Small block h beam rods #1971580
12/17/15 06:48 PM
12/17/15 06:48 PM
CA.
RAY1969CARS Offline OP
CA.
416 rpm's may hit a lil in the 8000. Which is the better rod ? I'm sorry I meant to ask between Manley or Scat rods
Re: Small block h beam rods [Re: RAY1969CARS] #1971592
12/17/15 07:03 PM
12/17/15 07:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I bought 4 sets of Eagle H-beams about a year
after they came out... all my engines run 8000+
rpm.. been in there for 5 years or better... about
250 passes a year(varies some)... still holding
strong.. but I dont know the quality now days... 3
sets were chevy.. 1 was mopar
EDIT
I should have said all my race engines.. I only
turn my 416 to 7200 right now
wave
Re: Small block h beam rods [Re: RAY1969CARS] #1971606
12/17/15 07:34 PM
12/17/15 07:34 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
When in the world do you make 250 passes a year... Lol
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Small block h beam rods [Re: B3422W5] #1971640
12/17/15 08:33 PM
12/17/15 08:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Back when I was racing... averaged between 225 and
270 a year.. a lot of it was at our local dump tracks
wave
Re: Small block h beam rods [Re: RAY1969CARS] #1971805
12/18/15 12:13 AM
12/18/15 12:13 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I don't see a W5 head supporting 8000 rpm..... feel free to prove me wrong.
Re: Small block h beam rods [Re: J_BODY] #1971849
12/18/15 12:55 AM
12/18/15 12:55 AM
CA.
CA.
l
So do you think this scats are good enough?
Re: Small block h beam rods [Re: RAY1969CARS] #1971891
12/18/15 01:41 AM
12/18/15 01:41 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I went with Molnar on my W8 deal..... I just knew you had been working on a W5 project and it seems the rpm deal is a bit high. Like I said... maybe I don't know what the H I'm talking about. We only pushed about 6800rpm on our W5 deal.
Re: Small block h beam rods [Re: J_BODY] #1971898
12/18/15 01:56 AM
12/18/15 01:56 AM
CA.
CA.
How much Cam and compression on That w5 mill ?
Re: Small block h beam rods [Re: RAY1969CARS] #1971905
12/18/15 02:06 AM
12/18/15 02:06 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
13.5 to 1 compression. 340 filled block, 4" stroke. Cam was a comp .658 lift, duration at .050 = 275I 282E. Heads were cnc ported with that group buy that was here through SDSS. Gave us a best of 9.87 @ 137. Car wasn't legal so my dad was shifting at 6200 and running 10ohs. We turned it up a couple of times and pull it would!
Re: Small block h beam rods [Re: J_BODY] #1971913
12/18/15 02:10 AM
12/18/15 02:10 AM
CA.
CA.
Lol that's bada$$
Re: Small block h beam rods [Re: RAY1969CARS] #1971929
12/18/15 02:36 AM
12/18/15 02:36 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
it was a cool bare bones combo.... built of obsolete hard to find parts unfortunately... we ran Eagle rods and crank. But after repeated bouts with water entering the #3 intake port... which finally resulted in a rod failure, we abandoned the project.
Re: Small block h beam rods [Re: J_BODY] #1971936
12/18/15 02:42 AM
12/18/15 02:42 AM
CA.
CA.
That's one hell of a cool motor
Re: Small block h beam rods [Re: RAY1969CARS] #1971953
12/18/15 03:11 AM
12/18/15 03:11 AM
New York
polyspheric Offline
polyspheric  Offline
New York
How heavy is the piston?
What rod bolts?
Boffin Emeritus
Re: Small block h beam rods [Re: RAY1969CARS] #1972054
12/18/15 12:14 PM
12/18/15 12:14 PM
, PA
sleepyhead416 Offline
, PA
Eagle H-beams here 7400 rpm 416 no problems.
