Master cylinder #197716
01/18/09 11:21 PM
01/18/09 11:21 PM
CJV5314 Offline OP
CJV5314  Offline OP
Are aftermarket master cylinders available to improve breaking?
Re: Master cylinder [Re: CJV5314] #197717
01/18/09 11:44 PM
01/18/09 11:44 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
what is your problem ? what type of brakes ?
Re: Master cylinder [Re: CJV5314] #197718
01/18/09 11:49 PM
01/18/09 11:49 PM
The high dollar aftermarket ones wont improve braking per se only hold up better over the long run. The common aluminum ones are trouble free, save weight, the only critical decision is to select the correct bore size for your app & I would suggest Dr Diff who is a member here who knows his(brake)stuff & will steer you in the right direction. EDIT if you need more braking the rotors/pads/calipers down at the wheels needs to be changed
Re: Master cylinder [Re: RapidRobert] #197719
01/19/09 01:01 AM
01/19/09 01:01 AM
CJV5314 Offline OP
CJV5314  Offline OP
Thanks for your post. Was at the bookstore the otherday and remember reading a book about drag racing and the author said that aftermarket master cylinders can improve breaking! Dont remember the book offhand but Im sure I remember reading it! Was hoping to improve the breaking on my 73 charger with front disc breaks without replacing the entire system. An improvement to the stock setup in my opinion would be less pedal resistance! Thanks for your help and welcome all comments.
Bowties and blue ovals just dont cut it for me!
Re: Master cylinder [Re: CJV5314] #197720
01/19/09 01:13 AM
01/19/09 01:13 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you decrease the master cylinder bore size, you increase the line pressure. This yields a longer, lighter pedal stroke.
Re: Master cylinder [Re: DoctorDiff] #197721
01/19/09 01:34 AM
01/19/09 01:34 AM
Do you have power disc/drum w a cast iron MC? I would replace the MC with a 7/8" bore aluminum unit with the adapter plate & I will defer to the Doc for the final sayso on the best bore size. Bleed it all out & I think you'd be good.
Re: Master cylinder [Re: RapidRobert] #197722
01/19/09 01:51 AM
01/19/09 01:51 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
1 1/32" bore works for most stock Mopar brake systems.
If you need more, a new iron 15/16" bore (4 hole) master is available from any parts store. #36406
This master is compatable with power and manual brakes.
Re: Master cylinder [Re: DoctorDiff] #197723
01/19/09 02:29 PM
01/19/09 02:29 PM
CJV5314 Offline OP
CJV5314  Offline OP
Thanks good info guys!
Re: Master cylinder [Re: CJV5314] #197724
01/19/09 08:11 PM
01/19/09 08:11 PM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
What part of Oregun you in?
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
