Page 12 of 26 1 2 10 11 12 13 14 25 26
Re: My 63 Dodge 330 Project: [Re: GY3] #1953756
11/18/15 04:02 PM
11/18/15 04:02 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Drove it around the neighborhood and town yesterday. So much fun!
Re: My 63 Dodge 330 Project: [Re: GY3] #1964331
12/06/15 01:23 PM
12/06/15 01:23 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Unfortunately, a week after the above picture, the engine started losing power. I ripped the valley tray off only to be greeted with some wiped cam lobes and ground up lifters.
After pulling the engine apart, I was relieved to find the crank was fine and all the bearings were perfect. Whew!
The block has been thoroughly cleaned and cylinders rehoned. I reinstalled the crank with new bearings last night.
I made the decision to go with a hydraulic roller cam after reading about others having the same problem with the current crop of flat tappet cams. Parts started to arrive last week and I was really impressed with the way Howards package the roller lifters.
Re: My 63 Dodge 330 Project: [Re: GY3] #1973117
12/20/15 04:47 AM
12/20/15 04:47 AM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
Hope your engine works well with no problems anymore. I know how much work it all is. Nice job.
Re: My 63 Dodge 330 Project: [Re: keith airgrabber] #1996503
01/22/16 07:17 PM
01/22/16 07:17 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Thoroughly cleaned out the engine and started from the bare block. It did give me a chance to inspect the internals and all the bearings looked great despite the cam and lifter material going through it.
New bearings, new cam and lifters, new distributor drive gear and fuel pump pushrod. I also put in some cometic head gaskets to drop the CR about half a point down to 10.5:1. It's 98% there but just need to button up a few things. No pics to post because it looks exactly the same externally. I should be able to fire it this weekend since it's supposed to warm up some.
Re: My 63 Dodge 330 Project: [Re: GY3] #1998559
01/25/16 07:03 PM
01/25/16 07:03 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
WHOOOOO!
It is back together and is a MONSTER!
I went with a Howards .545 lift 287/293 duration hydraulic roller cam.
It idles at 850 rpm and pulls like a train in 3rd gear!
Absolutely perfect for a pump gas street car with 3.55 gears and a 2800 stall convertor.
Re: My 63 Dodge 330 Project: [Re: GY3] #2004947
02/03/16 05:30 PM
02/03/16 05:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I went over to a friend's house that has a Go-Pro...
https://youtu.be/FcKEEDBRwno
Re: My 63 Dodge 330 Project: [Re: GY3] #2008335
02/09/16 12:51 AM
02/09/16 12:51 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I plan on some better and bigger tires for the rear so upgrading to Dana 60. Cut the full floater ends off today and started cleaning it up...
Re: My 63 Dodge 330 Project: [Re: Anonymous] #2008727
02/09/16 07:01 PM
02/09/16 07:01 PM
KS
417_Stroker Offline
417_Stroker  Offline
KS
What up Mark!? And yes this car is a ton of fun to ride in!
'69 Dart 417 pump gas with 200-4R 10.49@128
Re: My 63 Dodge 330 Project: [Re: 417_Stroker] #2008751
02/09/16 07:50 PM
02/09/16 07:50 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
All is fun and games until you lose a Go-Pro! laugh
Re: My 63 Dodge 330 Project: [Re: Anonymous] #2008754
02/09/16 07:53 PM
02/09/16 07:53 PM
KS
417_Stroker Offline
417_Stroker  Offline
KS
We got lucky! That's all I can say. It probably would have fell off in the 3rd gear pull going 100+ I'm sure
Re: My 63 Dodge 330 Project: [Re: 417_Stroker] #2017086
02/22/16 02:06 AM
02/22/16 02:06 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I've had problems with getting ANY traction with the street radials so I bought some Mickey Thompson ET Street Radial Pro's last week. I still can't get it to hook in 1st on the street but anything over 30 mph I can usually stick it and it slams you in the butt and goes!
Much better at putting the power to the ground overall and I'm sure on a well prepped track it will hook.
Re: My 63 Dodge 330 Project: [Re: GY3] #2018353
02/23/16 09:53 PM
02/23/16 09:53 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Installed a driveshaft safety hoop and a few interior bits.
I played with the Speedview App today and, even with limited traction in 1st gear and cold pavement, it managed a 12.0 e.t.
I'm sure once the track opens I can shave quite a bit off that..
Re: My 63 Dodge 330 Project: [Re: GY3] #2030012
03/12/16 11:40 PM
03/12/16 11:40 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I took it to the track today for our first test and tune.
It ran 11.75 @ 117 bouncing off the Rev limiter in 1st and 2nd.
Left off idle for this pass but tried a little higher launch. It blew the tires off and slowed to a 12.04. Tire pressure was as I drove it to the track at 20 psi. Will drop that next time to 14.
Pump gas, through the mufflers on street tires!
Pretty happy for 2800 stall and 3.55 street gears!
Re: My 63 Dodge 330 Project: [Re: GY3] #2030216
03/13/16 01:20 PM
03/13/16 01:20 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Re: My 63 Dodge 330 Project: [Re: GY3] #2045261
04/03/16 01:29 PM
04/03/16 01:29 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I'm prepping it for Mo-Kan this weekend.
I took out the Monroe front shocks and replaced them with some Competition Engineering shocks set at 90/10. I also removed the upper control arm bumpers to try and get more movement to out of the front at launch. I'm determined to get a better 60ft vs. The 1.78 last time!
I also installed the Moroso underdrive lower pulley.
Re: My 63 Dodge 330 Project: [Re: GY3] #2051006
04/10/16 01:30 PM
04/10/16 01:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I played with it Friday night and couldn't get it to hook very well. Saturday, we woke up to cold weather (37°). We all piled in the car and drove it to breakfast a few miles down the road in Asbury. It fired right up and stayed running with no fuss!
Later in the day it warmed up and I ran the best to date: 11.30 @ 119 mph!
1.60 60 ft.
Re: My 63 Dodge 330 Project: [Re: GY3] #2054246
04/14/16 01:31 PM
04/14/16 01:31 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Timeslip from this weekend:
Re: My 63 Dodge 330 Project: [Re: GY3] #2054249
04/14/16 01:37 PM
04/14/16 01:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
It's the little things...
I managed to get a pair of NOS outside door locks and new ignition tumbler from a Moparts member. New keys and everything works perfectly!
A fellow club member scored me the plastic panel that goes under the steering wheel. Mine was broken and had holes for switches.
Two minor upgrades but I keep picking away at the small stuff!
Re: My 63 Dodge 330 Project: [Re: GY3] #2061005
04/24/16 08:44 PM
04/24/16 08:44 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Again, picking away at small things. I found a 4 door parts car with a better back glass (mine has some scratches and pitting from years ago) and the trim screws and clips I needed for the inner window trim.
The car has been bone dry underneath since the rebuild but had a small puddle of Brad Penn under the engine last night. I'm really anal about sealing the motor up when I'm assembling, so I was really ticked!
It turns out it was the O-ring on the back of the oil pump pressure spring plug. 5 minute fix!
I'm anxious to get it back to the track but the lovely Kansas wind and rain have been keeping me away!
Re: My 63 Dodge 330 Project: [Re: GY3] #2069175
05/08/16 04:15 AM
05/08/16 04:15 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
New best mph tonight. 11.38 @ 121.29
Track just wasn't there with all the street cars on street tires.
Very happy with the gains I keep making, though!
