Page 2 of 11 1 2 3 4 10 11
Re: My bracket hemi build [Re: Triple Threat] #1973426
12/20/15 07:05 PM
12/20/15 07:05 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
Just saw the link didn't go according to plan, here it is
http://www.hughesengines.com/TechArticles/21740hpgen3hemi.php
Re: My bracket hemi build [Re: Triple Threat] #1973642
12/21/15 02:02 AM
12/21/15 02:02 AM
Renton Washington
Triple Threat Offline OP
Renton Washington
For comparison sake I had a 390 LA engine in this car before. It had 2 points less compression, 11:1, a similar sized solid flat tappet. And heads that went 280@.600
That combo went 10.75@123 on pump gas.
2 points more compression, 75 more CFM of head flow at .600 and some corn juice fueling it. How much ET is that worth??? Hopefully enough haha.
Car is only legal to 10.00 as it sits....
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: My bracket hemi build [Re: Triple Threat] #1973645
12/21/15 02:07 AM
12/21/15 02:07 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Yep you will be slowing it down to stay legal.
Mopar to the bone!!!
Re: My bracket hemi build [Re: Triple Threat] #1991631
01/15/16 11:10 PM
01/15/16 11:10 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Don't normally drop in on the GIII page, so I had missed this until now. Looks like a great build, License & more cage work may be in your future. Cant wait to see the Red Car under your shoe again, D!
Re: My bracket hemi build [Re: Triple Threat] #1999808
01/27/16 02:33 PM
01/27/16 02:33 PM
Renton Washington
Renton Washington
Pistons finally showed up last week so got the block bored and honed to size.
Owner of the shop was happy we used the torque plate, he checked it after finishing with a bore gauge and noted it moves about .0008 with the plate not bolted down.
Will begin our mock up next week.
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2000287
01/28/16 03:17 AM
01/28/16 03:17 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
Good luck on the build, looking forward to see how it runs
Be nice to know someone hear in the NW that's figuring out all the tricks to get one of these going!!
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: My bracket hemi build [Re: Triple Threat] #2000471
01/28/16 02:15 PM
01/28/16 02:15 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Looking good!!!
One question?
Would it wise to deburr the top of the piston? They LOOK like they have shape edges.
Matt
Re: My bracket hemi build [Re: Triple Threat] #2000548
01/28/16 04:04 PM
01/28/16 04:04 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I agree^^^, I would sand those crowns with wet 1000 grit.
Re: My bracket hemi build [Re: Triple Threat] #2000613
01/28/16 05:59 PM
01/28/16 05:59 PM
Renton Washington
Renton Washington
They look sharper in the picture than real life, but i'll definitely be going over everything.
Thanks for the idea!
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2000700
01/28/16 08:09 PM
01/28/16 08:09 PM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
dropped my motor off at the machinist today. got to see Dustin's heads on the cart. more sexy jewelry.they look fricken awesome! lol
Re: My bracket hemi build [Re: MattW] #2000980
01/29/16 02:35 AM
01/29/16 02:35 AM
In a house near you
Street Monkies Offline
In a house near you
They do look nice, but I agree also. You can't go wrong making sure everything is deburred, and smooth. Less chance for detonation. Looking forward to hearing how it runs. I hope it goes exactly what you want. I think it will.
Re: My bracket hemi build [Re: Triple Threat] #2001223
01/29/16 02:29 PM
01/29/16 02:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
That piston looks like detonation city, as well as blocked flame travel and crevice volume up the wazoo. Would it not have been better to mill the heads some and get a much smoother dome shape even if it still ended up a tad less compression?
As for polishing pistons tops I use 1000 grit also and wet it but not with water but WD-40, it seems to clog less.
Re: My bracket hemi build [Re: Triple Threat] #2001228
01/29/16 02:35 PM
01/29/16 02:35 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I guess I should elaborate on the detonation, those ridges beside the exhaust valve look like the worst offenders, they are gonna get real hot real fast as well as blocking flow of the last little bit of exhaust stroke and that will reduce scavenging. I would eliminate them all together. Then open up the spark plug divots for more access for the flame to travel to all surfaces faster and easier then put a big radius on everything else except above the top ring land obviously. I bet you will make more power and reliability even if it costs 1/2 point compression.
Re: My bracket hemi build [Re: HotRodDave] #2011094
02/13/16 01:47 PM
02/13/16 01:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yea I just decided to drop in over here because the new Gen III Hemi's really impress me and yours sounds like its gonna be a very nasty running build. up Good luck as it sounds like you will hit 10.0's or better to me. Ron
Re: My bracket hemi build [Re: Triple Threat] #2014250
02/17/16 09:25 PM
02/17/16 09:25 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
you will have no problem running 10flat
Re: My bracket hemi build [Re: Triple Threat] #2014381
02/18/16 12:15 AM
02/18/16 12:15 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I would have gotten ceramic coatings on the pistons...oil shedding on the bottom, heat reflective on top and anti scuff on the sides
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: My bracket hemi build [Re: Triple Threat] #2014637
02/18/16 01:05 PM
02/18/16 01:05 PM
Renton Washington
Renton Washington
We did some mock up this past weekend.
Piston to Valve
.075 intake
.115 exhaust
My Apaches are 71.5 CC
Compression appears to be 13.5:1 based on our calculations, should work fine on E85.
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2014745
02/18/16 03:52 PM
02/18/16 03:52 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Piston to Valve
.075 intake
.115 exhaust
you need bigger cam and you can send me your little one that is bigger than mine
Re: My bracket hemi build [Re: Triple Threat] #2015056
02/18/16 10:45 PM
02/18/16 10:45 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Good to see you are making progress Dustin.
"Just a Bracket car dressed up like a streetcar"
Re: My bracket hemi build [Re: Triple Threat] #2026460
03/07/16 01:06 PM
03/07/16 01:06 PM
Renton Washington
Renton Washington
Short Block is together. Trying to have the engine completely finished this week.
-Dustin
