Re: Trick Flow heads
[Re: sam64]
#1974488
12/22/15 01:05 PM
12/22/15 01:05 PM
Posts: 307 OH
TheBlackCar
OH
tf posted dyno numbers,but did they show the motor combination anywhere? 440 Mopar 4.350 x 3.750 stock crank , Eagle rods, JE F/T piston 10.5:1 Compression Comp 23-713-9 H/R cam 242/248 .549/.544 @ 106 TFS Mopar 240 cc heads TFS-16094-16 springs Comp 1621-16 rockers Edelbrock Victor intake Hooker 1/78 header w/ 3" Flowmasters Demon 830
[Re: fast68plymouth]
#1974574
12/22/15 03:22 PM
12/22/15 03:22 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What I've found with the fel-pro paper gaskets is that the "too wide" port spacing is really only caused by one pair of ports being in the "wrong" place. If you measure from the edge of the inner bolt holes to the edge of the adjacent intake port there is usually a difference of about .040-.050 between the two measurements. Using a std port EZ head, which has CNC'd port openings, if you line up the bolt holes of the gasket with the holes in the head, one pair of ports line up good, the other pair are off(too wide). Flip the gasket end for end, and the opposite pair of ports line up. On one of these heads at least, the pair of ports on the gasket that are closer to the bolt holes are the ones that line up correctly with the ports on the head(when visually centering the gasket by lining up all 4 bolt holes).
[Re: AndyF]
#1974761
12/22/15 09:21 PM
12/22/15 09:21 PM
fast68plymouth
So. Burlington, Vt.
It would make some sense for TF to port their heads to the FelPro gasket even if the FelPro gasket doesn't fit stock heads perfectly. I agree. And they probably did just that. I had a chance to look at a couple things this afternoon. The measurement from the edge of the inner bolt hole to the edge of the port opening on the tin valley pan gasket is .950, for both sets of holes. The paper gaskets are usually .970-.980 on one end and .930-.940 on the other. So, the spread of the ports is pretty much the same as the valley pan, the bolts holes are just shifted slightly. The only unmolested aftermarket std port head I have here at the moment is an EZ. Both the std valley pan and the paper gaskets have the port openings slightly too far apart to really fit "right" on that head. Fwiw, the std port Indy gaskets are also slightly too wide, but not as bad as the fel-pro. The Indy mw gasket centers up really well on this head though. Of course none of that has anything to do with how any of that fits the TF heads. So, I guess the question is....... What to do about that poor port alignment of the victor intake. And, if it gets fixed, how much difference will it really make? I wish they would offer some of those more race oriented manifolds with undersized port openings so they could be port matched to the heads easier.
[Re: TheBlackCar]
#1974772
12/22/15 09:33 PM
12/22/15 09:33 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
tf posted dyno numbers,but did they show the motor combination anywhere? 440 Mopar 4.350 x 3.750 stock crank , Eagle rods, JE F/T piston 10.5:1 Compression Comp 23-713-9 H/R cam 242/248 .549/.544 @ 106 TFS Mopar 240 cc heads TFS-16094-16 springs Comp 1621-16 rockers Edelbrock Victor intake Hooker 1/78 header w/ 3" Flowmasters Demon 830 Where did you get that info? That's not quite what is quoted in HR mag. "Our new big-block Chrysler heads flow 334 cfm on the intake side, and 262 cfm on the exhaust side. For testing purposes, we built a .030-over 440 with 10.5:1 compression and a 241/246-at-.050 camshaft," Mike explains. "On the dyno, this combo made 620 horsepower on pump gas. We feel it represents the type of combination many Mopar guys build, and obviously there's the potential for these heads to support even more power by running more cubic inches and a bigger cam." I'm not saying you are wrong, just curious about the source of that data. Thanks, Steve
#1974806
12/22/15 10:28 PM
12/22/15 10:28 PM
Posts: 742 Southern Alberta
Uberpube
Southern Alberta
I found 60 rwhp on a 383 sbc by fixing the bad intake to head relationship so that I could tune the efi properly.. On that motor, every port had step, overhang and mismatch, it caused a lot of weird air flow problems that really upset the tuning and made the engine feel flat.
[Re: Jerry Kathe]
#1975117
12/23/15 01:54 PM
12/23/15 01:54 PM
fast68plymouth
So. Burlington, Vt.
Mismatch is always part of the expectation from product to product. The part that caught my attention is the bolt hole plane centerline to port plane centerline, those ports are lower with the TF head when compared to production heads - either street oem production or max wedge. That isn't the hot set up for short side at the valve pocket. I haven't looked at any flow numbers on these other than the ones in this thread, but I suspect that may be why these things go dead at 500 - 550 lift in CFM numbers, I'm not trying to be critical, just an observation.....
I suppose to keep it a "bolt on replacement type" head and to get bigger CFM numbers the centerline had to drop some, but also keep in mind that bigger CFM numbers alone dont automatically mean more HP. It looked to me from the pic of the gasket on the head that the ports were pretty "correct" height wise on the TF head, and that the mismatch on the manifold was really about the manifold. My experience has been that the Edelbrock Victor intakes for BB Mopars usually have the ports a little on the "high" side. Though I haven't seen the alignment be as far off as the one Andy is using. That's going to take some welding or Belzona to get it right, without making the head "bigger".
[Re: Skeptic]
#1975124
12/23/15 02:05 PM
12/23/15 02:05 PM
Posts: 307 OH
TheBlackCar
OH
tf posted dyno numbers,but did they show the motor combination anywhere? 440 Mopar 4.350 x 3.750 Where did you get that info? That's not quite what is quoted in HR mag. That IS the specs of the original dyno motor prior to SEMA last year. As the year has passed, the cam, intake, and carb have been replaced with "TF Package" parts. My bad, I apologize, I should have quoted current product literature. I'm not saying you are wrong, just curious about the source of that data. Thanks, Steve TF
[Re: GY3]
#1975222
12/23/15 04:54 PM
12/23/15 04:54 PM
Posts: 3,171 Wichita Kansas
B Dartman
Wichita Kansas
[/quote] I perused the new heads at B Dartman's house the other night but came away confused... I'm not sure if he's building an engine for a car or an aircraft?! [/quote] Dunno - There may have been a recent delivery... Funny part is that with the holiday's they showed up in a U-Haul Truck (FexEd) LOL. Said it before - but being a novice, the advice in this thread is greatly appreciated...
[Re: B Dartman]
#1975228
12/23/15 05:02 PM
12/23/15 05:02 PM
dartman366
Mt. Vernon, Ohio
I perused the new heads at B Dartman's house the other night but came away confused... I'm not sure if he's building an engine for a car or an aircraft?! [/quote] Dunno - There may have been a recent delivery... Funny part is that with the holiday's they showed up in a U-Haul Truck (FexEd) LOL. Said it before - but being a novice, the advice in this thread is greatly appreciated... [/quote]How long did it take to get them once the order was put in?
#1975246
12/23/15 05:17 PM
12/23/15 05:17 PM
B Dartman
Wichita Kansas
- Ordered 11/23/15 when Summit had the 10% sale - back ordered - Delivered 12/18/15 Note: Hats off to Trick Flow - They called and left a message at the house indicating the date their castings were due it - how long they'd take to machine, assemble and estimated ship date (Kept customer informed).
#1975253
12/23/15 05:28 PM
12/23/15 05:28 PM
fast68plymouth
So. Burlington, Vt.
I'd be pretty surprised if those heads aren't "flying off the shelves".
[Re: B Dartman]
#1975275
12/23/15 06:14 PM
12/23/15 06:14 PM
dartman366
Mt. Vernon, Ohio
- Ordered 11/23/15 when Summit had the 10% sale - back ordered - Delivered 12/18/15 Note: Hats off to Trick Flow - They called and left a message at the house indicating the date their castings were due it - how long they'd take to machine, assemble and estimated ship date (Kept customer informed). put my order in 12/1 thru summit also, with a due date of 1/9/16, they also called with the same info, that was a nice touch with the message to keep us informed.
[Re: BradH]
#1975531
12/24/15 02:49 AM
12/24/15 02:49 AM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
Now I'm curious about what the next incarnation of these will be from TF? They will have the MW version available mid summer 2016
Brian Hafliger
[Re: Brian Hafliger]
#1975661
12/24/15 02:24 PM
12/24/15 02:24 PM
Thumperdart
State of confusion
Now I'm curious about what the next incarnation of these will be from TF? They will have the MW version available mid summer 2016 NOW we`re talkin..............
