Re: ms doesn't see the rpm? [Re: Andrewh] #1987712
01/10/16 05:35 PM
01/10/16 05:35 PM
Andrewh Offline OP
Andrewh  Offline OP
well after the jumper change, it fired up.
It would not stay running though unless I feathered the throttle.
I got it to warm up that way and then it just hunted around forever.
not sure if I have the iac wired right or if it is something else.
but it is more progress I guess.
anyone have the diagram for how mopar wires the iac motors?
Re: ms doesn't see the rpm? [Re: Andrewh] #1988334
01/11/16 11:50 AM
01/11/16 11:50 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
To set your base idle, I would pull the plug on the throttle stop screw and use that to set your idle speed just like a carb. The IAC should be used for warm-up fast idle, not base idle control. I would get the IAC closed, then disconnect it and come back to it later.
