Re: Prepping a stock block for racing [Re: rebel] #1968638
12/12/15 10:58 PM
12/12/15 10:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL.. its funny you use a screwdriver on the stand
just like I do
wave
Re: Prepping a stock block for racing [Re: MR_P_BODY] #1968652
12/12/15 11:13 PM
12/12/15 11:13 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
just like I do
wave
X2
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Prepping a stock block for racing [Re: rebel] #1968658
12/12/15 11:29 PM
12/12/15 11:29 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Originally Posted By rebel
Apart from sonic testing, magnafluxing & Torque Plate honing, what prep work do you do to make a factory block race ready? I was deburring my 400 block, cleaning up all the casting flash & generally smoothing my block, when a Chevy friend looked at what was doing & said I was wasting my time. Do any of you guys that work on stock block racers do any cleanup of the block? I coated all the inside surfaces with POR15 to make for a smoother surface for oil return, am I going too far?
Alot of machining steps involved but the main ones are:
Make sure decks are 100% square and parallel to the corrected crank center, bush lifter bores to make sure they're correctly positioned and aligned with the cam lobes, make sure the crank throws are indexed correctly and the journals have proper radius and clearances, bore and hone with torque plates and main caps installed (ideally at operating temp).
When you clean up after machining make sure you remove ALL galley plugs and thoroughly scrub all passages with strong detergent and rinse with hot water then blown dry with compressed air - repeat until brushes come out clean and no debris is blown out.
Re: Prepping a stock block for racing [Re: Stroker Scamp] #1968660
12/12/15 11:32 PM
12/12/15 11:32 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
just like I do
wave
X2
And somehow they can't drill the hole so the engine sets straight up!
Re: Prepping a stock block for racing [Re: MR_P_BODY] #1968666
12/12/15 11:43 PM
12/12/15 11:43 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
just like I do
wave
mine is actually a 1/4 drive screwdriver but the ball bearing fell out years ago so the sockets don't stay on it. but it recycles real nice in this job. many a time i've thought about cutting it down but i never seem to get around to it.
Re: Prepping a stock block for racing [Re: rebel] #1968751
12/13/15 01:45 AM
12/13/15 01:45 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
You can never go too far. All the above mentioned plus any sharp edge in the block and caps should be rounded off to prevent stress points
Re: Prepping a stock block for racing [Re: rebel] #1968762
12/13/15 02:06 AM
12/13/15 02:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
One other thing I do is to glue screen into the
intake valley.. that way it keeps any top end
parts from getting down to the bottom.. I use
JB weld to glue it in.. then I paint the valley
area.. I cover the screen when painting
wave
Re: Prepping a stock block for racing [Re: MR_P_BODY] #1968800
12/13/15 04:18 AM
12/13/15 04:18 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
wave
1 step ahead of you Mr P. I've made a couple of these in the past but I'm going to reallocate this one from the dead block it resides in.
Re: Prepping a stock block for racing [Re: rebel] #1968981
12/13/15 03:58 PM
12/13/15 03:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Looks nice up
wave
Re: Prepping a stock block for racing [Re: rebel] #1969268
12/14/15 01:33 AM
12/14/15 01:33 AM
Washington
skrews Offline
skrews  Offline
Washington
Have the block sonic checked before doing anything else.
Re: Prepping a stock block for racing [Re: rebel] #1969476
12/14/15 03:23 PM
12/14/15 03:23 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Personally - I like a old block baked then shot blasted - versus the old method of chemical hot tank. But regardless in the end it has to be washed clean - then cleaned again with brushes and all the thread chased clean. New or old makes no difference cleaning is the same - the more you clean it the better it will be! painting the inside is a personal preference - I go with unpainted.
Re: Prepping a stock block for racing [Re: rebel] #1969535
12/14/15 04:43 PM
12/14/15 04:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I clean them with really strong degreaser like red-hot or bleach-white for cleaning brake dust off wheels and tires, let it soak but don't let it dry, then I hit it with hot watter from my pressure washer, a couple times of this and it is ready to check out and machine if it checks out OK, dirll 1/8th drainback holes in lifter valley to drain oil puddles right onto cam lobes (all 16 if possible), then wash it same way a couple more times when back from machine shop, then test fit everything, adjust grind where needed dissasemble it and clean a couple more times and set up a big heater under the block to help it dry quickly, then mask it off and paint then assemble.
