Ziebart Removal
#349817
06/17/09 10:18 AM
06/17/09 10:18 AM
I recently purchased a '71 Road Runner from the original owner in Chicago. The car is covered liberally with Ziebart, a product widely used in northern states and Canada to prevent rust. My car has it everywhere and I would like to remove it in some places. Does anyone have a suggestion on how to remove this stuff. I visited with Ziebart staff people and they didn't have a suggestion. I've tried your regular solvents, etc, with no luck. I'd appreciate any ideas.
Re: Ziebart Removal
#349818
06/17/09 10:23 AM
06/17/09 10:23 AM
moparpollack
Lil Herman
Lil Herman
85086
Is this inside the panels or underneath the car? Challenger1 has a steam cleaner or power washer that removes undercoating without scraping.
Re: Ziebart Removal
#349819
06/17/09 10:30 AM
06/17/09 10:30 AM
moparpollack
Lil Herman
Lil Herman
85086
Re: Ziebart Removal
#349821
06/17/09 03:20 PM
06/17/09 03:20 PM
Ziebart is typically sprayed through holes drilled through places on the body, such as under sill plates, etc. They also spray it up into the wheelwells, etc for protection. The previous owner of this car must have told the guys that did the work that if "x" amount of product is good, "2x" must be better. It is all over the place. The whole inside of the trunk was sprayed with this stuff. It is under the hood, on the ram air assembly, inner fender wells,... It's crazy. What I have removed is very labor intensive. The sheet metal is solid as a rock, but at the pace I'm going, it will take forever. Car otherwise looks great. 53,000 one-owner car. Red with black interior. Just need to clean it up a bit. Thanks for your replies.
Re: Ziebart Removal
#349822
06/17/09 03:33 PM
06/17/09 03:33 PM
I just tried applying some WD40 to this stuff. Didn't affect it much differently than other stuff I've tried- mineral spirits, acetone, etc. Thanks for the suggestion. I will spray some on a couple of spots liberally today before I leave my shop and see how it does in the morning.
Re: Ziebart Removal
[Re: Challenger 1]
#349824
06/17/09 03:45 PM
06/17/09 03:45 PM
moparpollack
Lil Herman
Lil Herman
85086
Do you soak the undercoating in gasoline? If so how long?
Re: Ziebart Removal
[Re: moparpollack]
#349825
06/17/09 03:54 PM
06/17/09 03:54 PM
Posts: 821 NW Ohio
6pkaar
NW Ohio
Liberly apply the gasoline, sit back and light up a cigarette.....it won't be long before the undercoating is blown right off!
Re: Ziebart Removal
[Re: 6pkaar]
#349826
06/17/09 03:59 PM
06/17/09 03:59 PM
moparpollack
Lil Herman
Lil Herman
85086
We'll try that on your car first and see how it goes.
Re: Ziebart Removal
[Re: moparpollack]
#349827
06/17/09 05:06 PM
06/17/09 05:06 PM
Challenger 1
Cincinnati, Ohio
Only about 2-5 mins and then blast it off with hot water.
Re: Ziebart Removal
[Re: 65 Hemi]
#349829
06/17/09 08:33 PM
06/17/09 08:33 PM
Challenger 1
Cincinnati, Ohio
I have been in the coatings industry for years and have done alot of work with ziebart dealers. A heat induction unit work best with a putty knife. See if a local body shop or Rhino Linings dealer will rent you theirs.
The OP car is togeather and removing the stuff is not easy.
But if the car was stripped and on a rotisseire, then a "heat induction unit and a putty knife" is definetly not the best way to do it.
Re: Ziebart Removal
[Re: Challenger 1]
#349830
06/17/09 08:42 PM
06/17/09 08:42 PM
Posts: 304 Ohio
LS-300
Ohio
The stuff they give you for overspray works to soften it. Surprise its just kerosene
1979 Chrysler 300
1968 Barracuda project
Re: Ziebart Removal
#349832
06/17/09 11:33 PM
06/17/09 11:33 PM
Thanks for all the suggestions. I appreciate it very much.
Re: Ziebart Removal
[Re: 6pkaar]
#1976680
12/26/15 06:47 PM
12/26/15 06:47 PM
Posts: 16,162 Mesa, Arizona
dart4forte
Mesa, Arizona
Do you soak the undercoating in gasoline? If so how long? <img src="/ubbthreads/images/graemlins/1343795-scratchchin.gif" alt="" /> Liberly apply the gasoline, sit back and light up a cigarette.....it won't be long before the undercoating is blown right off! This will work Seriously, what about diesel?
Abe Lincoln
Re: Ziebart Removal
[Re: ScottSmith_Harms]
#1976707
12/26/15 07:38 PM
12/26/15 07:38 PM
dart4forte
Mesa, Arizona
I second the Steam cleaner as the ultimate factory undercoating removal tool. I like the fact that you don't remove anything but the undercoating and grime, the original paint and primer remains intact unless you actually try to remove it as well (which you can).
With aftermarket Ziebart drilled and squirted into doors and other inaccessible areas dipping the car would be about the only way you'll get rid of it all.
.02 Probably the best way doing it at home. I've seen Scott's car first hand and his blaster did a good job getting all the crud off the bottom of his car. Another option is dustless blasting. (One note. If you go with the dustless blasting option don't do it at home. Creates a big mess that has to be cleaned up. Do it at the vendors location.) We went with that and it took us two days to clean up the mess.
Abe Lincoln
