Axle splines on 8.75 rears?? #1963422
12/04/15 11:11 PM
12/04/15 11:11 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
I noticed spools on Ebay referring to 30 spline and 35 spline axles. Are each of these spline counts specific to any specific application? Would an A body most likely use the 30 spline axles?
Re: Axle splines on 8.75 rears?? [Re: DusterKrazy] #1963440
12/04/15 11:37 PM
12/04/15 11:37 PM
(1) probably but not sure what app is what (2) yes
Re: Axle splines on 8.75 rears?? [Re: DusterKrazy] #1963451
12/04/15 11:46 PM
12/04/15 11:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
As far as I know the 8 3/4 has one spline count, period.
No one ever wonder if the SG would fit based on spline count.
Sounds like a non-8 3/4 posting in that ad, but it is Ebay, not like it's the fount of accuracy.
Don't be the exception.
Re: Axle splines on 8.75 rears?? [Re: DusterKrazy] #1963459
12/04/15 11:57 PM
12/04/15 11:57 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
I went through this same dilemma when I bought my TruTrac earlier this year. They are 30 spline.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: Axle splines on 8.75 rears?? [Re: DusterKrazy] #1963465
12/05/15 12:03 AM
12/05/15 12:03 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Stock axles are 30 spline. You can get aftermarket axles in 35 spline.
I have one of those spools. I have not tried to install it yet, but it looks very nice.
Re: Axle splines on 8.75 rears?? [Re: slantzilla] #1963468
12/05/15 12:09 AM
12/05/15 12:09 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
30 spline 8.75 are the same as 30 spline dana 60...
Re: Axle splines on 8.75 rears?? [Re: DusterKrazy] #1963473
12/05/15 12:15 AM
12/05/15 12:15 AM
All the stock Mopar 8 3/4 rear ends came with 30 spline axles, all of them up When Mopar started using the Dana 60 rear ends in the H.D. cars options they came in several different spline counts with 35 spline being offered in 1970-1971. The 8 3/4 aftermarket spools are offered with 30 and 35 splines so you can use either axle spline you want, the 35 spline axles are a bunch bigger and better for street and drag racing a car that has good HP and hook with a 8 3/4. up scope Bottom line is the 8 3/4 are a decent rear end for most applications, they where never designed nor intended to be used in high HP cars for drag racing shock If you are planning on racing a car that weighs above 3000 lbs with the driver in the high tens or quicker in the 1/4 mile and you need to build a rear end for the car you may want to think about using a Dana 60 to start with thumbstwocents shruggy
