Re: Machinist needed [Re: Scamp408] #1976396
12/26/15 12:56 AM
12/26/15 12:56 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
That's gonna make this interesting. runaway
Re: Machinist needed [Re: WILD BILL] #1976513
12/26/15 01:06 PM
12/26/15 01:06 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Nothing interesting about that. Just run it a few days and that spring should wear in that taper for you
Re: Machinist needed [Re: Scamp408] #1976676
12/26/15 06:43 PM
12/26/15 06:43 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Originally Posted By scamp408
Most guys are making them or just not using it as I am now. The part is 200 and it takes 6 hours book time to install.
Get one from a 2014 or up, they changed the design along with a new design oil filter. $50 cheaper too. I have a used one from a 2014 3.6 engine I'm parting out I'd sell for $75.
Re: Machinist needed [Re: The Shadow] #1976711
12/26/15 07:49 PM
12/26/15 07:49 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I said that becuase I had already "finished" that end of the part and was starting on the smaller diameter side. I wasn't sure if I could flip the part and hold it by the small nose and still cut that taper into it.
Turns out I could and finished today.
I'm not ashamed to admit that I had to get help from my oldest to figure out the angle I would to cut the taper to acheive the desired result. Turns out it's just under 89 degrees to cut that taper.
It's good to have a kid who scored a 1540 on the SAT'S penguin
This has got to be the most complaex part I have ever atempted and to my measurements I think I nailed all the cirtical dimensions to within half a thou. I was using a HF digital caliper to measure with though so I can only be as accurate as it is. laugh2
Re: Machinist needed [Re: RalleyA12] #1976983
12/27/15 08:55 AM
12/27/15 08:55 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I was told it cant be used something is diff on the hook up.
