:59 PM
AndyF Offline
AndyF  Offline
Rod
ARP makes the damper bolt.
Re: Small block electric water pumps [Re: AndyF] #1981070
01/01/16 02:29 PM
01/01/16 02:29 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Nice stuff Andy.
Depending on how extreme the build. I prefer to reverse cool. If the block is not filled with concrete I like the core plug adapters to deliver water at the bottom of block. It is proven better cooling. Borrowed the idea from Sprint car applications. The R5 actually has a passage cast in the block just above oil pan rail.
